Question about Graco Trekko 3-Wheel Stroller
Removing the arm bar from the graco trekko
How do i remove the arm bar completely I can only get one side in and out..
3 Suggested Answers
Fame_Guru
  • 483 Answers
SOURCE: I want to remove the headrest on the graco nautilus
You've gotta step by step guide with pics :
http://www.car-seat.org/showthread.php?p=307531
Thanks,
Posted on Mar 27, 2009
ozark333
  • 396 Answers
SOURCE: shaking wheel on graco trekko
I am assuming you have lubed the wheel with a silicone based spray lube.
Is it wobbling with the wheel in the locked position? Th only reason a wheel can wobble is if the axle and the actual wheel have too much play. A thin shim washer may tighten the axle to wheel spacing. Most hardwar stores will have thin washers. Give it a try. Your manual made no reference to wheel maintanance so if you purchased it new I would call Graco and complain. If used, try to eliminate the problem. If you need it here is your manual.
Graco Trekko Manual
Posted on Apr 30, 2012
How do you remove links from my watch band DKNY?
Instructions
    • 1 Determine the amount of links that need to be removed for the watch to fit on your arm correctly.
    • 2 Find the tiny holes on each link. Most DKNY link wristwatches, such as the 3107 model, have holes at the links near the clasp.
    • 3 Using the screwdriver, gently push the pin holding the link bar on the first link you want to remove. The link bar should come out on the other side.
    • 4 Take the pliers and completely remove the link bar from the band. The link band will still be attached to the clasp. Remove the link with the pliers. Repeat Steps 1 through 4 for each additional link you want to remove.
    • 5 Gather the watch band and and bring the two sides back together. Join the link bar and the clasp together and, using the screwdriver, press the link bar back into the hole completely.
How to Take the Links off DKNY Watch eHow
Aug 27, 2014 | Watches
How do i remove yhe lower control arm on a 2008 Nissan Frontier 3.0l turbo diesel?
You need to loosen the torsion bar adjusting bolts until all the tension is removed, remember to mark a reference point from bar to frame so you can get close to the correct riding height after reassembly. Can't tell if you split the ball joint from the knuckle from your explanation but a couple of good solid whacks to the lower knuckle will unlock it. Mark & remove the control arm bushing bolts and use a pry bar to push out arm @ bushings.
Aug 19, 2014 | 2006 Nissan Frontier
Rear suspension sway axle side
could be rear wheel bearings - they come as a complete assy with brake hub - approx $45 each side - 1 hour per side for replacement. Also replace the rear sway bar links $8 for a set - other than that you could have a bent wheel and or loose rear control arm bolts - remove the rear wheels and check all mounting bolts - I had this problem and my rear end felt like it was shimming when I went around corners - 5 minute fix
Oct 27, 2013 | 2000 Ford Focus
Looking for a tray to purchase for graco trekko? What brands are compatible?
Hi Kaylee
We would recommend you contact Graco for assistance.
Contact Graco
Sep 03, 2013 | Baby Gear
Shaking wheel on graco trekko
Graco Trekko Manual
Apr 26, 2012 | Graco Trekko 3-Wheel Stroller
CV axle shaft replacement
Instructions
1.Set the vehicle transmission in "Park" and engage the emergency brake before attempting to remove the front right axle. Place wood blocks behind the rear wheels to prevent the vehicle from rolling and loosen the lug nuts one complete turn on the right front wheel with a tire tool.
2. .Lift the front passenger side of the vehicle with a floor jack and slide a jack stand under the vehicle frame near the wheel. Lower the floor jack so the vehicle is sitting on the jack stand and move the floor jack out of the way.
3. Remove the lug nuts with the tire tool and set the front passenger wheel out of the way. Take the cap off the end of the axle with a standard screwdriver and remove the cotter pin from the axle with a pair of pliers.
  • 4. Slide the crown washer off the axle and loosen the axle nut with a crescent wrench. Unfasten the top and bottom bolts that secure the brake caliper to the rotor with a socket wrench and slide the bolts out of the caliper.
