Question about HP Pavilion a1220n (A1220NED904AA) PC Desktop
Why is my hp pavilion a1220n product number ED904AA-ABA?
I had installed two 1 GB memory sticks in my tower along with the installed 512 MB memory sticks. When I try to turn on the tower, the front panel light won't light up. In the back of my tower, a green light flashes slow in the back part. Do that mean that I need to replace the power supply?
    Guru:
  • 571 Answers
Try removing the 512 MB memory to see if it does work with the 1GB stick only.
It's not the power supply that does have a problem. It has something with your memory stick.
Posted on Dec 12, 2012
melnavz
  • 1226 Answers
SOURCE: HP Desktop Pent 4 randomly shuts down and restarts on its own
That is a power failure, please try change the power supply..or test the voltage in the wall outlet if it rate 220 volts if not then power supply is the main causes. Sometimes the software's got conflict due to virus infections.
try to scan your computer with a potent antivirus maybe it help.
melnavz
Posted on Oct 23, 2008
  • 4088 Answers
SOURCE: Rebuilding HP Pavilion. Beep Code 1-3-3-1
It can't find any ram memory! Insert the memory and try again. Good luck!
Posted on Dec 24, 2009
luke4010
  • 35 Answers
SOURCE: Hp Pavilion a1120n will not power up.
Yes it needs a power supply. You can get a cheep one on eaby or get one off of the HP site
Hope this works,
Luke Wilcox
Posted on Dec 29, 2009
contratek
  • 83 Answers
SOURCE: Memory upgrade didn't work
sound like either the memory is incorrect or u may need to load the default settings in the BIOS
enter the BIOS / setup screen for the motherboard and see if the system shows the 2 gig installed
see the adding memory guide below and it will explain everything
Product Specs
Adding Memory Guide
see below for link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03886&lc=en&dlc=en&cc=us&product=3245050&lang=en
Posted on Feb 14, 2010
joecoolvette
  • 5660 Answers
SOURCE: Just bought 2 1GB PNY dual Chanel memory modules
HP Support > Pavilion a1600n desktop computer > Motherboard Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757531&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3245022
Scroll down the page to the illustration, and photo of the Pavilion a1600n motherboard.
On the motherboard illustration where it states DDR2 XMM1 (64 bit ,240-pin module), and DDR2 XMM2 (64 bit ,240-pin module), is where the two 1GB ram memory modules go.
On the motherboard photo, it is the two Blue in color ram memory slots.
The 512MB ram memory modules go into the Black ram memory slots.
[DDR2 XMM3, and DDR2 XMM4]
The Blue ram memory slots are one Channel. (Channel 1)
The Black ram memory slots are the second Channel.
(Channel 2)
You want to keep LIKE ram memory modules in the same Channel.
If you are having problems with the PNY ram memory modules, tell me what the manufacturer code is on them.
(Or if you bought them off of a website, see if you can copy and paste the link in a Comment. Believe upper right of your page.
FixYa is constantly undergoing changes to improve the website, is why I indicate that)
You need low density, unbuffered ram memory, DDR2 Sdram ram memory.
[DDR2 at either 533MegaHertz, or you can also use DDR2 at 667MHz.
PC2-4200 and PC2-5300 respectively ]
Don't try out any high performance ram memory is my recommendation, because the Voltage required by the ram memory, may not meet the factory default voltages that are preset in your computer.
[Factory Voltage default setting for ram memory for your motherboard, is set at 1.8 Volts.
Some high performance DDR2 ram memory requires 2.0 Volts, 2.1 Volts, or even higher ]
Posted on Jun 30, 2010
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Paulji786,
Below are the specs you requested on these 2 systems.
Optiplex GX280
Memory
Type
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
F0000h
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
Latest bios for HP Media Center PC?
sad how, how fixya AI guessing wrong??? pathetic, mess....
wow a very old media center, gen 2 of 14 or so.
