Question about Mr. Heater Model MH12TS - Single Tank-top Propane Heater
Whats wrong when tank top heater triyes to light but when let button out it goes out
  • Mr. Heater Master
  • 3,092 Answers
Blocked pilot too short or faulty thermocouple
Posted on Dec 13, 2012
Propane tank top heater wont stay lit
Try replacing the thermocouple , and clean pilot .
Dec 16, 2016 | Heating & Cooling
We bought a big buddy 2 days ago and now it wont work.
Push red button down to start, maybe 3 times, then push red button down HALF way down then turn to low.
IT COULD BE YOUR PROPANE TANK, got a new one but had problems, so I left it on all night and it lit in the morning.
BUT when I got it filled the next time the man said the stem in the tank might need to take it outside and bang the tank several times, stem in the top gets stuck a lot he said.
But last is to take the tank outside and use a flat head screwdriver and turn the screw? on the side where the hose would be connected to let some out.
Feb 05, 2015 | Mr. Heater Big Buddy Heater
Our church baptistry heater will come on for a few seconds and then goes off.after a little bit I can hit the reset button but will only come back on for a few seconds.then the red light goes out agai
1) For tank-type gas water heaters:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Re-post question on fixya or Tank forum and include information that shows on product label usually located on side of unit, so expert can determine which product, and what error codes and controller are revealing.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Jan 01, 2013 | Water Heaters
Can propane gas lines cause pilot lights to go out?
It could be a blockage in you pipes or blocked pilot on water heater nees cleaning or your pipe size is too small for both or you are low on gas or reg on tank not working ie wrong working pressure .
Dec 28, 2012 | Heating & Cooling
My 2 year old (rusted and looking like a 10 year old) Pilot goes on lights the heater, burns for about 2 minutes and goes out. I tried another regulator, same problem. Gas tank is full. The pilot light...
Heaters that have rusted are tin plated or chrome finish, it can be hard to get a stainless steel heaters since some traders sell heaters as stainless steel but don't tell you the burner is made of tin. If you get a new heater just ask the question, is the burner tin or stainless steel? The problem with a burner that goes out can be a simple as changing the thermocouple, these are consumable and last between 2 to 5 years depending on use and storage. But if you have a yellow tipping this is not good, this can be caused by wrong fuel mix or faulty gas valve and is not an easy fix. Found this site very useful patio heater problem solving. Lots of info.
Oct 23, 2011 | Coleman (5040B750) Patio Heater
I purchased a single burner tank top heater from Menards. Every attempt to light it resulted in a loud roar so I exchanged it. The replacement has functioned properly untill recently and now has a loud...
Turn the LP Tank Valve OFF and disconnect the heater from the tank. Wait 5 minutes and reconnect the heater to the tank. Turn the tank valve ON VERY, VERY SLOWLY (slow motion slow). Nor light the heater and turn it to high. Allow it to burn on high for several minutes, before tuning it to low. If this solved the problem, the OPD tank valve was shooting to much pressure to the heater regulator. Turning it on slowly, helps alleviate that problem.
Mar 13, 2011 | Reddy Heater Propane/LP Infra-Red Tank Top...
My heater is not getting hot i can not tell if their is a pilot light or a reset button i don know what to do with the heater it is very different how can i heat my water heater
Reliance makes gas and electric water heaters.
http://www.reliancewaterheaters.com/
Best way to start is to look at label on side of tank.
Label has serial number, model number, plus it will say if heater is gas or electric.
Reliance water heater age is shown in serial number: first digit is letter, second two digits are numbers: for example numbers 02 would be the year 2002.
If water heater is 8-12 years old, it might be time to consider new tank.
Gas water heater has 3 inch metal flue pipe coming out of top of tank.
Gas pilot is probably off.
Relight pilot light: Most gas water heaters today have instructions on side of tank just above gas valve that say how to relight pilot light. Instructions vary by model.
If you have gas water heater that is older, it might be easier to call a plumber.
Electric water heater has panels on front.
Open top panel and push in red reset button.
If you have electric water heater of any age, you can usually fix it yourself same day:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Dec 03, 2010 | RELIANCE ELECTRIC WATER HEATER
Table top propane heater: tank freezes, fire goes out
I have a table top heater and was wondering why I have flame shooting out of the top of it when I should have like a blue flame, what can I do
Dec 14, 2009 | RTO Bernzomatic Brushed Nickel Patio...
Tank-top propane unit won't stay lit
I had to replace the regulator. If you have a propane appliance shop near you, you can probably just get the nipple that goes into the bottle. It's aboit 3/16" diameter, 3/4" long and may have a 6 sided end up inside the screw on cap of the regulator.
Feb 24, 2009 | Mr. Heater Model MH12TS - Single Tank-top...
Mr. Heater Model MH12TS - Single Tank-top Propane Heater Logo
421 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
