Question about Whirlpool Accubake RF362LXTT Electric Kitchen Range
Accubake whirlpool oven with glass top burners shut off and on
The burners turn on and get hot and then they shut off and on.
    Sergeant:
  • 462 Answers
Faulty switch most likely
Posted on Dec 12, 2012
jumptrout51
  • 3361 Answers
SOURCE: have a whirlpool electric glass top stove
You must replace the burner switch for that burner.
Posted on Mar 08, 2009
SOURCE: F3 E4 Err
HI, i am wondering if you has some power outages? if you did, unplug your oven from the wall for 30 min and the computer will reset it self. It worked for me! hope this helped you.
Posted on Jul 19, 2008
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool Super Capacity 465 the oven/broiler does not come on.
More than likely a bad ignitor
Here is how to tell If the ignitor is glowing it should be VERY bright, if it is dim orange it is weak and bad.
Posted on Jan 08, 2009
rockitman187
  • 2559 Answers
SOURCE: I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Posted on Jan 13, 2009
  • 31 Answers
SOURCE: stove top works, display unit and oven does not
I would have to say that u need to remove the back painl and look for a ground wirer that is broken or burnt in half. make sur that u unplug the oven first.when u find the problem just replace the wirers
Posted on Feb 08, 2009
I have a whirlpool accubake wall unit oven Took out door to clean glass now I cannot put door back together
you have a couple of hinges you have to pull out at about 45 degrees then slide door down on them and shut door
May 05, 2016 | Whirlpool RBD245PRB 24-inch Double Wall...
When oven circulating fan is on there is a virbration. how do you locati the fan?
Fan is located in rear of stove or maybe a piece if foil paper for into blades
Jan 05, 2015 | Whirlpool Gold GY399LXUB 30" Slide-in...
Whirlpool accubake
Almost all electric stoves vent the oven through a hole in either the back right or rear burner. They can get very hot. I am surprised that your control panel is burned. It is only dangerous if you place a combustible over the burner. I have had some people do this and it has melted it. i haven'y heard of a fire from this but it could happen if it was hot enough.
Jul 31, 2014 | Whirlpool Accubake RF362LXTT Electric...
Indesit oven keeps heating
Tappan gas range, TGF334BCWB. I can NOT stop the broiler burner from lighting. I have unplugged the 110 power and I light top burner with a striker. However when stove is plugged in to the power the broiler burner lights and continues to burn. The oven knob is turned OFF. The only way to stop the broiler is to unplug the power.
Mar 11, 2014 | Whirlpool Accubake SF362LXTS Kitchen Range
Cooktop light doesn't shut off
The temperature sensor located on the that element is failing. the sensor red light reminds you that the burner area is still hot. The light should go out once the glass top has cooled,but the failing sensor won't allow it. A slight rap with your hand on glass top over that burner once cool will put the light out. It more than likely continue until the unit is replaced.
Jan 20, 2013 | Whirlpool Accubake RF362LXTT Electric...
My oven and stove top isn't working at all. If I turn a burner on, the clock and oven light up, but the burner doesn't get hot and either does the oven. It's only 8 years old and isn't used often.
I was having this problem and it was because I had tripped the breaker. Reset the breaker (box Inside your home) and try that, However, there is probably an underlying electrical problem that should be fixed asap. I live in an older remodeled mobile home that isn't equipped to handle a lot of appliances going at the same time. Try to make sure you aren't pulling so much power when you use the stove, ex: TV, microwave, oven, stove, all running at the same time.
Nov 19, 2010 | Whirlpool Accubake RF362LXTT Electric...
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Whirlpool Accubake RF362LXTT Electric Kitchen Range Logo
265 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