HP does not support this quote
HP Media Center m1070n Desktop PC,its RETIRED now
https://support.hp.com/us-en/retired-products
The BIOS does not do that!
what HP, it has full name and model.
the MMC controls this, and is very strict. (mem-managment controller)
the memory you are buying is no good. for YOUR PC.
this is so very common
and worse every year,
ever heard of Crucial or Kingston memory
they can fit up memory for you, it very complex.
not just DMM1, 2,3, but speed, min.
density rules.
chip count rules
chip voltage, 1.3. 1.5 or both or?
Total memory max allowed and PER SOCKET !
and even number of chips per side of stick , rule.
that worst was intel i5 old processors.
those are facts, and only the exact motherboard you have a
and what processor is there, (and if mmc is external to processor that)
matter.
? this?
M1070n
finding data on such and old box.
is not easy but google can dig up bits.
why not ask Kingston? for help,.
key facts are, (besides old)
Intel Pentium 4 520 / 2.8 GHz
Intel 915P Express (my guess, mmc is inside here)
oops
  • 512 MB / 4 GB (max)
  • Memory Speed 400 MHz
  • Memory Specification Compliance
    PC3200
  • Features
    unbuffered
  • Configuration Features
    2 x 256 MB
  • Technology
    DDR SDRAM
  • Installed Size
    512 MB
  • Data Integrity Check
    non-ECC
  • 4 GB
  • Form Factor
    DIMM 184-pin
looks like 1GB max per slot , 1 to 4.
good luck finding SDRAM in 2017 that works.
why not find a newer box? (pc) say 2010 or newer.,
they will run better and can buy ram easy
vastly better.... even Goodwill has them for few bucks
or this.
or like this,
https://www.walmart.com/ip/Refurbished-HP-7800-Desktop-PC-with-Intel-Core-2-Duo-Processor-4GB-Memory-19-Monitor-250GB-Hard-Drive-and-Windows-10-Home/54997432
May 21, 2017 | HP Pavilion Media Center M1070n...
I have the HP Pavilion a1330n computer, I just installed 4G of memory (4 X1G) to replace my previous 1G (2 X 512). The memory specs are correct but every morning the computer has a black screen and I have...
NO OS stated, Blues screens you mean the BSOD with the halt? statement on screen? i bet yes. (with words on blue screen)
words matter.....
Bought new memory or old?
no, (to supposed) yes, to , back to beginning done wrong or luck bad.
so put back the old RAM, does that work.?
or use just 1 stick of old ram. ? 1 by 1.
then repeat, new ram 1by1,
see? one stick is bad, if it all ran perfectly before you touched ram.
buying RAM for such and old PC is not easy.
step1:
first ASK HP, you asked now at yahoo, why here, and not HP>?
but HP long long ago retired the A series.
per HP pages. here
personally I do go the used PC store and buy $20 PC vastly newer.
sure would, but lets follow the rules for yours, step by step
step 2, (1 was hp , no support)
next is to lean what Memory was uses and what the processor spec is on the same,
the mobo is 2005 era. (as old as) 12 years ago...
its not Intel, its Athlon 64 (S) 3800+ 2.4 GHz
if it was intel , the intel chip drives the memory with its MMC
its not.
ASUS made this mobo by HP contract.A8AE-LE
hp name is: AmberineM-GL6E
max mem
4 GB* (4 x 1 GB) requires the replacement of the installed 512 MB DIMMs
PC-3200 MB/sec , speed ( not slower !) faster ok.
184 pin, DDR SDRAM
Dual-channel memory architecture
4 x 184-pin DDR DIMM sockets support unbuffered non-ECC 4 GB 400/300 MHZ DDR memory modules
page 7 is sparse in your manual.
https://www.manualslib.com/manual/721818/Asus-A8ae-Le.html?page=7#manual
the Athalon 64 has an ON DIE mmc, memory controller
this sets the base limits of all possible memory.
the memory speed is not by FSB, speeds
simpler terms, the memory is always running at a set fraction of the CPU speed
this chip has the advantage for running , cleaner DDR signals.
that other FSB designs.
what that means , to the user more memory choices.
I see this maker selling memory , a top maker,
http://www.crucial.com/usa/en/compatible-upgrade-for/HP-Compaq/pavilion-a1330n-series
test the sticks all 1 by 1,,, one good way to test it is run fast games.
