Question about Dometic RM2652 Refrigerator
Can you tell me what refrigerant (gas) is in a dometic fridge RM6270
I am importing a caravan into Australia it is a 2003 model. Customs want to know
  • Dometic Master
  • 4,654 Answers
Ammonia, Thanks Sea Breeze
Posted on Dec 12, 2012
22yooper
  • 828 Answers
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
Posted on May 26, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Refrigerator not working on gas
There is some reason maybe not explained here. But I will help you if you want. Below is a simple test. The manual I need you to make sure if you have the RM2652 or another model to get the correct manual. That model has digital controls and that is controlled by a control board for switching from AC to DC to Propane. If the board will not switch then we need to look for that problem. Dometic, good refrigerate and great support group. Now here is a link to that model number problem solving PDF. With the manual we can work together to solve this. Thanks, Sea Breeze http://www.dometic.com/FileOrganizer/1-international/Operation%20&%20Installation%20Manuals/Refrigerators%20-%20Caravan%20-%20Motohomes-%20RV/English%20and%20Multilingual/RM2652-RM2852.pdf
Posted on Jun 16, 2009
  • 127 Answers
SOURCE: Info on replacing drain hose on dometic model 2652
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
Posted on Jul 03, 2009
  • 9 Answers
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
motor1258
  • 6674 Answers
SOURCE: my dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
Posted on Jun 03, 2010
Dometic fridge not working on 240 volts gas ok and 12 volt ok
The AC heater element is most likely open. Replace it and it will restore AC operation.
Sep 21, 2016 | Dometic Refrigerators
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Just bought camper, fridge lights show it is supposed to be operating. And pilot lights but no complressor kicks in. The area between the fridge and freezer gets warm, but there is no cooling in the...
Hi and welcome to FixYa I am Kelly. Locate the model number of the unit if possible and I will get you a manual. There must be battery power connected or the unit will always operate on gas.
Many other nice to know things in the manual....
Manual liink is here:
UK http://www.dometic.com/enuk/Europe/United-Kingdom/Customer-Center/Operation-Manuals/
^^ site also has US manuals, You have to select US under: Refrigerators - Caravan-Motorhomes-RV
Global by model number & product code
http://www.dometicmanuals.com/PROD/MASTERDometic.nsf?Opendatabase
If the manual does not help you respond here and I will assist you in troubleshooting.
Thanks for choosing FixYa,
Kelly
Jun 14, 2011 | Dometic Refrigerators
My dometic fridge will not turn on
May 14, 2010 | Dometic RM2852 Refrigerator
RM6270 in a touring caravan, over 5 yrs old. Worked fine until mid-Sept, when it ceased on 240V, 12V & gas still good. Any other sources of the problem possible, other than the 240V element (e.g. power...
Some of the Dometics have what was called the 'Dinosaur Board' which is a circuit card which controls the unit.
http://www.dinosaurelectronics.com/
Not sure if it applies to your exact model, but if there is a company who just makes replacement control boards for Dometic fridges, that is a big fat clue, in my book. Cheers.
Oct 21, 2009 | Dometic RM2652 Refrigerator
Dometic RM6270 Caravan Fridge.Hinges
you should be able to find any part you need
at
pplmotorhomes.com
they have always been able to help me in the past
Oct 14, 2009 | Refrigerators
Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Jul 26, 2009 | Dometic RM2193 Compact Refrigerator With...
May 26, 2008 | Dometic Refrigerators
Dometic RM2652 Refrigerator Logo
64 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
