Question about Roland KC550 Amp Keyboard
Roland KC 550 keyboard amp, power light is on but no sound
My amp stopped working. When I turn it on, the blue standby light comes on, so the power connection is intact, i think. However, there is no sound at all, no matter what channel I plug into or how high i set the volume. I'm figuring it's a blown fuse, so I am currently trying to disassemble the amp, but I'm having trouble with that too, there doesn't seem to be any seams in the upholstered wood that encases the amp and speaker. Any help would be appreciated.
4 Suggested Answers
  • 1138 Answers
SOURCE: Roland keyboard. Extremely static-y speakers. Cuts out.
It sounds like your volume slider is dirty. Try carefully and judiciously spraying a good quality contact cleaner into the slider and working it. do not use a lot. It only takes a little. Also do not use WD40.
Posted on Apr 23, 2009
  • 5603 Answers
SOURCE: roland juno d not pikkingup volume but very low
Check if headphone output is normal... sometimes the headphone jack switch fails and doesn't send to speakers when headphones are unplugged.
Posted on Oct 20, 2010
walesarumi
  • 6993 Answers
SOURCE: My Roland kc 550 will not power on.
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care........
Posted on Mar 22, 2011
Only humming or buzzing , no music or sound
Try different cables. That would be the most simple and cheapest fix.
May 27, 2014 | Roland Kc-150 65-watt Keyboard Amplifier...
My amp becomes distorted when I turn my keyboard up. Both the Master Volume and the CH1 volume knobs are in the middle(12 o'clock). How do I keep my amp from distorting?
You left off the one bit of info we need... however, make sure the volume control on the keyboard is around the halfway point... If it is way down, turn it up and reduce the channel volume knob some. Make sure the cable from the keyboard is an instrument rated interconnect and not one intended for speaker (usually marked as such). Make sure the keyboard AND this amp are powered from the SAME receptacle... even if you have to run an extension cord. Listen with headphones on your keyboard to make sure the sound is clean there.
Sep 01, 2011 | Roland Elektronische Musikinstrumente...
Hi , I,m Itali , sorry for my English , but I'have a problem with KC-350 ( similar KC-550) The general Gain it's not responding. The output signal is very very low and very noisy. Thank for...
Sounds like you have a poor or open ground if the loud noise is 50 or 60 Hertz. If you have the loud noise when the keyboard not connected then the open ground is in the amp. Often times it is only a cold or bad solder connection which you can touch up with a solder iron and some rosin core solder. If the noise disappears when the keyboard is not connected then I would look at the patch cord first and the connectors second. If you have a second amp you can test to cord and keyboard to verify the problem is the keyboard. If you have to touch up the solder connections, unplug and open up the unit. Make sure all connectors or seated and none of them are loose. Use a grounded three prong solder iron and 60/40 rosin core solder. Heat up connections on the connector and add a small bit of solder to each connection. Next heat up the solder connections on the circuit board and quickly add some solder. Caution, do not apply to much heat on the circuit board or the copper trace will lift off the board so you need to use as little heat as possible just to start the solder to flow then let it cool.
Aug 19, 2011 | Roland KC550 Amp Keyboard
There is a power, but no sound at all.
When you turn it on does the speaker thump or make a hissing sound? If so then the speakers are ok. If there is notany sound, you must measure the speakers to make sure there is continunity.
If you need further help you can send it to Pro Line Music.215-736-8055
Jul 15, 2011 | Roland Kc150 Kc 150 Keyboard Amp Demo Unit...
I need the schematics for the Roland CK-60 amp or the wire diagram.
This MIGHT be close to your unit... it is for the KC-100... they often use the same circuitry.
http://elektrotanya.com/roland_kc-100.pdf/download.html
Scroll down to the "Get Manual" and click on it to download. There may be slight variations but these amps are simple enough to troubleshoot. USE the old trick of putting an incandescent lamp of say 100 watts in series with the power input to act as resetable fuse and save fuses when powering up after a repair.
Apr 29, 2011 | Roland KC60 (40W 10 3Ch Keyboard Amp)
I have a very loud hiss/buzz sound coming from my Roland. It goes away if I lower the high volume knob. This just starred to happen recently. I tried changing connections from ch1-4 but no fix.
If this ties to a keyboard, make sure the keyboard and this are BOTH plugged into the same receptacle. You should send a higher level from the keyboard (turn volume up to around 70% or so) and use less volume at the input gain of this amp. Use more at master volume if the amp has one if needed. If the hiss is there with NO input cables plugged in and input gains at 50%, that is objectionable, the amp probably needs servicing. Unused channel gains should be clear down.
Apr 11, 2011 | Roland Elektronische Musikinstrumente...
Take care........
Mar 21, 2011 | Roland KC550 Amp Keyboard
I have a roland kc 150 65w amp that begins humming the moment i turn it on. its a normal low frequency hum. nothing is plugged into it, and when i ajust the volume knobs it does not effect the sound. How...
First thing is to determine if sound is from the speaker or possibly the cabinet. If from the cabinet it is likely the power transformer is vibrating the chassis. This sometimes can be cured by adjusting the mounting bolts.
If the sound is from the speaker, then an electronic "cure" is needed. Please note that a very quiet hum is normal but if you can hear it 5 foot away, that is un-normal.
The hum would probably be due to failing component in the power supply. Unles you are adept at electronic repair, best to take it in for servicing.
Feb 25, 2011 | Roland Kc-150 65-watt Keyboard Amplifier...
My roland kc-60 has a hum but i cant get any sound but that
Does the hum exist with no cable plugged in? If so, take in for service. If there is no hum with cable out, then try new cable and/or musical instrument be it guitar or keyboard as the problem is likely in those.
Nov 22, 2010 | Roland Kc60
Roland KC550 Amp Keyboard Logo
156 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
