Question about Samsung PS42C430 42 Plasma TV
Power pcb relay ckicking sound - Samsung PS42C430 42 Plasma TV
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Relay is losing voltage or a issue on the power board, does not really matter as only boards are sold or available for this type of set, no individual parts are sold.
If you are able to safely open set look at the power board for damaged parts or puffy caps.
Posted on Dec 12, 2012
Looking for the fuse for the wiper motor 2008 chevy impala
WPR fuse 25amp under hood fuse box .
Wiper/Washer System Components
The Wiper/Washer System consists of the following components:
• Windshield wiper/washer switch
• Body control module (BCM)
• Wiper PCB relay
• Wiper high PCB relay
• Windshield wiper motor
• Windshield washer fluid pump
• Windshield washer fluid level switch
• WPR fuse 25 A
• WSW fuse 10 A
This is more then likely not a fuse issue !!!!!!!
Low Speed Operation
When the wiper switch is in the low speed position, ground is applied through the switch internal resistor and the wiper switch low signal circuit to the body control module (BCM). In response to this signal, the BCM energizes the WIPER PCB relay by applying battery voltage through the wiper relay control circuit to the coil side of the relay. This allows battery positive voltage from the WPR fuse to flow through the switch input side of the WIPER PCB relay and out to the switch input side of the WIPER HIGH PCB relay. Since the wiper high relay is de-energized and its switch contacts are normally closed to the low speed control circuit of the windshield wiper motor, the motor will operate at low speed.
Wiper motor low speed operation and the wiper PCB relay can also be commanded ON/OFF by using a scan tool. Refer to Control Module References.
The PCB relays mentioned above are soldered right into the circuit board inside the fuse/relay block under the hood . There are alot of reasons for the wipers not to work ! The fuse could be blown but fuse's don't just blow for no good reason , short to ground , low resistance high current flow etc.... Intermittant !
Power and Grounds
With the ignition in the ON position, accessory voltage is supplied through the 25A WPR fuse to the WIPER PCB relay, the WIPER HIGH PCB relay and the WS WASH PCB relay that are all located in the underhood fuse block. Refer to Wiper/Washer Schematics.
G200 provides ground for the windshield wiper motor and the WIPER PCB relay. G100 provides ground for the windshield washer fluid pump and the windshield washer fluid level switch.
Dec 04, 2016 | Cars & Trucks
What is causing the same relay connection to short/melt on the oven relay PCB?
Try re-soldering the relay on the board. Sounds to me the relay is not up to the job, find an engineer who can advise a heavier current relay that will fit in the same topology.
Sep 12, 2015 | LG LRE3083ST Stainless Steel 30" Electric...
5v ok. start up relay doesnt activate
Sounds like you may need the power supply or Main PCB. The Main PCB usually has your microprocessor with your communication lines.
Jul 23, 2014 | Sharp Televison & Video
Need help with chevy truck 1986, replaced fuse, and relay. press horn, and the relay clicks" now what ?
relay is ckicking because of in correct voltage,ck power supply to horn and make sure you have correct fuse ,hope this helps
Jul 07, 2011 | Chevrolet C1500 Cars & Trucks
I have no power to the dishwasher.No lights light up om the control panel.Checked circuit breaker and there is no problem there.Is there a fuse or power reset button.
if you definetely have power into machine its sounds like a pcb fault these can blow out tracking or relays on pcb causing dead machine can be replaced but not cheap.
Aug 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Starter clicking noise, bike won't start
start relay should be checked, if cables are loose or corroded they do not deliver enough power.if jumping the start relay will engage the starter replace the relay.
Apr 29, 2010 | 2005 Honda VTX 1300 R
52" rear projection tv has no power and fuse is ok
The clicking noise that you are hearing is actually the power relay. Normal operation by either the remote or the power button on the front panel, you would normally hear a soft click just after the press of the power buttons to turn the unit on or off. When you initially plug the unit in to power, you will hear the same click noise. Being that you are hearing it all the time indicates a failed relay. TV's now a days, or at least ones built during the last 15 - 20 years have different Printed Circuit Boards (PCB). There are PCB's for power (which youre dealing with now), sound,video and so on. The PCB that you need to repair your clicking issue will run you about 80 U.S. dollars for the part plus the average going rate for repair from a qualified service tech. You could purchase the part from Thompson Consumer Products repair and fix it yourself, but be aware, there will be no warranty on the part itself unless an authorized tech does the work. Located on this PCB is the power on/off relay, fuse, usually 4-5 connectors for power to different PCB's (depending on model and features). Now depending on how old the TV actually is, you may want to invest in a newr set, the reason why I say that is, is because the new power unit may and can overload the other boards and cause damage to them and now you have a new problem to deal with( along with more money being tossed down a hole.
Good luck
Sep 19, 2009 | RCA P52926 52" Rear Projection Television
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Tv wont power up
Good Day, y'all;
Try these:
CHECK CONNECTOR "DR" FOR PROPER CONNECTION, BETWEEN THE DEFL MINI PCB AND THE MAIN PCB. 2. CHECK C5A09 AND C5A50 BOTH 33 UFD 50 V OFF OF IC5A01 ON PCB-DEFL MINI. 3. CHECK FOR LEAKY IC5A03 PART # 270P704010 ON PCB-DEFL MINI 4. SUSPECT THE HIGH VOLTAGE BLOCK PART # 920P016010.
NO POWER. RELAY CLICKS 1. CHECK Q501 (261P071010), Q502 (260P561020) AND Q503 (260P788010). IF ANY OF THESE TRANSISTORS ARE SHORTED OR LEAKY REPLACE IT INSURE THE FOLLOWING CIRCUIT CHANGE HAS BEEN DONE. REMOVE J58 FROM THE PCB-MAIN. USING AN INSULATED JUMPER WIRE, SOLDER A 22 OHM 1/4W RESISTOR BETWEEN PIN 4 OF THE RELAY K9A30 AND THE J58 HOLE NEXT TO PIN 1 OF CONNECTOR DQ. DRESS AND INSULATE THE JUMPER AND RESISTOR TO PROTECT AGAINST SHORT CIRCUITS. INSTALL A .01 UF 50V CERAMIC CAPACITOR BETWEEN THE COLLECTOR OF Q510 AND THE GROUND LEAD OF R502. NO POWER. NO RELAY CLICK 1. CHECK FOR 5 VDC AT PIN 9 OF IC700 (AC-OFF) IF MISSING CHECK PC901 PART # 268P058020, ON THE POWER PCB. Good Luck, big IRISH. back.gif back.gif
Dec 16, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Samsung PS42C430 42 Plasma TV Logo
59 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
