Question about GE DHDVH52GFWW Gas Dryer
Ge dryer, front loader, model dhdvh52. i need to figure out how to open up the cabinet and clean out the lint filter. i tried to loosen some screws, but they seem to be factory installed and are so
Oops, it put all that in my question. i am new at this internet info stuff. sorry.
  • mary la fond Dec 13, 2012
    i need to know how to access the lint "tunnel" inside the dryer. there is a tunnel that starts under the removable lint filter. this tunnel seems to lead under the dryer drum, toward the back of the dryer. i want to clean it out and need some help, either to snake it, or remove the outside panel and vacume it. i tried to remove the panel, but the screws that seem to hold it in place will not budge. any idea how to clean the lint tunnel?
jsrock516
  • 5911 Answers
SOURCE: dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Posted on Jul 28, 2007
  • 178 Answers
SOURCE: DCVH515 GE Gas Dryer
The sensor in the filter "PATH" is actually located past the screen. It measures the amount of air flow passing through the exhaust cavity going outside. My suggestion is to clean the airflow duct from right past the lint filter all the way out side. It is recommended that this be done once a year for optimal performance. If this doesn't work, let me know.
Posted on Mar 16, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Dryer - sensor problem
When I pull up the exploded view of your model, it does not show an individual moisture sensor, but is does show disconnect plug(s) for it. I can only assume that the sensor bars are an intrical part of one of the front bulkhead components. That all being said, the most common reason for your symptoms is when people use fabric softener sheets in the dryer, the sheets leave a waxy type coating on the silver sensor bars inside the drum, near the air inlet to the lint filter. If you clean those two (usually about 4 inch long x about 1/4 inch wide) metal bars off, they will be able to detect the moisture level of the clothing again, and your dryer will work on auto dry again.
Posted on Jan 24, 2009
  • 207 Answers
SOURCE: How to get the front panel off GE Profile Harmony
Here's a simple overview of what you have to do:
You actually don't remove the back sir, but that's okay, that's a common misconception for this model dryer. The proper way to disassemble this particular dryer is you start with the top. You have to start with the removal of the control panel, then the top of the dryer. What I would consider the top cover. Then you'll have to remove two plastic brackets. Then you have to remove the front. There's two aluminum brackets in each corner, remove those. Open the door and there'll be two more screws to remove on each side. You have to lift the front just a little and then pull towards you. I forgot to mention, before that part, you'll need to ensure you are disconnecting the electrical wiring. There's almost no chance of connecting the wrong ones even if you forget. GE made this part novice proof. Once you get the front removed, you'll see the lint/trap. There's a couple of screws on either side of the aluminum housing. Not much to it. Let me know if there's anything I can clarify further. Have fun!
Posted on Apr 23, 2009
SOURCE: Ge Adora Dryer, Worked great.
the dryer during its cycle squeaks and rumbles it sounds like some thing is not right.
Posted on Jan 03, 2010
Battery info, where to buy? cost?
Hi Betty...
I talk big about buying batteries (& stuff) on eBay...
but when my FAITHFUL iPhone 4S didn't need
a new one (per the genii (genus-es??) at the
APPLE-STORE...
I told then to put in a NEW ONE anyway...
Works better & lasts a lot longer.
Short story ... shorter
Only take your PHONE to a TRUSTED VENDOR.
(my opinion).
. Carnac the Magnificent
Mar 26, 2018 | Computers & Internet
Beeld maak nie oop vir my nie
SORRY but we have no idea what image does not work on what type equipement .
Mar 13, 2018 | Computers & Internet
Probl?me avec e-tec 150 hp 2006 Moteur calle ? 2000 trm . merci !
English please.
your welcome. no french here.
but tell what PC
oops you posted HP computers for a car.
sorry.
Aug 06, 2017 | Boating
Manual needed for Craftsman 10inch table saw, model 113.298841
go to sears website scroll all the way down to bottom click on order parts put in your info find your manual add to cart pay for part wait 3 weeks for doorbell to ring sign mans thing open box here's your new manual... sorry for being funny, but after reading a lot of this stuff you need a sense of humor...
May 15, 2017 | Craftsman Saws
Hostile creations new rogue is leaking air from the oops
Sorry, Not a model I have ever serviced.
Dec 28, 2011 | Cars & Trucks
1998 2500 dodge ram gauges jumpping after wife hooked up jumpper cables backwards i have replaiced a 140 amp fuse and the altanator and battery truck will run also the air bag light and odometer flash
You robably have a lot of stuff that is smoked. For your own safety and piece of mind, you should have this vehicle looked at by a professional. You do want these air bags to work if necessary, right?
I'm sorry ou have this problem. Please have a pro take a look see.
Thanks for your question at FixYa.com
Jan 15, 2010 | 1996 Dodge Ram 2500 Club Cab
Window won't roll up or down
The internet is a great place to get stuff like that cheap -(Google Search "Honda parts") -- Most Later model Hondas have power windows, so I bet it is hard to find -- Advance and AutoZone both have a section of replacement parts that are called "Oops" - (Red and white boxes, w/black letters) and they supply alot of the easily broken parts that are harder to find... - Lastly if no other choice, a Honda dealer would have it for sure (In the correct color as well - the "Oops" parts usually come only in black), but, Honda is usually really proud of their stuff - they either have it or can get it - That's what I'd recommend...Hope that helps...DD
Sep 13, 2009 | 1997 Honda Accord
GE DHDVH52GFWW Gas Dryer Logo
47 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
