Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Saeco leaking... Please HELP!#@&(!
We own the Saeco Incanto (SUP021Y) Recently it has begun to leak. It leaks clear water onto the counter after the brew cycle is complete, seems to be coming from behind/ inside the steamer/ frother mechanism. It also doesn't fill cup as before (1/2 of brewed coffee seems to dump into the drip tray.) And the used up grind that goes into the collection compartment comes out very moist, it used to come out alot more packed and drier previously. I am in some serious need of help in repairing this machine. The coffee we use is a Portuguese Bean called Sical. We bought it in Portugal just under 2 years ago. We live in South Jersey. I must also admit that it wasn't turned off on a regular basis. Your advice, help, part recommendations, and where to purhase or reputable local repair person would be greatly appreciated.
This may just be a cleaning issue. I have had this alot. If you open the machine and take the contraption out of the inside (the hopper thing). You should clean this of course but the problem is behind that on the back wall of the machine. There is a diagonal slot. at the bottom of the slot is a drainage port that is supposed to take the water and send it to the tray. but you will probably find that this is all clogged up with coffee. You need to clean the coffee out, I recommend pipe cleaners and Qtips and patience to get it out. You will know it is clean when you can squirt water into the bottom of the diagonal slot and it will flow out of a little port just below it (where it goes to the tray).
How to keep this from happening again. Most likely given the description of the beans (too wet), your grinder is set too fine. You can adjust the grinder when it is running and you should adust it to a higher number. Its recommended to be on 8 and you may need to go to 10 or 11, ( you have to experiment with it). I only recently realized that my own grinder was set at too low of a number and it was causing a recurrence of this leakage issue.
Posted on Jan 18, 2009
    Sergeant:
  • Saeco Expert
  • 223 Answers
Island,
Some incanto's had an issue with the steam valve assembly, because they were plastic and some were defective. Here is the new improved steam valve kit: http://cerinicoffee.com/Saeco_steam_valve_replacement_kit.asp
We are a authorized service center in NY, and were actually the first authorized center for NY, CT, & NJ. If you would like you can send your machine to us and we would by glad to take care of your machine for you. Here is the service repair page: http://cerinicoffee.com/Espresso_machine_service.asp
Thanks for giving us the oportunity to service you.
Cerini Coffee Services, Inc.
www.CeriniCoffee.com
Posted on Jan 16, 2009
Saeco incanto deluxe frother leaking and wont pull shot because water comes out of frother tube during shot disbursement
Dear Jon,
Hi this shrikant from mumbai.This problem is happen due to dust stuck in tea/hot water valve ( for steam which you rotate).
If you have screw driver set then open the machine by using + screw drive. step below,
1.I here attach picture of valve.
2.you have to open it and clean it ( sea in pic 44,46,47,54).
3.after water leaking stop you have replace one o-ring 54 no. in picture.
4.After you machine work fine.
regards,
Shrikant Shinde
Yogishri Engineering
+91-8425830001
Jan 28, 2015 | Saeco INCANTO DELUXE Espresso Machine
Fix leaking from brew unit
Time to buy and replace a gasket. They get hard and cracked over time due to the heat and just to simple aging.
Sep 21, 2014 | Saeco Incanto Sirius Fully Automatic...
I have a Saeco Italia Sup21 it Leaks water under the machine can you suggest what I can do for repairs?
Remove brew unit and make sure small chamber under white plastic valve in the machine is clean, also clear chute to drain tray.
Sep 16, 2010 | Saeco Incanto Classic Espresso Machine
Leaking water, wet under coffee machine
make sure the water tank is not leaking theres a seal in the part on the machine that the tank sits on its underr the hard plastic ring. if that is good then theres a line or somthing gone internally
Dec 01, 2009 | Saeco Incanto Classic Espresso Machine
Small leak from the bottom right side (when looking at the machine) of my Saeco Incanto Sirius Espresso Machine when being operated. After two or three cups of coffe are made, need to move machine to the...
I have the same problem. To day I opened the Saeco and discovered that the unit attached to the knob at the right side of the machine must be replaced. Water came out in two places. I dont know where to buy this part.
Per
Oct 13, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto power loss.
You either have two things i think, my first thought is a leak.
The two most usall leaks on a incanto is either from the boiler or the steamvalve.
alitle more long shot is a defective fuse on the bioler.
Jul 22, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto not grinding
Hi Chris,
The leaking is your steam valve that has to be replaced, you can see this if you open the door and look up in the right corner there you will see water drip.
If not then you have a pipe or boiler leak.
How old is your machine?
How often do you descale the machine?
When you try to make a cup of coffee, starts the grinder for two seconds or is it dead?
Hope this will help you.
Jul 19, 2008 | Coffee Makers & Espresso Machines
Water leak
The majority of leaks in the Incanto are caused by the steam / tap body installation. If you open the machine, you will find the tap body is made of toughened plastic. This is inferior, and should be replaced with a brass tap body which can be purchased directly from Saeco. Also, the piston sometimes sticks and creates a blockage. You will also notice the steam outlet is only cm's from the micro processor on the power board. Any leaks from the steam tap body almost invariably wreac havoc on the power board. Overall, the Incanto is a poorly designed machine that I would not recommend.
Nov 10, 2007 | Saeco Incanto Classic Espresso Machine
Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Oct 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Water leaking
Depending on the age it could be just some orings leaking or a connection that has come loose. Or it could be the boiler leaking. Not knowing the age it is had to know which. You should google "saeco repair" and have an authorized repair center take a look.
Aug 24, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
369 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