  • 5. Lift the brake caliper off the rotor and remove the brake pads from the caliper. Suspend the brake caliper from the vehicle frame with a wire hanger and take the rotor off the axle.
  • 6. Unfasten the thru-bolt on the vertical sway bar with a socket wrench and remove the bolt from the sway bar. Take the channel bolt out from between the sway bar and lower A-arm that the thru-bolt ran through, and loosen the bolts that secure the front right axle to the center flange with a socket wrench and breaker bar. You may need to loosen the bolts with the breaker bar before removing them with the socket wrench.
  • 7. Slide the front right axle off the center flange and let it rest on the A-arm. Lift the front passenger side up with the floor jack to get enough room between the steering knuckle and A-arm and slide the axle out of the vehicle.
    Install in reverse order.
  • Mar 23, 2012 | 2006 Mazda 3
    How do I. Get the lower control arm off my 01 stratus
    SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS. MAKE VECHICLE SITTING ON LEVEL SOLID GROUND. REMOVE FRONT WHEELS , REMOVE HEAT SHIELD, IF EQUIPPED WITH 15 INCH WHEELS, REMOVE BALL JOINT CLAMP NUT, REMOVE SWAY BAR TO CONTROL ARM BOLTS, REMOVE STRUT CLEVIS FROM THE LOWER CONTROL ARM, REMOVE SWAY BAR TO CROSSMEMBER BOLTS LOOSEN THEM AND ROTATE THE SWAY BAR AWAY FROM THE CONTROL ARM, LOWER CONTROL ARM FROM STEERING KNUCKLE. REMOVE BOTH LOWER CONTROL ARM BOLTS. REMOVE CONTROL ARM. DURING INSTALLATION TORQUE LOWER CONTROL ARM BOLTS 120 FT LBS. CONTROL ARM STEERING KNUCLE TORQUE NUT 70 FT LBS.TORQUE SWAY BAR BOLTS 21 FT LBS.
    May 23, 2011 | Dodge Stratus Cars & Trucks
    One of the back wheels needs to be replaced - how can I find a wheel and how much are they. Is it easy to repair?
    I also need to replace three wheels as they have rusted really bad any luck anyone on where you can get parts for a Graco Trekko three wheel stroller
    Feb 24, 2011 | Graco LeisureSport 7420 Jogger
    How do I change the front driver side axle assembly on a 2001 Dodge Stratus?
    first jack up side you will be working on and place jjackstand under the frame, next remove the wheel,to make it easier remove the caliper and tie away, dont remove the brake hose!, then remove the rotor it slides off you may need to tap backside with a hammer, next is to remove the bolt and nut from the lower balljoint, then use balljiont tool to saperate the lower control arm from spindle, you may need a pry bar to pull down on control arm to completly separte move spindle to side and let arm up, next remove the axle (cv) nut on the front, then use pry bar to pop out of trany, install new axle hold straight and slide into tray as far as you can then with nut on the axle a little tap to axle in to trany the rest of the way you will feel it go in and lock and then reverse direction to put back together, hope this helps.
    Sep 02, 2010 | 2001 Dodge Stratus
    Left turn signal won't go back to neutral after turn complete
    hi this could be due to either the bar that flicks that side of the indicator off has either worn or broken, or the plastic section in the indicator arm it self has worn or broken, have you have the steering wheel off recently?if not correctly fitted back this could do it to, you can try removing the steering wheel and checking this out the indicator arm is a complete unit, and to be honest is unwise to take it apart as there are springs and ball bearings that are very fiddly to re fit back, but you possibly could get a replacement from a breakers yard.....hope this helps
    Feb 26, 2010 | 1995 Buick Regal
    Graco Trekko 3-Wheel Stroller Logo
    328 people viewed this question
    Top Graco Baby Gear Experts
    Joyce Nokleby
    Douglas Dinnebeil
    Douglas Dinnebeil
    Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
