Question about Hoover Max Extract Pressure Pro 60 FH50220 - 001-50220
How do I replace the hose and trunnion on Max Extract 60
I have the part but can't get the machine apart to get to the new part installed.
  • Jennie Bridges Dec 14, 2012
    This part replaces the hand held attachment to clean furniture. The handle will not stop spraying water. I cannot replace just the handle, I have to replace the entire hose that connects to the water supply in the reservoir. I can't figure out how to get to the place to take the old hose out and put the new assembly in.
Why doesn't the water pick up on my carpet shampooer???
Hi Julie! If the cleaner is not picking up the dirty water this usually means something is not sealed off properly. Try these steps below to restore suction to your cleaner.
1. Remove the clean water tank. Recline the handle & let the handle lie down on the floor.
2. Remove the dirty water tank. Check that the dirty water tank cap is on the dirty water tank and tightened closed.
3. Clear the filter screen of any hair or debris.
4. Remove the nozzle. Clean the nozzle of any hair or debris.
5. Located on the machine behind the nozzle is a 2nd filter screen. Clean it of any hair or debris.
6. Replace the nozzle.
7. Replace the dirty water tank. Press down on all sides so that it is flush to the cleaner base.
Give it a try! The suction should be restored to your cleaner. If not I have included a video link where you may view these instructions. Hope this helps! Loss of Suction Won pick up Hoover Max Extract 77 FH50230 FH50222...
Nov 02, 2014 | Hoover Max Extract 77 Multi-Surface Pro...
How to use the upholstery attachment for hoover max extra 60 carpet cleaner?
Hey there! The nozzle/valve that releases the solution from the hose may be clogged and not closing off to stop the solution flow. You can try soaking the trigger end in warm water for a few hours to unclog it. Also make sure you are inserting the hose back into the hose slot in the back of the cleaner. If the cleaner is still dispensing from both the hose and the cleaner, your nozzle/valve assembly may need to be replaced. To order a replacement nozzle/valve assembly follow the link below.
Search Results
Hope this helps!
Aug 30, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
Why is my clean tank emptying immediately to my dirty water tank?
Hi Medori! It sounds like you have an issue with your pump assembly. We recommend taking your unit in to a Hoover authorized service center. For your convenience I have included a link to our service center locator. Hope this helps!
Service Center Locator
Aug 02, 2014 | Hoover Max Extract Pressure Pro 60 FH50220
Why does my hoover max extract leak water onto the floor?
seals faulty, replace or shop replacement if within guarantee
Jun 28, 2014 | Hoover Max Extract 77 Multi-Surface Pro...
How do I clean cat hair out of spin brissels
Hey there! The brushes can be removed for cleaning. With the handle in the upright position, tilt the cleaner back so that handle rests on floor. Grab brush assembly and pull firmly. Remove hair and debris from brushes. You may clean the brushes under running water. If for some reason you are not able to clean the brushes, replacement brushes can be ordered by following the link below.
Search Results
Jun 12, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
How do I fix pin at bottom of clean water tank?
Replace the part. This might mean buying a whole new water tank. You can order most parts online. Have your make and model ready. Find a site by google. ie if it's a hoover enter, "hoover parts".
May 12, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
Hoover max extract widepath won't spray water
One of your two water Inlet valves (either Hot or Cold) is not working and need to be replaced
Mar 14, 2014 | Hoover Max Extract Pressure Pro 60 FH50220...
Doesnt spray
Sounds like you have trash in nozzle or electrcal problem.
Nov 12, 2013 | Hoover Max Extract Pressure Pro 60 FH50220...
Hoover Max Extract Pressure Pro 60 FH50220 - 001-50220 Logo
Top Hoover Air Purifiers Experts
Thatvacguy.com
Are you a Hoover Air Purifier Expert? Answer questions, earn points and help others