DDR stick density rules and numbers and types of memory pre stick and pre side can cause problems on old processors.
I could not find the Athalon 64 rules on this, AMD can tell you at there site but im too lazy to look it up..
best is to let Crucial or Kingston guy you , here. for SURE>
Jul 13, 2017 | HP Pavilion a1330n (EL466AA) PC Desktop
I want to increase the memory ram of my lap top: HP pavilion ze4910us What kind and how much memory can I install ?
You can upgrade, have a look at the specs;
Pavilion ze4910us Memory Specifications Standard Memory 512 MB (removable) Maximum Memory 1.0 GB Memory Expansion 2 sockets Memory Comments PC2100/2700 DDR SDRAM SODIMMs CPU Type 1.4GHz Intel Celeron M 330 Model Comments 400MHz FSB Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop, the HewlettPackard Pavilion ze4910us Laptop takes the PC2100/2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your HewlettPackard Pavilion ze4910us Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop.
Hope that helps.
Dec 15, 2010 | Computers & Internet
Install Ram upgrade for HP Laptop Pavilion
Maximum memory capacity is Up to 1 GB (1024 MB) SDRAM using 512-MB modules.
Mar 27, 2009 | Computers & Internet
What is the ram limit of HP Pavilion 061 DW234A-ABA A530N I have two sticks of kingston 512 in it right now but want to put in two sticks of 1 GB each. Can I? Nvidia 7800 GS OC with 500 watt power supply,...
From the HP specifications page for Pavillion A530N:
Memory type DDR Memory speed PC 3200/2700/2100/1600 Memory sockets Two DDR DIMMs (184-pin) Maximum HP/Compaq approved memory Two x 512 MB DDR-DIMMS, 1024 MB total (1 GB)
Mar 10, 2009 | ASUS Computers & Internet
Have a compaq presario sr2170nx....installed 1 gb memory but not showing up. swapped the memory sticks positions and restarted but still wont show up.
If you do not get the right memory for your computer it will not work. the memory you need is listed in the table below. And pay attention to the max amount of ram. Your system can only hold 2 gig and it comes with one gig installed
Component Attributes Memory Installed 1 GB Maximum allowed 2 GB (2 x 1 GB) Speed supported PC2-4200 MB/sec Type 240 pin, DDR2 SDRAM
Jan 14, 2009 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
My name is Siavosh Eskandari. I have a desk top PC Compaq presario Desktop with Intel celeron processor 2.7 HHz Model SR1010NX, Prod. # DW25AA-ABA,Serial # MXK4180P8Y with 256 MB PC 2100 DDR SDRAM. The...
the model SR1010NX can take upto 1gb max of ddr 1 ram and must be done a 2x 512 ddr 1 chips
Memory Component Attributes Memory Installed 256 MB (1 x 256) Maximum allowed 1 GB (2 x 512 MB) requires the replacement of the installed 256MB DIMM Speed supported PC2700 MB/sec (messages at PC2100 Type 184 pin, DDR1-333 SDRAM DIMM slots Two
Nov 28, 2008 | HP Computers & Internet
MEMORY UPGRADE
Sorry for the delay in my response.
Your computer will accept a maximum of 1 GB of memory. If both memory modules are the same brand and part number then it is possible that one of the sticks are bad.
Try each 512 MB memory stick in the first memory slot, without installing a second stick. This will troubleshoot to find out if one of the 512 memory sticks are bad. If both check out ok, then the problem is with the video adaptor.
Have you tried adjusting the refresh rate on the monitor as I described in my first response?
My final possible solution would be to upgrade the bios. Below is a link to the webpage for your computer system. You will find links for troubleshooting guides, driver and software downloads, product specifications, etc. If you click on driver downloads, then choose your operating system, you will be directed to a page that should provide the latest ROM (bios) update.
http://h10025.www1.hp.com/ewfrf/wc/product?product=93322&lc=en&cc=us&dlc=en&lang=en&cc=us
Jul 28, 2008 | Computers & Internet
HP Pavilion a1220n (A1220NED904AA) PC Desktop Logo
100 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
