Question about Panasonic Audio Players & Recorders
I wish to adapt speaker SB-AFC301 surround sound cluster to a USB to connect to a laptop pc.
Adapt to a USB
  • 84 Answers
SOURCE: Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Posted on Feb 11, 2008
SOURCE: Z-5500 speakers
hi i just purchase logitech z 5500 pl have problem in instalation and pl advice me how to connect wt my tv , I have connect the Z 5500 in Coax Chennel But No Sound effect frm tv when switch dvd to tv .
Posted on Sep 29, 2008
mdsaeed67
  • 849 Answers
SOURCE: CONNECTING SPEAKERS
you must have surround sound card/output from your computer to connect surround soud speakers.
if so, then put the right jack to right pin.
Posted on Oct 20, 2008
yooperbud
  • 8637 Answers
SOURCE: not getting sound out of speakers
Go into Control Panel and click on SOUNDS and when the Sound Properties window opens check to see if the speakers are set right.
Hope this helps. Bud
Posted on Jan 19, 2009
SOURCE: no sound from new speakers
advent computer spk. from old computer , won't work with new c.
Posted on Mar 10, 2009
How to change laptop connecter speaker
it is on-board u had to remove complete socket and plug the new socket
Oct 19, 2013 | Panasonic Center Speaker Sb-hc480 Home...
Vsx-815 sb. system
Check in your speaker setup menu. Sometimes you can select between using the surround back speaker jacks as "B" front speakers as well. You would have to tell the unit which one you want to use it as.
Feb 08, 2013 | Audio Players & Recorders
ONKYO TX-SR701 - Hi When using the speaker config I can get output from all speakers but the Surround back speaker R does not work. I do get sound from Surround back L. It's a bit confusing as the...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR701-Receivers-manual/id/365ag222/t/2/
7.1 would have Surround Back L and R.
6.1 would have just one back there (SB). It defaults to the Left output on the Pre-Outs if you ever go that route.
This being a 6.1 receiver it does not support two SB channels BUT you can configure those amp channels for a separate Zone supporting 2 speakers. Confused?
The manual shows a single SB speaker connected to the left side on Page 27. THAT would be consistent with a 6.1 configuration.
Jun 04, 2011 | Onkyo TX-SR701 Receiver
How do i connect my Creative T6160 speakers to my laptop.
Your speakers are 5.1, but your laptop has 2.0 audio output, which means that it is a simple stereo (left and right channel output). You will need to connect a USB sound card (such as the Creative X-Fi Surround 5.1) with 5.1 channel connectivity in order to connect your speakers.
Hope this helps.
May 24, 2011 | Computers & Internet
I have a Creative Inspire 5200 EAX 5.1 surround sound speaker system that I want to use with my Acer Aspire 5738 laptop. It works fine with my desktop but when I connect it to the laptop, two of the...
The laptop normally not support 5.1 home theater you purchase new external 5.1 sound card and it connect your USB port of laptop. Home theater connect through sound card
Apr 26, 2011 | Acer Aspire AS57386444 (LXPF702102) PC...
How do i connect to laptop? i can only hear 2 of 4!
If your laptop hasn't a 5.1 surround card you can't connect them in a true 5.1 surround system way. But if you have a stereo sound card and if you don't care about true multichannel and want just to hear sound from all the speakers you neet to connect the adapter that came along with your speaker set-just plug and match the colors from the speaker plugs with the adapter and buy a jack stereo to 2 rca cable and plug the rca connectors to the adapter and plug the stereo jack to you laptop.
Oct 17, 2009 | Logitech X-530 Computer Speakers
Hello i have a medion 5.1 active sound system and i am trying to install it to an acer 5335 laptop but for some reason it will not work. i am using the usb method can you give me some advise and help...
hello Paul,
I understand that you wish to connect an laptop computer that has a standard stereo out(2 channels), earphoe jack or adio out to an active stereo system that supports the dolby 5.1 multichannel souround sound.
That is where the problem starts.The active sound system has more input channels than the two stereo channels given by the laptop, so connecting them via adaptor (audio out from laptop, earphone-like, 3.5 mm' male' jack to red and black chinch plug,'male' version to stereo L(left) and R(right) channel in at the active system) may provide you with extra stereo sound enhancement(like any other amplifier would), but no real surround sound..
To solve this, you would need a stationary desktop PC with an extra surround soundcard
that has all the multi channel out in it, as there is no chance to upgrade your laptop with such devices I am sorry to tell you that you perform an impossible task to get surround sound from your laptop.
Sep 11, 2009 | Audio Players & Recorders
Spherex Xbox 5.1 Surround suound..USB does not work
If the xbox is not able to recognise the usb, it is most likely that the product is not compatible with the xbox i would look for an adapter which would take the usb connection to the xbox's analog connection, or if your speakers have a stero 2.5 connection then you can easily find an adapter to connect to the xbox's analog connection in the back, the analog connection is the red and white ports at the back!.
Feb 11, 2009 | Spherex Xbox 5.1 Surround Sound System...
PANASONIC SURROUND SOUND SB-WA3300
May be wrong number. SB-WA330 is name of speakers and search http://safemanuals.com/ to give you the right manual
Samuel
Aug 18, 2008 | Panasonic Home Theater System System
Possible broken speaker
You must determine if subwoofer amp or speaker are bad.Take the good surround speaker and move it to the bad side.If the good speaker does not produce audio the the amplifer is bad.If you use the good speaker in either surround output and it works then your speaker is bad.If you take the small speaker apart the panasonic part number is stamped on the magnet.Locate a service center that will order it for you.
Mar 13, 2008 | Panasonic SC-HT730 System
62 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
