Question about Refrigerators
Totally Dead This unit looked great and worked fine foor a few months and just quit working.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Refrigerators Expert
  • 310 Answers
If the light is on and nothing else works, suspect these two issues:
The refrigerator thermostat has failed in the open position.
The defrost timer has failed in the defrost position.
Posted on Jan 13, 2009
Lg ld301el
totally dead, check fuses. could be stiffened up over the time and took fuse out on first switch on
Aug 13, 2014 | LG Dehumidifiers
Krups Beertender VB5028CT (C75) totally dead now.
I had one that appeared totally dead and replaced four capacitors (~$5 to buy) and it's back up and running. If you pull the back of the unit and remove the unit attached to the power cord you'll see a pcb board. Look for any capacitors that look kind of rounded on the top (they should be flat). On mine it was a cluster of one 470 uF and three 1000 uf capacitors. Desolder those and solder in new ones. Mine were rated at 16 volts but I replaced them with 25 volt units for a bit more safety margin.
Jan 11, 2013 | Krups C75 Beertender Home Beer-tap System...
Where is the fuse for ge spacemaker jvm1320wb-002...the unit is totally dead...nothing works
It is time to replace the microwave oven, if the fuse is open you more than likely have a more serious problem that will be costly, companies only go back a few years when it comes to supply parts
Jun 16, 2012 | GE Microwave Ovens
I have a riptide st 80 24 volt bow mount co-pilot. Still under warranty but has worked well for 9 months. When I start unit, it works well for 15 seconds (more/less) and then shuts off with the green on...
Start to look for the charge state of your battery.
Measure the voltage on the battery connectors when the motor falls out. If lower than 11v your battery is too weak.
Also check all the cables between battery and motor. Check foor loose connection or oxidation.
Aug 19, 2017 | Minn Kota Riptide St Saltwater 80 Bow...
I got my pump a month or two ago and it worked great but last week it quit working no LCD light or anything. The power going to it is fine but it popped the breaker on the plug when it quit working. Is...
You are not over looking anything.
There are no consumer ways to fix your problem
If you still have your receipt you can call Intex
They will e-mail you a form just fill it out and fax it back
within a few days a new one will be at your door
Aug 06, 2010 | Intex Automatic Salt Water System for ...
My Whirlpool refrigerator quits working and restarts
Good day,
If it only occurs on a monthly cycle, even a service tech would not find it unless it happened while he was there.
First choice would be to replace both the thermostat and the defrost control. These are the items that turn the machine off and on and either one could hang or stick once in a while.
NOW, that is based on the fact that the machine goes totally dead during that period. If you hear something, anything running then the above does not apply.
The possibilities then, are, the fan motor in the freezer won't run (you can hear it running when you open the freezer door), the cooling fan motor behind the bottom rear cover that cools the compressor and condenser same situation, will not run.
Lastly, the start relay mounted on the side of the compressor is weak. It will not kick in the compressor, but in that situation, the fans will run.
Hope that helps. I've serviced a lot of refrigerators with that complaint, and it's always been the first 2 items.
Feb 17, 2010 | Whirlpool ET1FTKXK Top Freezer...
I have an similar problem with my Amana Dryer LEA30AW.
First Clean out your filter, Assuming the element is okay and cut-out are fine it should run okay, you could also try running it on low heat will take a bit longer but hey if it works great..Good luck
Oct 01, 2009 | Dryers
Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
Touchpad is not responding
maybe you kill all the process that the touchpad use
or you have an virus
May 16, 2009 | Toshiba Satellite M205-S7452 Notebook
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
