Question about Onkyo HT-S5300 Theater System
My speaker is no sounds
I connect all speaker wires but still no audio
    New Friend:
    Problem Solver:
  • 7 Answers
Connect the front speakers to the 2 Big Banana plug/screw type connectors marked speakers A and not the 2 color coded ones that are push in style. the B channel speakers are actually color coded and I hooked mine up this way and had similar issues.
Posted on Mar 24, 2013
I have a 2000 oldsmobile alero and I can't get sound out of my rear speakers good speakers and connection just no sound
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
2001 Oldsmobile Alero Car Radio Stereo Audio Wiring ...
www.modifiedlife.com/2001-oldsmobile-alero-car-radio-stereo-audio-wi...
Easy Plug and Play Wiring Adapter. ... 2001 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram ... If you can't find your car audio wire diagram, car stereo wire diagram or car radio ... Right Rear Speaker Positive Wire (+): Dark Blue ... olds alero and I have replace the stock stereo and have found that the sound out put ...
Request a Oldsmobile Car Radio Stereo Wiring Diagram
Jan 21, 2016 | Oldsmobile Cars & Trucks
No sound
Tried unplug,replug the tv back about an hour later.Than do resetting to all audio setting back to factory setting.Now ur tv should have audio back again.If this is a computer audio problems,check ur speaker plug in wire from the sound card jiggle the wire a little.Ur computer audio should return,most of the times just cold connections between the sound card and the audio speaker wire connections.
Feb 09, 2013 | Computers & Internet
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
What should I do if there is no audio output from the speaker
check your speaker if it is good you can do this by putting a meter to the two connectors on the speaker.or using a battery with wires and connect them to the speaker which will give you a audible sound if that is absent then your speaker is bad..if there is sound then check the ic or transistor in your audio section.the speaker wire is connected to the audio section.
Jul 11, 2010 | Televison & Video
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and...
bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Jun 21, 2009 | Polk Audio RTi A7 Main / Stereo Speaker
Trying to reconnect a set of Harman Kardon candlestick computer speakers to a Dell Dimension E520 computer. I got three plugs and dell has 6 holes...what the heck goes where? Nothing I seem to try works...
Hi rjlevesque
For the speakers, you need only connect to the GREEN jack at the back of your computer. It's OK to leave the others blank.
Your two HK speakers will, with one wire, connect to each other and, w/ another wire (usually having a GREEN connector on the end), connect to the computer.
I'm not sure what the 3rd wire is unless it's (1) the power connector or (2) for connecting to a sub-woofer.
Does the speaker set include a sub-woofer? Or does it include a "surround sound" or 3rd speaker?
You can find pics & symbols (the symbols are helpful if your sound card jacks are not color-coded) for (3) of the most common audio connections HERE.
Usually the color of the connector on the wire is matched to the sound card jack w/ the same color. (green to green; pink to pink; blue to blue).
green = speakers
pink = mic
blue = line in
Make sure you are connecting to the active sound connectors - the ones you used b4 the HK speakers.
If you have "integrated audio" (audio that is built into the motherboard) and you have an audio expansion card installed on the computer as well, one may be disabled or not selected in your computer's audio configuration.
If that's the case (that you have two sets of audio jacks to choose from), try connecting the speaker wire from the HK speakers 1st to the green jack (or the jack marked w/ the symbol of a speaker) at the bottom of your computer. (There'll only audio jacks here if there is an audio expansion card installed on your computer.)
If that is the case, there'll be other (usually) colored jacks running horizontally next to the speakers jack.
If you still have no sound, connect the speaker wire to the GREEN jack that is (usually on Dells) up by your PS2 (round - one purple and one green) keyboard and mouse connectors (also at the back of your computer). The other jacks in that set (of audio jacks) will be situated vertical to one another and on the left-most side at the back of your computer.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Computers & Internet
Wire house speakers
Two ways--first you can open up the unit and use the exsisting wires from the tvs internal speakers or goto radio shack and ask them for a audio jack splitter,you would than connect the wires from the speaker to the splitter then plug the jack into the audio input on the back of the tv.If your thinking youll get more sound from these speakers by doing this it wont work unless you have a surrond sound system.Only an amplifier can boost the output.
Feb 23, 2008 | Alpine CDA-9815 CD Player
Onkyo HT-S5300 Theater System Logo
73 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
