Question about Panasonic Microwave Ovens
The lock is on my panasonic over the range microwave.can you help
I leaned against hte microwave buttons by mistake and now it says lock.
  • Panasonic Master
  • 9,098 Answers
The owner's manual will cover how to lock and unlock the controller.
If for some reason you don't still have yours, You can download your Panasonic owner's manual here.
If it's not a US model, see Panasonic.net.
Posted on Dec 12, 2012
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave keypad displays ''L''
Your owner's manual should cover it.
I'd say the child lock has been activated.
If it has a "Help" button, look for the lock option.
Otherwise, do a hard reset by unplugging it for a couple of minutes, then setting them clock.
Posted on Oct 30, 2009
SOURCE: I HAVE A PANASONIC NNSS277S OVER THE RANGE
IMHO this is an expensive microwave and it is pretty poor that the door mechanism is so weak considering that it gets constant stress from opeing and closing the door and especially since the part that breaks is integral to the expensive control panel. I have the same problem with my microwave after only 2 1/2 years of use. After some fiddling I got it apart as follows. Remove the three screws that hold on the top grille (above the door) on and lift off the grille. Turn off the power to the microwave at the switch panel. Remove the two screws above the control display that are now visible after removing the top grille. Do NOT pry this panel off, slide it upwards to unlatch the hooks and lift it off carefully. There are a lot of wires which you will have to unplug (note their locations although none of the plugs are interchangeable) and separate the panel from the microwave. You can now check the latch itself and open the door by putting your finger under the lift latch and genly pushing upwards. If the door won't open the problem is in the latch mechanism which can be removed by taking out the two screws on the inside of the case an unplugging the many wires (note locations, a couple of them can be plugged back in the same place). If the problem is the same as the one I had it is in the actualy release button assembly where one of the brackets are broken. You will either have to replace the whole display & control panel or glue the bracket back together. I'm in the process of trying to glue it with epoxy but I can't vouch for how reliable the repair will be. Remove the screws that secure the control panel metal reinforcement and unplug the flat cable then remove it carefully. If either of the plasting pivot brackets moves it is broken. With the metal plate removed the problem should be obvious.
Posted on Jul 18, 2010
How do you unlock the panosonic microwave
hi Barbara.
this is what i could find out.
. Press the "Stop" button three (3) times.
or read up more at this link.
You are now ready to use your new Panasonic Microwave Oven. When you first turn on your microwave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . . Press the "Stop" button three (3) times and the "CHILD LOCK" will be turned off.
set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/om/set-up_guide_en_om.pdf
How do you unlock the panosonic microwave Google Search
Dec 02, 2017 | Microwave Ovens
Oct 30, 2009 | Kenmore Microwave Ovens
Sharp R1870 microwave door will not open and child lock is not on.
We have the applicable service manuals for these models and have uploaded them to our site here and here to help you.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Chances are the rear of the door open button and/or the face of the door open lever is worn enough that it will not actuate properly. Or the lever may be broken.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should
open.
You can order parts for this brand from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Sep 16, 2009 | Sharp R-1870 Convection/Microwave Oven
Child sign in window of microwave ,cant start it panasonic
On my NN-L738BA there is a Child Lock feature.
You set the child lock by pressing the Start button 3 times.
If the Child Lock is enabled it displays the word :CHILD".
To disable this feature on my microwave the manual says to
press the Stop/Reset 3 times.
Check your manual for the Child Lock.
Mar 06, 2009 | Panasonic NN-S541 Microwave Oven
My son has locked the microwave.
hold the stop button down for 10 seconds or hold the start button down untill it beeps
Jan 21, 2009 | Panasonic NN-S561 Microwave Oven
Panasonic NN-ST666W Microwave oven
What usually breaks is the door open lever, but it may be that the rear of the door open button and the face of the door open lever are worn to the point where they will not actuate.
On a counter top model, the outer cover will need to be removed to diagnose and repair this.
On an over-the-range model, only the control panel needs to be
removed in most cases.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find Panasonic parts in Australia here.
Dec 07, 2008 | Panasonic NN-P794SF Microwave Oven
Panasonic word prompt microwave
You should be able to download your Panasonic owner's manual here.
Nov 26, 2008 | Panasonic NN-P794SF Microwave Oven
Cant open the oven model nnst656w
What usually breaks is the door open lever. Sometimes it may be a worn door open button (the back side) or the face of the lever.
On an over-the-range model, only the control panel needs to be removed. At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order Panasonic parts from Tritronics (or call 866-779-5835) but if you don't find what you're looking for there, try here.
Nov 02, 2008 | Panasonic NN-T888S Convection/Microwave...
We need a replacement piece for our microwave. The button you push to open and close the microwave is broken.
What usually breaks is the door open lever, but the prongs on the door open button may also be worn.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel usually needs to be removed.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find Panasonic (US) parts here. If you're not in the US, please reply back.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 09, 2008 | Panasonic Microwave Ovens
Door
Please reply back with your brand and model number so we can help you better.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Jun 22, 2008 | Panasonic NN-H275 Microwave Oven
Microwave Ovens Logo
102 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
