Whirlpool washer W10280544C, basket/bin unattached. Help please!
My whirlpool cabrio has water trapped in the wash basket. Is this normal? Keep getting UL code and checked everything else.
I have the same issue. when I remove the wash basket from the tub the plastic parts all seem to have a lot of water trapped inside them. I am looking for a solution and may start my own question. not getting any fault code at all the washer runs as designed. but the dirty water trapped in the plastic top of and bottom of the wash basket is making the clean clothes smell like a dirty dish rag.
Sep 05, 2012 | Whirlpool WTW6400SW Cabrio Washer
Drum seems totally unattached in the washer machine?!?!
Welcome to FixYa
Based on your description I suspect the rear bearing or spider gear is toast. You are probably right, either the suspension shock absorbers are broke or the inner basket is separated from the spider gear often times.
Very common for these machines unfortunately. It isn't too bad if just shocks, but it is a very involved repair for the spider gear/inner basket.
**Unplug the unit from the wall before attempting any of these service tips...safety first**
You'll need to remove the lower access panel to investigate the shocks...these shown are the newer style but previous versions where all plastic, hence the broke much easier.
i.e.
and the rear panel to inspect the basket & spider gear attachment. Check for any signs of leakage or rust behind where the arrow indicates...the tub bearing.
If you think you're up to it I can help in whatever manner possible with those Frigidaire washers.
I'll watch for your reply. Good luck.
Regards,
Macmarkus :)
Apr 08, 2011 | Frigidaire GLTF2940ES Front Load Washer
What is the fresh and ready bin used for?
The fresh and ready bin is used for fruit. You can place various fruits in the tilt out bin and grapes in the berry basket. The berry basket is made do it can be lifted out of the assembly and run under the faucet to rinse your grapes (it has holes in the bottom). The entire fresh and ready assembly is manufactured by a Whirlpool supplier in Southern Indiana.
Sep 29, 2009 | Kenmore 21.8 cu. ft. Side-by-Side...
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
My Whirlpool washer basket is crocked
Check the rear suspension spring. It attaches to a bracket under the back of the tub and then to the base of the washer.
May 03, 2009 | Whirlpool Washing Machines
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer basket has dropped 1.5"
Different models use different devices to "suspend" the tub. Please verify the exact make / model.
Dec 31, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Open Questions:
Maytag Bravos MVWX700XL2 won't spin the clothes and is making a weird whining/whirling noise when attempting to do so. Hi, I have a Maytag Bravos MVWX700XL2. It's about five years old. For about a year now, it would occaisinally make a weird noise while washing that seemed to come from the agitator working. I know this sounds funny, but the noise sounded like a chittering squirrel. It didn't do it all of the time, just mostly when I would wash smaller loads. Today I noticed while doing the weekly laundry, that the agitator wasn't fully agitating. It was turning back and forth, but very slowly and not "mixing" the clothes like it usually does. I went though two loads like that, and on the third load, when it was time for the washer to rinse and spin, it started to make a whining/whirling noise and it would not spin out the clothes (but it did drain). The control panel is not giving an error code. I removed the wet clothes and tried to have it just rinse and spin or drain and spin empty and the strange noise continued w/o any success. I have a video of it making that noise that I can post/send if someone can tell me how. I paid over $500 for the washer, and I really don't want to have to replace it this soon, nor do I want a $300 repair bill. My husband is very handy and could fix it if we knew how to properly diagnose the problem so we get the correct part. Based on what I've read, could it be the shift actuator or a broken motor coupler?
Jul 16, 2018 | Maytag Washing Machines
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
