Question about Samsung S22a100n 21.5-Inch Class LED Monitor - Black
Samsung monitor connected to macbook stuck is power save mode
Samsung monitor is stuck in power save mode. The monitor is attached to a MacBook Pro 2012, and had worked just fine - until last week. The monitor had not been connected to the laptop for a period of time, and when it was reconnected and not it's stuck in power save. Suggestions? Solutions? Thanks for help.
  • Binques Dec 12, 2012
    that should read "when it was reconnected it stayed stuck in power save."
  • 1,591 Answers
Make sure the mac is detecting the monitor. If there is an interconnection cable, make sure it's OK. Try hooking the monitor to another computer. If it works on another system, then the problem is with the mac, and not the monitor.
If the monitor does NOT work on another computer, then there's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Posted on Dec 12, 2012
  • 1684 Answers
SOURCE: samsung 740n not working
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jun 20, 2009
mdsaeed67
  • 849 Answers
SOURCE: Samsung 2232bw monitor
this shows the internal circut problem, need to consult a technician
Posted on Nov 07, 2008
  • 4 Answers
SOURCE: Samsung syncmaster 2253BW blurry/out of focus HELP!
cables wont make a difference, are you sure your display settings are set to 1680 x 1050? i have had problems when it is set to 1600 x 1000 and i had to reinstall the video card drivers.
Posted on Jan 09, 2009
  • 1684 Answers
SOURCE: Samsung SyncMaster 710N Monitor SLEEP MODE
The monitor is not going to sleep the power supply board is shutting down. If you can solder you should be able to repair the monitor yourself. The problem is caused by blown capacitors on the power board. Go to our web site at : www.ccl-la.com/badcaps.htm We have pictures of what to look for. Open your monitor and look at the power supply board for any blown capacitors, replace all that you find. The replacement parts can be ordered from several places on the internet or we can supply them for you. The replacement parts will need to be high temp and will be marked 105c. The values you need to get will be marked on the sides of the ones you take out but will be something like 220uf, 470uf, or 1000uf etc. and then a voltage rating. When you install the new ones be sure to insert them with the polarity stripe going the same direction as the old ones come out. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions just let us know
I hope this helps if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Oct 24, 2009
  • 121 Answers
SOURCE: i have the syncmaster 20wm samsung monitor. I
try pushing the input button or checking the cables
Posted on Dec 02, 2009
How to set up and connect to macbook
find the jack on side of MacBook- look for same jack on tv- get cord and plug it in- tv to pc mode and mac should send signal to tv
Sep 02, 2014 | Samsung SD390 Series S27D390H Black High...
HELP! bought a BX2450 Samsung monitor and it`s not showing full resolution, i need a driver for my macbook pro 13` (mid 2010) anyone????
I have a very strong suspicion that you are connecting your Macbook Pro to the VGA input on the monitor instead of the HDMI.
Your Macbook Pro uses the Mini Displayport connection type. Are you using a Mini Displayport to HDMI adapter? If not, purchase one and that will resolve your issue.
If you are already using a Mini Displayport to HDMI adapter, make sure your resolution is set to the maximum (1920x1080 according to Samsung's website) in Apple Menu > System Preferences > Displays > Display.
If available, select the 'Best for Display' option which should automatically set the maximum resolution for the display. If not, select 'Scaled' and choose 1920x1080.
Sep 04, 2013 | Samsung BX2450 LCD Monitor
Monitor rotation from MacBook Pro
Go to system preferences > displays, then there's an option to rotate the display. You'll also need the corresponding cable to connect it. Enjoy the mac!
Dec 11, 2012 | Samsung SyncMaster 2493HM Monitor
How can i connect the macbook pro into an lcd projector, which adapter should i use....?
what are your options on the projector side?
Your Mac comes with a DVI (Digital Visual Interface) port.
Attach the DVI to VGA adapter to the VGA connector of the external monitor.
depending on the external monitor/projector, you may need different adapters.
