Question about Onkyo HT-S5300 Theater System
No sounds on my speakers
No audio
How to use speaker in computer?
Does your motherboard has an onboard sound card? If it has then read your motherboard manual especially the audio section of the manual where the topic is described how and where to plug in which audio jacks coming out from you speakers (speaker system) to which part of the external audio ports usually located at the rear end of your computer case. You need to install the sound card drivers to activate audio properties of your computer of course, to actually use the speakers.
You can also use the front panel audio port of your computer case where you can connect your speakers to as well.
In case your motherboard did not come up with sound card installed you can always install an external sound card and then connect the speakers to the proper external audio ports of the card. Just read your motherboard or sound card manual. It is all there.
Jun 03, 2011 | Audio Players & Recorders
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
The speakers are not working. if i turn up the volume, I can hear static noise, but do not get any sound. tv speakers are on. I played around with the audio settinds and all the different hdmi ports,...
Hello
There are two possibilites for this fault. The first one is, damaged speaker voice coil and the second one is damaged audio output IC. To confirm it you have to open your TV. Speakers can be checked without removing them from the cabin fittings. Check them with the helap of a multimeter; set in OHms range. You can alos check it with a standard torch cell also. Connect the two terminals of the torch cell to the two terminals of the speaker [intermittantly, not constantly]; will produce a 'thumb' sound; if the speaker is good.
Connect the 'audio out socket' of the tv, with any other audio equipment, and listen whether there is sound form the external audio equipment, like amplifier or so. If there is sound from the external audio equipment, and no sound from the internal speaker of the TV, and the speaker is good, surely the 'audio output IC' of the TV is damged and should be replaced. OK.
May 13, 2011 | Vizio M550NV 55 in LCD HDTV
I just bought logitech 5.1 surround sound speakers, but its making a buzzing noise how do i fix that please. could it be that my sound card is not good enough?
if you buy a 5.1 speaker you also need 5.1 sound card that supports the speakers. although it will still work with ordinary sound card but you can't actually use the feature of the speakers. the buzzing sound can cause by loose connections of the audio cable or audio connector. you can also hear a buzzing sound if you connect it at the wrong port. just remember the color codes
green - audio out (for speakers) red - microphone blue - line in or audio in black - digital audio
Apr 22, 2011 | Logitech X-530 5.1 Speakers
I recently purchased an M audio sterophile Usb soundcard. I want to connect my computer speakers up to it. I have tried many ways and dosnt seem to work? Please help.
you might need to install the sound drivers or select the right speakers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable
hope this helps
Mar 17, 2011 | M-Audio M Audio Audiophile USB Sound Card
Speakers are plugged in but there isn't any sound coming out of the speakers, yet i know the speakers work i tried them on my laptop
Things to check:
  1. Ensure you are plugging into the correct port. Some systems have both integrated audio and and expansion sound card. If it has both, the expansion card should be the port to connect the speakers. Generally all desktops use Green as the speaker jack color.
  2. Ensure the volume control is not muted. Set volume for 75%
  3. Ensure if the audio is integrated, that the audio is enabled in the BIOS
  4. in Control Panel, Sounds and Audio devices, make sure the sound card is the default playback device. Also ensure that Stereo desktop speakers are selected as the speaker tyoe.
Mar 28, 2010 | Dell A215 Computer Speakers
Connect creative 4.1 speakers with laptop at time 2 speaker work
i assume ur mother board supports surround sound an ur using windows os. go to control panel - sounds and audio devices - speaker settings-advanced - speaker set up with the drop down menu. select surround sound - apply - ok.
if ur using surround audio drivers like realtek, etc. the settings console should have somewhat similar options like audio input/output (I/O) options. select surround sound speaker setting and configure which audio port should be audio output ports. driver settings can be accessed from control panel too. to access control panel click on start menu there u'll see the control panel menu.
Mar 13, 2010 | Creative Labs Audio Players & Recorders
Windows 7 Audio Quadraphonic Not functioning well
Sounds like you are getting quad sound in the test process that checks them, yet when in windows media player or winamp (or whatever) your rear speakers aren't producing sound: Try setting your sound drivers to do something like "speaker fill" then you are set. I'm under the belief that stereo sounds aren't being matrixed into all 4 speakers.
Mar 25, 2009 | Computers & Internet
My speaker sound
If you are using Windows XP, click >Start>Control Panel>Sound, Speech and audio devices> again >Sound, Speech and audio devices> then check the "Device Volume" control. Also check the controls under "Advanced" button.
Feb 15, 2009 | Polk Audio AMR50 Computer Speakers
Onkyo HT-S5300 Theater System Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
