Question about KitchenAid K45SS Classic Stand Mixer
It just quit while I was using on high speed.
It sounds like I need to replace the plastic worm? With a mixer the age of mine (at least 25 years Old) will the newer metal worm work on this model?
  • 2 more comments
  • Dian Clark
    Dian Clark Dec 13, 2012
    I appreciate all of the suggestions. I do plan to order the plastic worm. I am very sure that Kitchen aide is a wonderful product. It would not be possible to have an appliance for as long as I have had if it were not. If this does not work, I will have a professional look at it before I buy another mixer. I assure you it will be a Kitchen aide! Thanks again
  • Dian Clark
    Dian Clark Jan 25, 2013
    I ordered and have received the plastic worm and I also got new brushes, however, one of the metal contacts on the brush is lodged inside and I do not know how to get to it and try to remove it. any suggestions?
  • Slo Mover Jan 26, 2013
    Hello Diane, I'm not sure that I understand what you mean by "metal contact is stuck" the bruch is made up of a copper spring attached to the end of a small rectangular piece of carbon, if that is stuck and by pulling on the exposed copper spring will not get the entire piece out, then turn the machine (motor head) on it's side and rotate the planetary to loosen up the brush from the commutator (the part of the motor that the brush rests against during the operation of the mixer)
    If I have misunderstood the problem let me know
    Novelist:
  • KitchenAid Expert
  • 185 Answers
The lady's model is a K45SS and it does not have a Hall Effect Senor, Her machine di not go to high speed, it STOPPED!!, and that is all we know. If the mixer motor still runs or operates then it is a gear problem and yes it would be the nylon worm gear made to fail in order to protect the motor from burning out. if it won't start at all no noise or movement then it is an electrical problem and it could be the speed control switch the brushes the phase control board the govorner or the motor. what is needed is more information from the lady seeking help.
Posted on Dec 29, 2012
SOURCE: My Kitchenaid K5SS 300 watt standing mixer launches into the highest speed regardless of the speed ....
I had a similar problem where the mixer would also go to fast speed right away. On the back at the top was a screw that was loose. After tightening this screw I had 4 speeds but no stir speed. I unscrewed that screw and a bolt fell out. This bolt went to threads on the inside of the area covered by that back plate. I put that bolt back on and tightened it and the corresponding one on the other side and wala the mixer works perfectly at all speeds. Hope it helps. Make sure mixer is unplugged before attempting anything like this (wires are exposed when the back plate is removed - some kind of flexible circuit board).
Posted on Dec 29, 2008
  • 16 Answers
SOURCE: mixer speed turned erratic!
I would recommend that you first check the Hall effect sensor which determines the speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight.  Guess what?  My original sensor also made my mixer work!  There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. BTW the part number is 9703312. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.  6.  Make sure you use common sense and unplug the mixer when making connections and such.
Posted on Dec 30, 2008
  • 3 Answers
SOURCE: Mixer turns on revs to a high speed and then quits
I replaced the control board on mine, and that seemed to resolve the issue
Posted on Nov 29, 2008
  • 16 Answers
SOURCE: mixer starts running on selected speed then speeds up & quits
I'm not sure what model of Kitchenaid you have.  I have a professional 6 Quart model, KP26M1XPT. I would recommend that you first check the Hall Effect sensor which determines the mixer’s speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My mixer worked as good as new! But I was curious to know if my original sensor was actually defective, so I put it back in mixer and again made sure all of the connections were tight. Guess what? My original sensor also made my mixer work!  There was nothing wrong with the original Hall Effect sensor except the connection between the control board and sensor was not tight--unfortunately I didn't check the connection before I decided to buy the new sensor. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall Effect sensor looks like. BTW the part number is 9703312.
2.  You'll need a phillips head screwdriver to open up the mixer gear case cover.
3.  Make sure that the connection between the control board and sensor is absolutely tight and snug.  This is critical!
4.  Also, make sure that the orientation of the sensor is correct.  It's difficult to tell which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or down. After you've made the connection, run the mixer. If it still doesn't work, disconnect the sensor, reconnect it with the prongs facing the opposite direction and try it again.  I actually found the right sensor orientation through a little trial and error.  But by going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work if it were reconnected with correct orientation.
