Question about Hitachi Televison & Video
CLU-351U remote has no set button. How can you enter a code?
3 Suggested Answers
  • 121 Answers
SOURCE: i need the vcr codes for a hicachi CLU 4362S REMOTE
I fyou have an rca remote try 055, or 056, or 057 or 107 or 111 or 120 or 538 or 324 or 336 or 931 or 834. See if those are helpful if not post your remote and model............Thanks for using Fixya .com : )
Posted on May 24, 2009
SOURCE: remote codes needed
http://www.hitachiserviceusa.com:8080/57S700.pdf
Go to Page 34 for instructions and the codes are on page 40.
Posted on Jan 03, 2011
How do I program my Hitachi clu-4997s remote control?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 27, 2014 | Hitachi Remote Control CLU-4997S...
Is the hitachi clu-5727tsi remote capatible with sony televison
If it has set-up code to sony brand TVs, you can. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Aug 19, 2014 | Hitachi CLU-5727TSI Remote Control HL01827
How to re-program remote clu577tsi hitachi tv
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Apr 03, 2012 | Hitachi Clu-577tsi Remote Control
I need a code list for true tech dvd player for my hitachi clu 4362s
Hello
There is no setup codes for Trutech DVD player to synchronise with the Hitachi CLU-436S remote control. OK.
Oct 15, 2011 | Hitachi CLU-4324UG Remote Control
Service menu codes for P42H401 plasma
PROCEDURE:
(1) With Plasma turned On, Enter the I2C Service Menu: (Remember, you are doing this without seeing a picture).
  • Press "EXIT" once, just in case TV Guide is brought up for Set-Up.
  • Press "Menu" and wait a few seconds.
  • Press "Menu" ~ "Menu" ~ "8" ~ "Select" Buttons on the Remote:
  • The Service Menu is entered, even though you can not tell.
Service Menu selection you can not see
  • To navigate and adjust while in the Service Menu, use the remote control's Cursor Keys.
Dec 31, 2010 | Hitachi P42H401 42 in. Plasma HDTV
I need the code to program my hitachi remote control to a SDV290 Toshiba Dvd player?
1.Turn on the component to be programmed, such as the television or DVD player.
2.Press the "Code Set" button on your Hitachi remote. The button is often located near the top with the separate component buttons.
3.Press the button for the component you wish to program with the Hitachi Remote(TV,DVD).
4.Enter the manufacturer's code for the component being programmed. The manufacturer's code can be found either in the Hitachi manual, the manual for the component being programmed or on the website of the manufacturer of the product.
5.Press the "Enter" button to submit the manufacturer's code.
6.Press the power button for the component being programmed. Make sure the remote is pointed at the correct component, and it should turn on if the program was entered correctly
Thanx
Jul 29, 2010 | Hitachi CLU-5713TSI Remote Control
I want to set up my remote clu 5729tsi to the cable box
Try this as all remotes work about the same when manual setting.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 28, 2009 | Hitachi CLU-5713TSI Remote Control
Search for your codes
Here is the owners manual for the TV. Programing the remote instructions are on pages 28-31 (codes on on page 31) http://dl.owneriq.net/7/761c1421-be39-40c4-b493-a94c83223d90.pdf
Jul 14, 2008 | Hitachi CLU-5713TSI Remote Control
Hitachi CLE984
The code you need is 0145
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Jul 01, 2008 | Hitachi CLU-5713TSI Remote Control
Remote code
You won't be able to use it for your dvd player unfortunately.
The code for sky is 0145.
Gaz
Jan 14, 2008 | Hitachi CLU-4324UG Remote Control
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
