Question about Whirlpool Heating & Cooling
Whirlpool ace124xr air conditioner will not heat
Cools but does not heat
  • 30 Answers
SOURCE: whirlpool ACE244XS air conditioner blows out cool air when on hea
Due to Defective Thermostate Switch Try to Replace, will be ok
Posted on Feb 01, 2009
  • 127 Answers
SOURCE: Air conditioner not cooling
This is a tell tale sign that your condenser coil on the rear of your upper unit is dirty. You need to get up on the roof and remove the shroud from the unit. Gently spray into the condenser with a water hose until the water that is coming out is clean. This is a good procedure to do once or twice a year to help the efficiency of your unit.
Hope this helps.
Jeff
Posted on Jul 04, 2009
erpaalai
  • 999 Answers
SOURCE: whirlpool window air conditioner 20000 btu's not cooling properly
It is possible the cover needs removed and the condenser coils are in need of a good cleaning. (the one in the back that is outside).This assuming the compressor is running and it has not developed a leak and lost the coolant charge. Eric
Posted on Aug 15, 2009
  • 232 Answers
SOURCE: "cool on " flashing..no heat or cool air blowing
when its flashing its in a 5 min delay mode if you wait 5 min and still flashing you may need a new stat. but give it a full 5 min.
Posted on Sep 20, 2009
  • 4736 Answers
SOURCE: Whirlpool air conditioner blows out
Fortunately, that's not smoke. It's a cool mist or fog, that is caused by high outside humidity and the coldness of the cooling coils. Generally, it's nothing to be concerned about. Just be sure that you keep the air intake filter clean and the the drain hole in the drain pan is not clogged.
I hope this was of help to you and thanks for choosing FixYa.
Posted on Jul 24, 2011
We have a mod. Ace124xr window unit unit when turned on just hmmms nothing else.
it probaly just has a bad capacitor. a very cheap part. it looks like a aluminun can with wires coming out the top, or sometimes it is flat.
Sep 14, 2014 | Heating & Cooling
Exhaust Heat
There is a kit for that. You can also import outside air instead of using cool air from the room. You can make or find "small kitchen pan" that covers the intake area on the back then add a collar for a 4" hose from a dryer and vent it outside making sure the air stays away from the exhaust air.
Link to part http://www.manualslib.com/manual/337967/Whirlpool-Acp102ps.html?page=4#manual
Apr 15, 2014 | Whirlpool ACP102PS Portable Air...
I have a whirlpool wall heat/ac unit, model ACE184XL0. All of a sudden, the heat quit working. Fan still blows, and AC still seems to work, although I can't tell if it's just pulling in cold outside air...
Dear it is a thermostat system. You can simply check it by setting temp at 30 then check either warm air is coming or cool air. at this time warm air should come. If warm air is not coming means there is a fault is realy in your pcb. It can be simply remove no need to worry.
Oct 14, 2013 | Whirlpool ACE244XS Air Conditioner
Whirlpool model WC260A-1A cannot find manual and central air conditioner will not turn on worked well 2 days ago.
Does the fan turn on when you have it set to cool? does the furnace still work? Does the fan auto, and on options still work?(for example when on its on, when auto, and neither the cool or heat functions should be running, the fan is off)? Basicly i'm asking your to test your thermostat right now.
Aug 04, 2013 | Whirlpool Central Ac Condenser-new...
I need help on how to activate heating mode in my 7wa4501q whirlpool 6th sense minisplit pleasee
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 13, 2011 | Heating & Cooling
Whirlpool window air conditioner 20000 btu's not cooling properly
Aug 15, 2009 | Whirlpool ACQ158XP Wall/Window Air...
A/c not cooling
it sounds the problem with the compresser.or may be ur compresser is getting heated quickly and stops working which stops cooling.
Dec 17, 2008 | Whirlpool ACE244XS Air Conditioner
Whirlpool ACE244XS air conditioner blows out cool air when on hea
Nov 18, 2008 | Whirlpool ACE244XS Air Conditioner
Heating & Cooling Logo
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