Sep 11, 2010 | Apple MacBook Pro Notebook
I just connected my MacBook Pro to my Samsung 46" HD TV and the only thing it shows is the standard galaxy image that is shown at the start up phase. The strange thing is, the galaxy background is not...
What is happening is the Samsung TV is acting as a second monitor. You need to go to system preferences and then displays there will be a check box indicating video mirroring activate that and when that is activated what you will see is what is on your macbook. Hope this helps.
Jun 12, 2010 | Apple 15.4 MacBook Pro Notebook Computer ...
Connecting LE26R8 to MacBook Pro
Hi.
LE26R8 its a Samsung LCD TV.
You can Connect a LCD TV to MacBook Pro.
You need a mini dvi to dvi or mini dvi to vga depending on your monitor. You also need a cable to get the sound to the tv from the macbook (from headphone output specifically)
Also Watch this video its a Tutorial to How Connect a LCD TV to MacBook Pro.
The Video:
(do not delete)
Good Luck.
Nov 03, 2009 | Samsung Audio Players & Recorders
I have just hooked up an external monitor (LG Flatron) to my macbook--no problem with web pages, but I am unable to see my desktop or any word files. When I boot up, it says analog in the upper right...
  1. When you connect an external monitor to your MacBook (or PowerBook, for that matter), you can combine your MacBook's LCD and your external monitor to create one big monitor. That means when your mouse pointer goes off the edge of one, it will appear on the other. Open the Displays Preference Pane to configure the resolution and orientation of the two monitors. This type of configuration works well when you want to keep your main work on your larger external display, but still keep things like IM, iTunes, and email constantly visible on the smaller laptop LCD.
  2. Some windows act like they don't want to be dragged on to your external monitor. If a windows is being stubborn, try dragging it up to the menu bar, and keep dragging, even if stays stuck below the menu bar. Sometimes once you have dragged it far enough that it has room to render the entire window, it will jump to the other monitor (Terminal used to have this problem, but Apple fixed it some time ago). If that doesn't work, try dragging it from a corner of your monitor. My Adium contact list doesn't seem to want to live on my external monitor, but I can coerce it up there by dragging up from either corner.
  3. When your laptop is open, you can't switch to using the full resolution of an external monitor. I have no idea why, but it's a fact of life for MacBook users. You can use both displays in "extended" mode, or you can mirror your MacBook's display (which most likely doesn't use the full resolution of your external monitor), but you can't switch to using only the external monitor. Very strange.
  4. If you close your laptop, you can actually get the full resolution of your external display. Put your MacBook to sleep, connect your external display and an external monitor, and wake the computer up by pressing any key. You will have full use of your external display while your laptop is closed.
  5. If you really want to have your MacBook open while only using an external display, after following the procedure above, you can open your MacBook, and it's screen will remain off, which means you can still use the MacBook's keyboard and trackpad. Why you can't get into this mode using F7, I have no idea. This is a good technique for allowing some heat to dissipate while still using an external display so the lid of your MacBook doesn't melt or warp.
  6. You can boot your computer using just an external display. Just connect your external display, open the lid, hit the power button, and close the lid again immediately.
  7. In order to output only to an external monitor, you have to have the power cable connected. I tried for several minutes yesterday to get my MacBook to wake up with an external keyboard and monitor before unpacking my AC adapter from my backpack, and it wouldn't work. It took me a while to make the connection (no pun intended), but I eventually discovered that with the power cable attached, everything works as expected.
Aug 05, 2009 | Apple Refurbished MacBook 2.4GHz Intel...
?have 17 inch macbook pro and 24 inch apple monitor, also apple wireless mouse and keyboard. Every once in a while the mouse and keyboard lose connection but the trackpad works with the monitor along with...
If you have "good batteries" installed in the mouse and keyboard and you still have the problem- the best way is to remove the devices via the System Preference panel in your MacBook and then re-install them again. It is important that you remove them first as the system may revert to the previous connection. Good luck!
Apr 29, 2009 | Apple Wireless Mighty Mouse
Samsung S22a100n 21.5-Inch Class LED Monitor - Black Logo
94 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
