Question about HP Officejet Pro L7590 All-in-One InkJet Printer
My new hp officejet pro L7590 printer tells me that "no scan options" are available. I bought this as a all-in-one printer. help, I need to scan
    Guru:
  • 731 Answers
Hi Kate,
This error occurs if HP drive services are not functioning properly, so try my solution
Solution
Follow these steps in the order presented to resolve the issue.
Step one: Verify that the Digital Imaging Monitor is ready
The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete.
If the Digital Imaging Monitor is in the system tray, proceed to Step two.
If the Digital Imaging Monitor does not appear in the system tray, follow these steps.
Windows 98, Me, and XP
1.Click Start , and then click Run .
2.In the Open text box, type msconfig .
3.Click OK .
4.In the System Configuration Utility window, click the Startup tab.
5.Search the list for HP Digital Imaging Monitor .
6.If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. 7.Proceed to step three to uninstall and reinstall the software.
8.Select the HP Digital Imaging Monitor check box.
9.Click Apply , and then click Close .
10.Click Yes to restart.
Windows Vista
1.Click Start .
2.In the Start Search text box, type msconfig and press Enter .
3.On the User Account Control window, click Continue . The System Configuration Utility window displays.
4.Click the Startup tab.
Step two: Populate the destination list
1.The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
2.Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
3.On the Windows desktop, double-click the HP Solution Center icon.
4.On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
5.If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
6.Click Settings .
7.Click Scan Settings and Preferences .
8.Click Scan to... Setup .
9.Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
10.If the Front Panel Destination List is empty, continue with this procedure.
11.If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
12.Click each program to include on the Scan To list.
13.Click the Add arrow.
14.Click OK .
15.Scan a document using the Scan To button on the front panel.
16.If the scan fails, try to scan using the HP Solution Center Scan button.
17.If the scan still fails, proceed to Step three to uninstall and reinstall the software.
Step three: Uninstall and reinstall the software
1.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
2.If the software installer does not automatically start, complete the following steps.
3.Click Start , and then click Run .
4.In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
5.Click OK .
6.On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
7.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
8.If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
9.Follow the onscreen instructions until the printer software is completely installed.
10.After successful installation, scan a document.
Step four: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Thanks
Riz
Posted on Jan 13, 2009
My hp L7590 Not scan in Pdf. It only scan in jpg format. I want to scan multiple pages in one file so pdf or other option like .doc is needed but it will not scan. Message display your device driver is not...
The PDF File Type Is Not an Option When Scanning from HP Solution Center for HP Multifunction Printers When Using Windows
This document pertains to all multifunction printers with HP Solution Center software connected to a Windows computer.
When you scan from HP Solution Center in Windows, the PDF file type is not available.
Oct 10, 2017 | HP Officejet Pro L7590 All-in-One InkJet...
Unable to input a destination for the Button Settings Tab
Even if the printer installs OK, the scanner is not allways recognized. Try to look for new hardware>scanners in Control Panel. It migth want the HP CD or the driver from www.HP,com. Or find a picture editing program and File>Import>HP officejet Pro L 7590 AIO- twain! That works!
Mar 05, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Scanner Issues with my HP officejet pro L7590
Dear Sir,
According to your problem it seems to be your
1.Your Printer USB cable Unpluged or faulty.check your printer USB cable is it connected to the PC or not. if it is correct go to next step
2.May your computer Printer driver uninstalled.You may need to reinstall printer driver and application once again by using printer driver CD. I think these steps helps to solve your problem.If you have any problem regarding this issue post a comment eith more information about the problem,we will glad to assist you.
good luck
Aug 26, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
I have a Hp Officjet Pro L7590 and want to scan a document and attach it to an E-mail. I have never used this machine before and need instruction. I have attempt to scan the doucment but have been...
Please click on the link below, this will take you to the HP site where you can find detailed instructions to various tasks that you can do with your officejet pro.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=21260&lc=en&dlc=en&cc=us&lang=en&product=3643612
To attach it to a email, just click on the attach button and point to this scanned file.
Jul 19, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Setup e-mail to send from printer when scan on HP L7590 Thank you Erik
Scan something. Save as jpg. Open email account. Add attachment. Choose above jpg. Send.
Fixya!
Chris (ziraffa)
Jan 14, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
The scanner will not work on the L7590
Found on HP page:
Open the following ports on the firewall utility by following the instructions provided by the manufacturer: UDP ports: 161, 427 and 137
TCP ports: 9220, 9500 and 9290
I allow these ports in my firewall (router firewall) and it works now.
Source:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00897551&jumpid=ot_recdoc/c00503569/en_us/c00897551/loc:3&custom_solutionid=rd_c00503569&lc=en&dlc=en&cc=us&product=3643612
Cheers
Marek
Nov 05, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
HP Officejet Pro L7590 All-in-One InkJet Printer Logo
372 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
