Jvc hd52g886 no sound
No sound
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
L would first make sure the speakers in the set did not get switched to OFF and also see if a DVD connected to one of the rear inputs has sound or not.
I know this set as saw one two weeks old first with no sound.
The entire audio circuit is on a single board (all of it) that is sandwiched between two other boards.
The first one was new so I Called Jvc and did some checks as they indicated---problem was on the audio board and since no individual parts for any board are sold--they told me to order the board--the board was on Factory backorder as a lot of them failed.
The customer did not want to wait so since a new set they exchanged it----Then they notified us to cancel the part order and dispose of the set in any way we wanted--they abandoned it to us.
I had our parts person keep the order going for the board..
l received the part about a month later, installed it (40 minutes) and had a 100% nearly brand new set that we later sold with a warranty--ours.
Most shops should be able to detect if the board is bad---you will have signal and audio coming in and if none at the output--bad board.
If I remember that board wholesales for around (at the time) a hundred dollars or a little more.
Hope this helps
SD TECH
Posted on Dec 12, 2012
Chromecast is not working with jvc hd52g886
Don,
The HDMI is best..but you need the standard HDMI cable. BUT this JVC is in the new Noah movie? Seriously, it wont handle Roku. The digital in function is strictly 480 p.
I think you will have to upgrade to a newer tv for this source
Mar 23, 2014 | JVC HD-52G886 52" Rear Projection HDTV
Picture adjustment for JVC HD52G886
Here is the manual http://www.retrevo.com/support/JVC-HD-52G886-TVs-manual/id/279ci059/t/2/, also may need to go into picture advance settings to do some calibrations.
Apr 02, 2012 | JVC HD-52G886 52" Rear Projection HDTV
Have a jvc hd rear proj, m#hd52g886 new lamp light on front keep flashing and no picture...Help
seagoblin28,
If you haven't replaced the lamp you should. If you have replaced the lamp you may just need to reset the unit. Go to my tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains where to get the lamp at the best price and how to replace it as well as links to additional problems.
Thanks for using Fix Ya and for the great rating.]
hardrocko
Feb 18, 2011 | JVC HD-52G886 52" Rear Projection HDTV
My hd52g886 has intermitten picture with sound
when the picture is out see if you can see the lamp light on in the back inside the tv. if its still on you might have a problem with the optical engine. if not try replacing the lamp part# tscl110u
Mar 27, 2010 | JVC HD-52G886 52" Rear Projection HDTV
My jvc-hd52g886 has a bad picture where black shld appers it is over lapped with red bloches
A projection tv that has color issues is usually due to bad ballast which is attached to color wheel which you should also look at to make sure the colors are not mixed together and wheel is not warped.
May 10, 2009 | JVC Televison & Video
Service man says light engine. how much? jvc model hd52g886
Whites are yellow can be a convergence or color balance problem, and lamp going out could also be a bad ballast board, black spots are usually light engine, could be a different fault on DMD board.
The fact is that when you get all this symptom together unavoidably you have a faulty light engine.
The light engine is the most expensive part to replace, its price for this model is always over $1600 ( I know, keep the heart tablets at hand).
Here is the part for your model: TS-COP7A-SAA-R
Mar 28, 2009 | Toshiba 46HM95 46" HDTV
Power board for jvc hd52g886
you can try removing the 3wire plug that runs to the ATSC tuner (1orange wire 2 white wires). This will tell you if the tuner is causing the shutdown. This is a common problem.
Apr 03, 2008 | JVC HD-52G886 52" Rear Projection HDTV
No power
the fuse is not the problem. one or all of the fans has stoped running and is sending a feed back to the micro stating there is a problem. this set is a sealed system and does require a qualified JVC athorized tech to repair.
Dec 11, 2007 | JVC HD-52G886 52" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
