Question about Panasonic KX-TGA550M Cordless Phone (KXTGA550M)
Resetting the phone without using the joystick?
Hi, I bought a used KX-TGA550 phone system. One of the handset (KX-TGA550) does not recognize the base (I somehow think that it may not even be registered to the base that I am having- though it shows a handset number on it, it may have been registered to another base). I am trying to deregister and register this handset again to get it to work. The problem is, the joystick on this handset does work when scrolling around, but not when pressing down ("OK"). I try to use direct commands to deregister and re-register, but the last step of de-registering still requires pressing the "OK". Is there a way of working around this? I just need to get the phone to connect to the base again, after that I think I can do without the "OK" button. Thank you very much!
5 Suggested Answers
SOURCE: DeRegistering a Damaged Cordless Phone????!!!!
If you are still looking for an answer on dereg of a handset, the manual says Menu - 0-0-2 then 3-3-5-OK then select the handset you want to cancel/deregister
Posted on Feb 17, 2008
SOURCE: DeRegistering a Damaged Cordless Phone???!!!!
Here is the procedure as given to me by Panasonic Tech Support.
To DEREGISTER, using the handset you want to register, push MENU.....002.......335...and hit ok.
Then press the handset number you want to deregister (1 through 4). Don't worry if the handset says there is no link to base. This is because you just unregistered it so there will be no link.
To REGISTER, press and hold the locator button on the base unit until the green LED starts blinking. Then take the handset unit and press MENU.......001 and hit ok. Your unit should now be registered.
Posted on Feb 16, 2009
SOURCE: Can't register Panasonic KX-TG6051 handset
Press (menu 00, reg) an press locator for 3 secons--- than press ok in you phone.
Posted on Sep 29, 2009
SOURCE: Can´t register handset . Panasonic KX-TG2620BX
I forgot dial lock, piease help me to open dial lock
Posted on Jul 05, 2010
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
Got a new set of handsets but the base doesn't recognize them...
Hi - Are you sure you have followed the following procedure exactly?
Have the correct base units for these handsets which are:
KX-TG1032, KX-TG1033,
KX-TG1034, KX-TG1035
Are using NiMH batteries
That have been charged for at least seven hours
Have followed this procedure:
Good Luck,
Mikeywaf
Mar 31, 2011 | Panasonic KX-TGA101S Cordless Handset
I bought a used handset for my Panasonic wireless phone system, and now it is still registered to the original base and won't communicate with my base unit. Handset is KX-TGA931T and base is KX-TG9331T. ...
They are correct - the phones are married to the original base and can only communicate with that unit since they share frequencies. Other handsets have different frequencies ans will not work
Sep 20, 2017 | Panasonic KXTGA931T Cordless Expansion...
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Aug 01, 2009 | Panasonic KX-TGA600B Cordless Expansion...
Need to clear out a used kx-tga270s handset
press function, initial setting, registration, deregistration, enter 335(deL) and then press Ok (right button on screen).
Once that is done press mute on the base unit and Ok on the hanset (right button on sreen)
Mar 28, 2009 | Panasonic KX TGA270S Cordless Expansion...
Dead handsets
i had the same problem with my KX-TGA650 and called repair out and they said it wasn't seating on the home base to charge, we'll see. i'm looking for a manual for this phone lost mine and cost prohibitive to order from panasonic. and download pdf is just too large.
go to website and it tells you that only a same model is able to be used with the base unit. hope this helps.
martha
angelml@sbcglobal.net
Jan 05, 2009 | Panasonic KX-TGA650 Cordless Expansion...
KX-TG4321 & KX-TG430B - Purchased separately, can't register handset to base
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps should help.... Resetting Handsets
Oct 22, 2008 | Panasonic KX-TG4321B Cordless Phone
Programming old handsets to a new base
Cancel the old handsets registration at the previous base unit if desired.
For additional handsets, you must register each of them at the new base unit. Only one handset can be registered at a time. A handset will be assigned anextension number at registration.
Make sure the base unit and the other handsets are not being used. Program the same way as the extra handset you bought.
Registration must be completed within 1 minute.
Jun 25, 2008 | Panasonic KX-TG2740 Cordless Phone
Panasonic KX-TGA550M Cordless Phone (KXTGA550M) Logo
42 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
