Question about Consew 744R-30
I have a 744R-30. the spring in the safety clutch keeps popping out. i then have to pay to get it back in. what would be causing this to happen. where can i purchase springs for it.
Is there heavy duty springs that should be used
  • Consew Master
  • 7,365 Answers
Try contacting a consew dealer and ask them about a spring
Posted on Dec 12, 2012
2 Suggested Answers
SOURCE: Thread won't stay in discs and under tension spring
On the first set of spring loaded tensioner plates there is a small bar that comes out straight at you. Bring the thread over this bar before heading down to the next catch. Also make sure you do not have dirt in between the plates. The only other possibility is the tension release is easing the thread tension while sewing. (like your knee hits the foot lift or the whole foot lift is too tightly assembled
good luck
Posted on Jun 28, 2008
The looper safety cover wont close thus machine wont sew
if there is a spring in it, you may have to have the spring check or replaced
May 07, 2016 | Sewing Machines
My machine keeps going out and will not make a stitch when I reset the clutch. How can I reset it if this happens?
if you took the machine to have the clutch problem fixed and there is still a clutch problem, I suggest taking it back to them and seeing what was actually done, if anything...
Jan 24, 2016 | Sewing Machines
How do i re-install the needleplate on my singer model 30215? I cannot get it to stay down on the 2 reference pins. It keeps poping up. Thank you!
The pins are springs to pull the plate down. Keep the plate flat. Go at an angle and push down on one of the springs and slide under the lip. Do the other side while moving the plate so the plate is aligned. With the springs pulling down it won't pop out.
Oct 25, 2014 | Sewing Machines
Juki LU-562 I heard a clunck and the bottom walking foot doesn't work right .
Hello, I have a different model Juki but it sounds to me that your safety clutch has been tripped. The safety clutch functions when an excessive load is applied to the hook or the other components during sewing. At this time, the hook will not rotate even if turning the handwheel. When the safety clutch has functioned, remove the cause and reset the safety clutch by pressing and holding the push button on the top surface of the machine bed, while strongly turning the handwheel in the reverse direction of rotation. The resetting procedure is completed when the handwheel clicks.
Jan 07, 2014 | Juki Sewing Machines
Singer quantum xl-600 bobbin case spinning
sounds to me like you need a professional cleaning and timing adjustment.
Jul 09, 2012 | Singer Quantum XL-6000 Computerized Sewing...
My bobbin keeps popping out. There is a small hole under the bobbin casing. I pulled what appeared to be a wick out of there. It was frayed on the end and I thought it was part of my tension problem. Is...
Hi, the wick will not interfere with your tension, it is there to oil the hook shaft.
If you e-mail me at dupina@mweb.co.za i will send you the instructions and pictures on the bobbin case settings. Take special note of the retaining bracket, plate spring position and the Reverse rotation stopper. It sometimes happens that the reverse rotation stopper bends upwards, allowing the bobbin case to move underneath it. Press it slightly down to prevent this.
Aug 25, 2011 | Singer Touch Sew 7462 Mechanical Sewing...
"check top thread" warning, but top thread is threaded correctly
The upper thread sensor may be bad or need cleaning off but this doesn't happen very often. What does happen is that the thread regulating spring (the spring that the thread goes through just before going up to the take up lever) has come out of a small grooved piece it fits through. By taking the side cover off you should be able to see this and possibly be able to pop it back in. A tiny amount of super glue can keep it from happening again.
Nov 07, 2008 | Bernina Artista 180
Kenmore 385 sewing machine gets stuck in reverse
Make sure that your machine is set to sew forward. The reverse button on your machine should have a spring loaded return. If the spring is in place, and doesn't appear stretched, try a drop (just a drop) of sewing machine oil. Please use sewing machine oil. Not WD-40, or any other household oil. If the machine hasn't been serviced in a while, or used alot recently, they knob may need to be "reminded" that its supposed to go in and out. :) After applying the oil, push the knob in and pop it back out like you have been. If nothing else is wrong, it should loosen up and move freely.
Nov 24, 2007 | Sewing Machines
Consew 744R-30 Logo
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
