Question about Panasonic CT-32G11 32" TV
Panasonic 1996 CT-32G11U. It won't turn on, it makes a click noise and nothing happens. It's not a fuse, I checked.
  • 1 more comment
  • hollyl103 Jan 13, 2009
    Can you be a little more specific? ie. where is it and what does it look like?
  • scarmade Mar 04, 2009
    On a Panasonic Tau 36" CRT I have the same problem...Red light on whin i hit power I get a click and a thrum and no picture or audio...not the fuse, also checked.
  • patrickg450 May 11, 2010
    I installed a new nte2353/bu2508 and it did not work. Still hear the "click" but never powers up, any other ideas?
  • 346 Answers
Check the horizontal output transistor
Posted on Jan 13, 2009
  • cyriacus joseph Jan 14, 2009
    it is black and has 3 pins. it is mounted on a heat sink which is a metal plate. on the transistor may be written 2sd1556 or bu2508
    please refer to a qualified tv repair personel to do repairs
Where is the fuse on a Panasonic CT-32HC43. It just won;t turn on. It was working great and then nothing.
The fuse is located on the power supply board. It looks like a small glass tube with metal caps at both ends like the ones in the image below on the board next to it you will see a small marking that says the specifications of the fuse. Ex: 10A(Read 10 Amperes), 120V. The replacement you are gonna purchase should be of the same specifications. Make sure you unplug the tv from the power supply before replacing it so that you will avoid the risk of electric shock.
A positive rating for the advice provided will be highly appreciated and I will be glad to assist you further if you need more help.
Mar 29, 2010 | Panasonic CT-36HL43 36" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Panasonic CT-32g19j
check The B+ of your tv. If no b+ Check the input AC voltage. If Ac i/p are ok but no B+ Volt maybe your IC in power supply has problem.
Jun 01, 2009 | Panasonic CT-32SL14 32" TV
Tv shuts off tv/video doesnt work
that is a indication that a fault is about to occur, dont force that tv take it to a technician before it switches off completely, a power supply is supposed to be checked.
Mar 26, 2009 | Panasonic CT-36SL13 32" TV
TV will not turn on, it makes a click and nothing happens?
repar is
replace stk 730-020 i have them in stock
replace c809 capasitor value is 22uf at63v not in stock
replace location f801 t4a not instock
Jan 13, 2009 | Panasonic CT-32G11 32" TV
Panasonic CT 36HL42CF
same trouble ,the tree pronged square chip that you mension which is called horizontal transistor is busted again. try to check the plyback of your tv .maybe that parts have a problem.
Sep 29, 2008 | Panasonic CT-36HL43 36" TV
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
My tv dose not turn on
i have a ct-36hl43 it was ac fuse gma 6.3 amp its on the panasonic web site under parts cost a dollar randy vincent
Dec 29, 2007 | Panasonic CT-36HL43 36" TV
CT-32HL42 Panasonic will not turn on
These sets have a number of problems like yours which are associated with bad solder connections or cold solder joints. On this set one pin on the the start-up relay is usually open or intermittent The solution is to resolder connections on main p.c board. and especially on the vertical output IC. Also change the caps in the vertical section to avoid future problems. Scrivitron.
Jul 06, 2007 | Panasonic CT-27G13 TV
Televison & Video Logo
280 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
