Question about Ovens
Amana arg7800ww oven will not come up to temperature.
Already replaced oven temperature sensor, but oven will only heat up to 120 degrees. The Broiler ignitor will glow when turned on but will not ignite. Is it the gas valve??? any help will be appreciated. the stove top burners work fine,,
  • maurhoff Jan 16, 2009
    The ignitor did the trick!! Let's hope this stove holds out a bit longer. Thanks
  • 21 Answers
Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
Posted on Jan 13, 2009
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Jan 23, 2018 | Bosch HBL3420UC Electric Single Oven
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Bottom element is not heating to temp an shuts off during heat up - without error code showing in the display. IE. - Press Bake, 350 degrees defaults on screen; Press Start. YOu hear the Click as it...
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 05, 2011 | GE JTP15 Electric Single Oven
Oven turns on, but w2ill only heat up to about 120 degrees, you can reset and increase temp, but will only go to 150 degrees. Broiler works, but oven anf d oven clean do not work
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 18, 2011 | Amana Ovens
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
F3-error. Kenmore classic oven Heating element will not go pass 100 deg. Heating element recently replaced. Broiler is also malfunctioning
Hello there:
Whenever you get the dreaded f-3 code this is the code that tells you that the temperature sensor is going bad or already has gone bad and needs to be replaced immediatly. It should look something like this and cost about 50 dollars
Jun 20, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
My oven has increased only 65 degrees in almost an hour....what does it mean when it heats up, but SLOWLEY??
The broiler element on the top of the oven comes on during the preheat cycle to speed things up and then only the lower element keeps the temperature steady. One of those elements is bad, probably the broiler. Try using the broiler and see if it works. If not, you need to disconnect the elements from the oven and check them with an ohm meter. If gthe elements check out ok, then it must be the temperature sensor/thermostat.
Jun 25, 2009 | Frigidaire FEB27S5A Electric Single Oven
Broiler won't turn off. Error code F-3
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
Ovens Logo
348 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