6.  Finally, use your common sense and make sure to unplug the mixer before checking, connecting or disconnecting anything.
Posted on Mar 21, 2009
ricardok45
  • 135 Answers
SOURCE: kitchenaid K5-A mixer ''growling''
Hi . Chevron FM ALC EP-2 grease is what you need for the lubricant. This has a Mineral Oil base, allowing for it to, at some time, drip into whatever it is that you mix without concern for your health. From what I can, tell this is the only thing that needs to be done. Clean out as much of the old grease as possible.
Goto www.mendingshed.com and download for free a Kitchenaid Service Manual that will cover your mixer.
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Mar 25, 2009
MY kitchen Aide mixer was running alittle rough /loud and now has stop completely. It is approx 24 years old and has never had any problems. It is hard to find a local repair [place. any suggestions
Two things you can do for a 24-year old machine:
1. Replace both motor brushes (Black large plastic Caps on each side
of the Moto Housing). Without these, the motor wouldn't even run.
2. Replace the Worm Gear (the cause of the Rough Loud noises)
Download a copy of the Repair Part List from Kitchenaid.com for
your model KSM90.
Also don't forget to tighten all the screws inside the mixers and use
fresh Kitchenaid Grade Food Grease for all the gears.
Jun 21, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
When I turn on my Kitchenaid mixer at any speed, it ramps up to high speed and then shuts down after maybe 30 seconds.
You need a reputable repairman. My gears were stripped after trying to mix a very thick dough. It would only work on high speed. After it was repaired.... I still use it, all the speeds work, and that has been 15 years ago. My mixer was at least 8 years old at the time of the "stripping".
Aug 21, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
When my 85 year old mother, who no longer does much cooking or baking, heard that my trusty KitchenAid stand mixer finally gave up the ghost after 25 years of great service, she sent me her KitchenAid...
The mixer normally has it's gearbox packed with (quite thick) grease. Over time it can heat up and become more fluid and leak out. I would guess that the amount of oil you saw would not be a problem to loose. If it were mine, I would use it and not worry. If you do feel you need to check, the grease is packed in the front of the head. You will need to remove the head, split it (you will need to remove the band and planetary) and then you can see the gears.
Jan 28, 2010 | KitchenAid K45SS Classic Stand Mixer
Mixer works on high speed but not low. Brushes
Motor brushes are fairly cheap to buy. It sounds like the first place to start: http://kitchenaidmixerspares.co.uk/Home/tabid/36/ProductID/88/Default.aspx
Jan 11, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Grinding sounds and slower mixer speeds
It sounds like you may have a broken worm gear inside your mixer which is a common problem.It is a wearable part which transfers the power from the motor to the main drive. It may be chipped or damaged right now, and running it will cause more damage. Part number for the worm gear is W10112253. This does however require some know how to replace. Hope this helps
Thanks
Nov 21, 2009 | KitchenAid K45SS Classic Stand Mixer
I have a Kitchenaid Professional 5 Plus Mixer beaters won't turn
It sounds like it has been overloaded and the worm gear has been stripped. You will need to take the head apart to confirm this.
Jun 24, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid 600, Stand Mixer - Loud grinding noise, happened when mixing bread dough. When bowl is lowered (dough hook disengaged)....no noise, hook turns. When bowl is raised so that hook engages dough,...
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Jan 31, 2009 | KitchenAid KP2671 Professional 6 Series...
Hobart A200 diagnosis
the first A-200's have a worm gear drive that will slip when old but also when mixing dough somtimes the dough will push the mixer aherad of its self and look like its slowing but its just catching up. if you have a old worm shaft it will have a spring on it is how to tell. it is replaced with a shaft that is all keyed and has no slip or give unless a key shears.
Michael
Nov 25, 2008 | Hobart A200 Stand Mixer
Nov 24, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid K45SS Classic Stand Mixer Logo
522 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
