Question about Dynex Televison & Video
What size vesa screws for samsung 8000 series 55 inch?
MODEL UN55D8000YF NEED THE 4 SCREWS TO MOUNT ONTO THE WALL BRACKET...PLEEEEASE
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
budmrtn
  • 11361 Answers
SOURCE: LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 01, 2010
Testimonial: "Thank you! We'll head to Lowe's tomorrow to pick up the appropriate size screws. We just moved into a new home and they left the wall mount up for us, but did not leave any of the extra screws that went with the mount. Thanks again! "
SOURCE: VESA Screws
I went to Lowes and found some 4mm .7 screws, 25mm long, and they worked like a champ. (get the lock washers too)
Apparently, most mounts include only 5mm and larger screws
Posted on Oct 08, 2010
SOURCE: MNTR SMSNG|LCD 24" 5MS B2430HD RT I am looking for
Sansung Custermer Service told me these screws were an odd size and offered to send the screws to me. 8 week and 6 phone calls later and still no screws!!
I have tried M5 and M4 and both were too large. I'm trying to source M3's and hope they will fit, otherwise I'll return the TV to Costco.....
Posted on Dec 29, 2010
SOURCE: TV wall mount screws for Dynex 32" TV, which size?
Orchard supply.....Metric Cap Screw size:
M6-1.0 x 12MM
They come 2 to a package for about $1.39
Posted on Jan 30, 2011
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
Best wall mount to install samsung curved 55 inch tv
Contact the authorized service center for Samsung. They can provide you more details. http://electronicshelponline.blogspot.com/
Feb 18, 2015 | Samsung Televison & Video
We want to wall mount thevTV what size screw fits the back of the TV? Sanyo model DP32649
Assuming a modern TV with a square/rectangular arrangement of holes (i.e. VESA mount) - they're M4, length varies.
Appropriate screws will be in the kit with the wall bracket.
Nov 08, 2014 | Televison & Video
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
HI , I'm looking for the size of the mounting bolts that would be required to mount a 32 inch Sony LCD TV.
If you are talking about the mounting screws that go into the back of the television to mount a VESA sized wall bracket, then it's most likely 5mm screws. The length of the screws could differ, depending on the bracket you are attaching, but usually 12mm or 16mm can be used. just make sure that the screws are long enough to thread into the TV completely, but not too long, or they may damage internal components.
If you are talking about the Lag screws needed to mount the bracket to the wall, then use 3/8" width lag screws 2 1/2" to 3 1/2" long, depending on how deep you have to go before hitting the wood stud.
Apr 03, 2011 | Televison & Video
I have a 32 inch ATSC/ALT3200N....Need a wall mount for it, and where to get same.
If you know what the Mounting comfiguration is... 200mm x 200mm etc. and the weight of the unit, then you can start your search...google search for the mounting size... i.e. "200mm x 200mm LCD wall Mount bracket"
that will get you started... then you can narrow down the search for the Weight supporting limitations.
your manual saids the hole pattern is:
Vesa standard (300x200mm)
Screw type: 4 x MB5x10
here's my search results:
http://www.google.com/#q=300mm+x+200mm+wall+mount+bracket&hl=en&prmd=ivns&source=univ&tbs=shop:1&tbo=u&sa=X&ei=yjx5Tf2vJZKw0QHL-ZzMAw&sqi=2&ved=0CFMQrQQ&biw=1015&bih=642&bav=on.2,or.&fp=86eb73c4baae05b0
Mar 10, 2011 | Televison & Video
I have 1 tv Thomson 32E92NH22 LCD and i lost the manual.I'm trying to get it hanged on the wall.No ideea what tipe of screw i need to conect the tv to the wall hanger.Can somebody halpe me?Thanx a...
Hi mona_77a,
You can find the manual for your TV here.
Your Thomson TV is compatible with a VESA FDMI (Flat Display Mounting Interface.)
These typically use "VESA screws."
VESA screws tend to be metric sizes of M4 (0.7mm pitch). The length is typically 10mm, but would depend on the bracket (if you don't have a gauge handy, just put a small stick of some sort in there and mark it off with a felt pen, then measure).
Washers are a really good idea, especially if you decide on thumbscrews with plastic heads.
You may be interested in eHow's tutorial on how to mount a flatscreen TV to a wall. This is for a 42 inch screen, but the same rules should apply with a 32 inch.
  • Open Link in New Tab
  • Download
Mar 01, 2011 | Televison & Video
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
I have a Samsung LN32A450 and a Peerless SGLs01 mount. I need to put on the universal bracket onto the back of my TV but the back of my TV is not "flat", is more like a small S-curve so the lower part is...
That TV is new enough to have a VESA standard connection on the back, try attaching the mount directly to the 4 screw holes on the back, tv's don't normally need an adapter if the back is fitted with VESA. if not you can find low cost adapter plates on www.etvmount.com for the most part any vesa adapter than matches your size will function fine.
good luck-
Will
www.compressionconnector.com
Feb 19, 2009 | Akai LCT2721AD 27 in. LCD Television
Televison & Video Logo
482 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
