Question about Plumbing
Replace cartridge in kwc luna faucet
How to remove handle to replace cartridge
  • 34 Answers
SOURCE: leaking Jado lavatory faucet
It is a rubber gasket that is leaking, Pull the cartridge with a cresent wrench. There will be a paking nut on the top of the cartridge where the handle connects. You should be able to remove this with a pair of pliers. There will be a rubber o-ring inside. Take that to the hardware to to find a replacement to it. It wont be hard to match they keep tons in stock at ace or lowes
Posted on Feb 04, 2009
  • 659 Answers
SOURCE: KWC FAUCET
http://www.kwcamerica.com/wheretobuy.php
Here is the info you requested.
Posted on Apr 11, 2009
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
Dplumber
  • 119 Answers
SOURCE: How do I remove handle
There should be a small hole under each lever handle. Inside the hole is a handle setscrew. Use a 2.5mm hex wrench to loosen, not remove, the setscrew. turn the screw counter clockwise to loosen, and then the handel should just pull straight up and off the faucet. Here is a parts breakdown for the PRICE PFISTER Treviso Wide Lavatory Faucet T49-DK00.
Posted on Sep 08, 2010
Dplumber
  • 119 Answers
SOURCE: I just replaced the cartridge in my KWC faucet and
It is possible that you installed a bad valve cartridge, it would not be the first one. It is also possible to over tighten the cartridge retaining nut, rare, but it can happen. In either situation you need to call KWC and ask them to send you a new cartridge asap. They are usually very easy to work with. If you need further assistance please let us know.
Posted on Sep 17, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    I installed a uberhaus tub and shower faucet luna series and I don't have the instructions the water won't shut off when I turn the handle to off
    you might have the cartridge turned 180 degrees out of alignment. remove the handle, and carefully rotate the stem until the water shuts off, then re install the handle in its appropriate position.
    Mar 26, 2015 | Home
    Installed a new KWC Domo faucet and its leaking (alot) under the sink
    Does if have a sprayer and is it still hooked up?
    Aug 14, 2014 | Plumbing
    New kwc domo leaking under (alot) sink
    mixing chamber of the faucet may be cracked
    Sticking of KWC Suprimo faucet
    My bathroom faucet handle (not same brand as yours) was so hard to turn that it pulled the base around with it on the vanity when I jerked it. I used an Allen wrench to take out one of the set screws holding the handle on, put the tiny straw of a WD40 can in the set screw hole, squirted WD40 inside the handle, replaced the setscrew, and worked the handle to and fro a few times to lubricate the inside. No more sticking!
    Feb 22, 2014 | KWC 10.271.333.700 Suprimo Kitchen Faucets
    Kwc kitchen faucet
    Usually you need to use a hex key to unscrew.
    Could you take a photo of the faucet and show us?
    Feb 03, 2014 | Plumbing
    Kwc faucet washers
    lowes home improvment
    Dec 11, 2017 | Plumbing
    KWC Domo single handle faucet is sticky...how do I fix that? Do I have to replace a cartridge?
    Have the same issue. No one seems to have an answer, including KWC (except to buy a new $90.00 cartridge).
    Nov 09, 2010 | Danze D403412 Melrose Single Handle...
    I just replaced the cartridge in my KWC faucet and now it's very hard to raise and lower the on off handle. Any advice?
    Sep 16, 2010 | Grohe Plumbing
    Need instruction for installation pull out faucet
    firs you have to remove the handle
    remove lastic cap on top or no cap look for a erasure size cap or ruber tab on the side
    take a flashlight and determine if you need an allen head screw or phillps
    remove the screw( be sure to cover your drains so nos small parts get in bottom
    remove the handle
    depending on the type of faucet you may have to unscrew a large nut holding the cartridge in place
    whatever remove anything holding the cartridge down (some require a cartridege remover)
    remove, take to store match up new and replace
    by all means turn water of under sinnk good luck
    TIP anytime you have to put a wrench on chrome protect chrome with a wash cloth
    Jan 08, 2009 | Dmm KWC K.24.41.61.000C28 Gastro Deck...
    Plumbing Logo
    378 people viewed this question
    Top Plumbing Experts
    Andrew Bugbee
    Tom Chichester
    Gil Shultz
    Are you a Plumbing Expert? Answer questions, earn points and help others
