I want to change my security password, what shall i do?
    Problem Solver:
  • 5 Answers
If windows, do ctrl-alt-delete, change password should be an option on the dialog that comes up.
Posted on Dec 12, 2012
I have a SBG6580. I am trying to enter the security key but cannot find it on the back of the router...please help
I shall have to assume you in a 'Factory Reset' situation, where you have not signed into the modem, and changed username/password defaults, (new unit, fresh out of the box).
Do not connect to the cable company yet. First, secure the modem.....
From the User Manual, page 9..... You do have a User Manual?
1. Open a browser window, after connecting your computer.
Use a 'wired' connection. Never change security settings, using Wi-Fi connection.....
2. Type in the IP address for the modem 192.168.0.1 in the URL address. That should take you to the modem's password change window.
3. Type in the default Username: admin.
4. Type in the default Password: motorola.
5. Type in your new username in the Password Change Username field.
6. Type in your new password in the New Password field.
7. Re-enter your new password
8. Re-type your new username in the Current Username Password field.
9. Click Apply.
10. Connect the modem to the cable company. You should shortly be able to go online, after the modem has synchronized to the cable company. That usually takes about a minute.
Your question asks for the 'security key'. That generally refers to the Wi-Fi settings. If that is the case, go to the 192.168.0.1 address, sign-in, and click on Wireless. Follow the obvious directions.... Or, post here again....
Feb 12, 2015 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
I want to change my security password. what shall i do?
This article actually has most if not all the info you are looking for. It should be under WiFi Protected Setup.
http://portforward.com/english/routers/wireless/Encore/ENHWI-N2/wireless.htm
Dec 12, 2012 | Encore ENHWI-N2 802.11n Wireless Router...
I don't have security set up on my Linksys router
Turn over router and check in the bottom default access IP address and then type that IP address in to your browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password` as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply and reboot if prompted.
Dec 06, 2012 | Linksys Wireless-g 2.4 Ghz Broadband...
I can't reset my bios password
BIOS password can be removed using either of these two ways:
1) Take you BIOS cell out for a while and then plug it in again and your BIOS password shall be removed.
2) You can also change your BIOS Jumper Setting. Generally the BIOS jumper resides on pin 1 and 2. You simple take it out and then plant it in on pin 2 and 3. Power on your computer and then power it off. Then change the jumper to default setting that is pin 1 & 2 and then once you shall power on your laptop the BIOS password shall be removed.
The BIOS jumper resides on the motherboard and there is a marking on it stating "BIOS" which shall help you identify the correct jumper.
Oct 30, 2012 | HP Compaq Business Notebook 2230s
Forgot password how do i change it
Oct 02, 2012 | Linksys Cisco-Wrt160n-rm Wireless N Router
Change password
Mar 28, 2012 | Linksys Computers & Internet
HOW CAN CHANGE MODEM PASSWORD
Good Luck
Oct 21, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
I have forgotten my security code. My phone is working since it is not locked but I want to change my password. What shall I do? Plz suggest me something good.. I need to change my password anyhow.
hi you can use master reset codes to reset your mobile .you can get the codes from here
prounlocking
here they ask the following details before rendering the codes they are
1.mobile model
2.imei number of the mobile
finally they will send you the master reset codes .
Aug 30, 2011 | Nokia 7210
I forgot the password and username,and i want to change the security password of my router what shall i do?
If you have forgotten the router's password then you have to reset the router to factory default to access the interface again. Then you can use the router's default user name and password, that is admin and admin (or username: " " (leave it blank) and password: admin (all in lower case)
You can find the default passwords on the following website;
http://www.routerpasswords.com/index.asp
Once you have logged in to the router console, you can set new security password
Apr 01, 2011 | Linksys WRH54G Wireless Router
I forgot my password for my Linksys SPA-2102 phone adapter and router, how can reset it without the old password
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first...
Then turn over router and check in the bottom default access IP address and then type that IP address in to your browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password` as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply and reboot if prompted.
Dec 20, 2010 | Linksys SPA-2102 NA Analog VoIP Adapter...
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
