Question about Akai Televison & Video
When I turn it on, the red button is lit up but no picture. is it worth the repair?
    Top Expert:
  • Akai Master
  • 45,018 Answers
The "red button" merely indicates that power is getting to the set. Most likely the internal power supply has failed
Posted on Dec 12, 2012
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
LG Dryer buttons frozen 'on'
Did it run for awhile first? Ours ran & ran & never turned off. I manually unplugged it. Eventually, determined it was the thermostat that was triggered. First time, the repair man replaced it. Second time, he just hit the red "reset" button in the back. (LG told me over the phone there was no reset button, but not true.) You have to remove a panel in the back (carefully, it's sharp) and reset. Not sure this is your problem, though, from the sound of it. Worth a try. Now I don't run ANYTHING when the dryer is on (not even the washer..which is a pain). Seems to help.
Mar 05, 2014 | LG DLEC855 Dryer
I want to light the pilot but do not know how what is the red button for and do you turn on the gas to light pilot?
nope - don't turn on gas at the Range's front control panel to light the pilot lite.
but you do need to turn on the gas to the kitchen range at the plumbers black pipe valve to the Range.
To light the pilot light:
(1) depress the red button (that feeds the gas to the pilot light orifice)
(2) using lighter/match/lit rolled-up newspaper, etc, light the tiny amount of gas coming from orifice
(3) continue to hold dow red button for 1 or 1.5 minutes (this allows heat to bend the bi-metal contact)
(4) after 1-1.5 minutes with a lit pilot light, release the red button - the pilot should remain lit
(5) you're done lighting the pilot lite - turn on the oven (or broiler).
Dec 27, 2010 | Kitchen Ranges
Red LED light blinks 7 times when the set is turned on; no pictur
if you have the circuit diagram of your tv,check the horizontal polarisation IC closer to the line transformer and replace it.If it doesn't work,send the question again.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
AKAI PT5598HD won't turn on
take it to a repair shop and have then look at it. it may or may not be worth the cost of the repair. i dont know what the parts and labor would be on it
Nov 15, 2008 | Akai PT5598HD 55" Rear Projection...
RCA 27F520T no picture problem
 Examine PCB closely,probable cracked board.Depending on
how severe,it may be fixable.Ask repairman what the bench labor
charge will be to repair,if repairable at all.
Oct 11, 2007 | RCA TruFlat 27F520T 27" TV
Red-Orange Screen
If the screen flashed when the TV made a popping sound, then I would suspect an intermittent heater to cathode short in the picture tube. When this happens, it usually takes out one to three output IC packs located on the CRT drive board. Even if you replaced the defective output packs which are soldered in and attached to metal heat sinks to restore the picture, the CRT could short again and redo the damage. For a 20 inch screen it is probably not worth repairing.
Dec 04, 2006 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
11 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
