Question about Whirlpool RF378LXKS Electric Kitchen Range
Where are the fuses located on a whirlpool range rf378lxks
The oven lock doesn't work even though I have replaced the motor that actuates the lock I suspect a fuse has blown that provides power to the locking mechanism
    Sergeant:
  • 462 Answers
Usually located in the top of the back guard {where your knobs are'cover lifts up may be a couple screws or remove bottom drawer and check inside
Posted on Dec 12, 2012
SOURCE: Whirlpool cooktop,built in oven and range
not be funny, but I have the same problem-and/maufacturer
Wirlpool makes a pice of junk! and my range (3 years old) is going in the trash soon.
This range uses a computer and it has NO fan to cool the computqer look at you computer it has a fan.
Posted on Mar 03, 2009
  • 718 Answers
SOURCE: location of the fuses
GR448LXPQ
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GR448LXPQ
Click on your model number. Click on the diagrams in the left-hand side for the parts location.
A thermal fuse (9) is shown in the Chassis Diagram. You can check that and other diagrams for more.
Posted on Apr 11, 2009
SOURCE: Whirlpool Gold Accubake Range
try holding down the start button for 3 seconds
Posted on Nov 15, 2009
blueextc3221
  • 15935 Answers
SOURCE: E1 -F5- .. Locked - displays after cleaning the
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Posted on Oct 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: Super capacity 465 Whirlpool range . E1 F5 code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.ER%^
E-1 & F-5 come on after about a minute when attempting to use self cleaning. the micro switches work & the solenoid has been replaced. could it be the ERC ?
Oct 21, 2011 | Whirlpool GMC305PD Electric Single Oven
I have an Amana ARG7102W P1143347NW gas range that the oven will not light. All other functions work including the broiler and the oven ignitor glows brightly. I don't think it is getting gas to the...
most likely it will be the ignitor,even though it glows it doesn't mean the ignitor is good.it works on amps.a flat ignitor takes 3.2 amps to open the gas valve and a round ignitor takes 2.5 amps to open the valve,the only way to check it is to replace it and i would or if you have an amp meter with a clamp on it you just stick one of the wires going to the ignitor inside the clamp and it will tell you how many amps are coming out of the ignitor.buy a new ignitor and you should be fine.it calls for ignitor part number 31940001 and it's around 50 dollars.
Jun 12, 2011 | Amana Ovens
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
Feb 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Electric Cook top Coil
there may be 2 screws on the rear/behind of the cooker top or on the front underneath the top when top oven door is open.
Sep 30, 2009 | Hotpoint RGB745 Gas Kitchen Range
Oven Not Working
see if your broiler works if it does replace the bootom ignighter even though it glowes does not mean its working right it has to pull a ceartain amount of amps for the safty valve to open if the broiler doesnt light then the safty valve needs replacing and reply for futher info
Aug 16, 2008 | Whirlpool GS460 Gas Kitchen Range
Oven door lock
when in the cleaning mode the door lock will engage to make sure the heat does not get out. if it will not engage make sure there is nothing blocking the lock.
Aug 15, 2008 | KitchenAid KERC507 Electric Kitchen Range
Kenmore gas range trouble
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Nov 20, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Whirlpool RF378LXKS Electric Kitchen Range Logo
209 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
