Question about Emerson IC172 Clock Radio
Emerson ic172 keeps saying ipod
When I push power it always says "ipod" - there is no ipod connected. It used to work fine, suddenly stopped. Cannot get radio back on. alarms - even in the "radio" position present same error.
3 Suggested Answers
SOURCE: Time Display
A-ha! Those manuals sure do come in handy sometimes. I found the solution. In addition to functioning as a snooze button for delaying the alarm, the snooze button is also a brightness button for the time. If you press snooze one time it changes the time brightness from bright to dim, press it again and it goes from dim to motion sensitive only, press it again and it returns to bright.
I just tried this and resolved my problem. I hope it helps you as well.
Enjoy!
Posted on Oct 13, 2008
  • 814 Answers
SOURCE: My Emerson IC172 Clock Radio won't recognize iPod
For this type of problem you will need to talk to Emerson Customer Support. They will know if the functions you want will be available to you with the operation of the Clock/Radio and your iPod. The telephone number for the Emerson customer support is 1-800-909-1240. You can call them during the hours of 8am-4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information help you solve your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 15, 2009
Tip
How do I make my iPod always Sync my Photos
<p>If you have an iPod capable of storing photos, you probably want to keep the images. To ensure that your photos are always sync your iPod, your synchronization settings in iTunes. If you choose to have your iPod to sync automatically or manually, your preferences under "Photos" tab to sync photos from a folder or program. When you set these preferences, iTunes will remember them and sync your iPod the same way you connect to your computer. <br /> <p><br /> <p>1. Connect your iPod to your computer using the data cable that came with it. <br /> <p><br /> <p>2. Open iTunes if it does not open automatically. Click the name of your iPod under "Devices" in the left pane. <br /> <p><br /> <p>3. Click on "Photos" above the central panel of iTunes. <br /> <p><br /> <p>4. Check the box next to "Sync Photos." Select a program or a folder with the photos you want to sync from the drop-down menu. <br /> <p><br /> <p>5. Choose to sync all photos and albums or just selections. If you choose the latter, make your selections by checking the boxes next to the folders to sync. You can also choose to automatically include certain events, or events such as the latest in recent months. <br /> <p><br /> <p>6. Click Apply. Now, when you sync your iPod, it will always sync your photos. <br />
on Aug 05, 2011 | Computers & Internet
Koolertron Mazda 3 ipod connection problems
common problem cause by the ipod screen turning off (going to sleep).
I bet it keeps going if you keep it active (awake).
No cheap fix sorry.
Apr 16, 2017 | Car Audio & Video
My iPod is not recognized by Windows (XP SP3). The message says that "the USB device attached has malfunctioned" the troubleshooter says no driver is present. I have uninstall the mass storge...
Welcome to Fixya. The "the USB device attached has malfunctioned" is a common issue of a usb device that is connected to the computer. If you can still use the ipod properly it seems that there is something that has been detect by windows that is malfunctioning on the iPod when you connect it. There are only 3 possible reasons. First is the cable that you are using and the other one is the port on the ipod where you connect the usb cable and the 3rd is the motherboard needs to be rebooted. You can try to change the usb cable or try to use the steps below and see if you will encounter the same error.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power. First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices! So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
If you are using a laptop you need to remove the battery to drain the power on the motherboard. Please let me know what happen so that we can continue troubleshooting.
If you have questions please let me know. Thanks
Sep 23, 2011 | Apple iPod MA446LL/A MP3 Player
Is says connect to power but it wont charge or read when i connect it
it depends on what you are using to charge it with.
if you are charging it on the computer make sure that the plug that goes into the computer is in the right location and the plug that goes into your ipod is not in backwards.
if you are using a stero and it is not charging try to push the ipod in all the way and if that doesn't work then use something to push your iPod forward. or just see if your stero is working correctly. if not try a wall charger or a car charger. those usually ALWAYS work.
Jul 14, 2010 | Apple iPod touch
Ipod connecter comes out when i take ipod out of docking station
If your willing to fork out for a new iPod dock then that seems like the best option for you, If its not connecting properly and its obviously broken then unless your really good with a soldering iron and a screwdriver its had it.
Mar 16, 2009 | Emerson Docking Station for Apple iPod
Mar 11, 2009 | Emerson Smartset Clock Radio
Time Display
Enjoy!
Sep 01, 2008 | Emerson Smartset Clock Radio
Harman Kardon Go + Play Portable Speaker Keeps Shutting Off
I just had this exact problem. I'm using an ipod mini. I solved it by docking the ipod firmly at the angle
the dock is at and have the ipod at an angle, not flat. I put the plastic and rubber adapter for the mini as instructed and also placed the rubber adapter for the nano upside down to keep
the ipod propped at an angle. (Also can use something similar to keep ipod propped up at an angle)
Took a while when I first used to figure out how the dock worked. The dock is a little weird how it is hinged to go from an angle to flat. Nothing in the instructions about this. By putting the ipod flat it would still have a connection to charge and play but the power shuts off every 10 minutes. I spent a whole night having it shut off every 10 minutes. This drives me crazy when systems have features like that which always seems to cause more problems (just my humble opinion)
By having the ipod at an angle I'm currently just now having it run an hour and 20 minutes and counting with no shut offs,(fingers crossed) but so far so good.
Saw on the internet that if the ipod is not connected firmly the system has an auto shut down. I think the ipod's weight propped at an angle keeps the connection firm. Also some said they want to see the ipod display, there you go!!!! This seems to be working so far for me, may be worth a try...I was about to return mine but I love the sound so I'm keeping mine now!!!! Works fine. Happy camper again.
Please reply if this works for anyone it worked for me.
Jun 30, 2008 | Harman Kardon Go + Play Portable Speaker...
Emerson IC172 Clock Radio Logo
15 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
