Regarding Volume Sometime power may be cutoff while watching TV. If TV is put on after getting AC power the volume is going high (displaying more than 200). Every time I used mute the Tv and reduce the volume. How to fix? Thanks
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
MARR
  • 49 Answers
SOURCE: Samsung TXE1370 13" TV - volume out of control
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
Posted on Feb 26, 2007
  • 192 Answers
SOURCE: high pitch sound for Sony FD Trinitron WEGA KV-27HS420 27" TV
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Posted on Mar 04, 2007
  • 135 Answers
SOURCE: tv volume goes down of its own accord
Some dust in the button to lower the volume on your TV or on your remote control might be causing it to think it's being pressed. Try playing around with it, pressing it hard so as to relieve it of any pressure on the inside.
Posted on Jan 09, 2008
  • 668 Answers
SOURCE: i was watching tv when suddenly the volume control
The front panel Tactile Switches probably need to be replaced. The part # of the switches is 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this helps,
Skyassoc
Posted on Jul 02, 2009
jrweighing
  • 183 Answers
SOURCE: TV Volume goes up by itself and remote wont work
There are 2 reasons that this is happening in respect to the problem commencing after your daughter has cleaned the tv. Either your daughter has sprayed the volume button with cleaner and fluid has got into the the graphite pad under the button and conducting as though the button is being pressed continuously..or she has put too much pressure on the button if it is a metallic plate contact switch.One way to find out is by pressing the down volume button.does it it click ? if it does.try the up volume..If that doesnt click the problem is the metallic plate is dented in making contact hence a new switch. Another cause ive seen is cleaning the remote control with cleaner and fluid has got into the remote and it sends signals to the tv all the time..If the remote control is hidden under a cushion and the problem stops, then the remote control is at fault and needs drying out..Hope this helps :)
Posted on Aug 04, 2009
TV Volume problems, it's Low and won't go Hi
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 31, 2015 | Televison & Video
My volume display stays on
The Tv needs to be serviced by a technician.Probably there is a problem with the circuits inside.
Apr 12, 2008 | Televison & Video
TV volume goes to loudest on it's own
It sounds like you may have a stuck micro button (volume button on tv) . You might try to push the up volume button on the tv several time and try to get it unstuck (if in fact that is the problem). Also sometime I have had situtions where the board holding these switches on the inside of the t was broke and had to be soldered and repaired.
If I can be of any more help, please email me at wyoed1@aol.com. "Original Radio Man" Ed
Feb 12, 2013 | Sharp 25R-S100 25" TV
Low Volume despite High setting on TV
HI I am having the same problem. tv sound is fine, then fades so that 50 is the only sound volume to hear the show. It happens intermittently. Did you get your's solved? thanks
Jul 06, 2010 | JVC AV-27050 TV
Volume making humming noise when on
there is a bad ground.
the hum you are hearing is ac getting into the audio.check all the rca plugs on the set are plugged in all the way.do not run them close to a power bar either.
sometimes a second unit with it's own volume is hooked up to the tv and then the tv volume is up too high because the other box is turned down.if there is a unit hooked up,turn it's volume up ,and the volume on the tv down,otherwise the tv will amplify the residual noise.cheers,ed
Jul 04, 2009 | Proscan 32LB30H LCD TV
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
May 15, 2009 | Onkyo TX-SR502 Receiver
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Akai model lct2721ad. tv.
Mine does this all the time. It appears to be a factory flaw. The only way around it is to set the channel you are watching to "MONO" and the crackling sound will disappear.
May 11, 2008 | Akai LCT2721AD 27 in. LCD Television
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Sound form Bush TV
It could be several problems, I'll share with u a couple. All of them need a tech.[technician]
Your volume control works by adjusting the voltage\current to the speakers. The VOLUME CONTROL could be damaged\fixed at a point [even if you are raising\lowering] at high volume.Sometime the control has a crack ********\********* in such a way that the volume arm won't go past crack[see above] on HIGH volume.
The audio IC could be shorted in high volume. Sometimes the audio IC is PART of a 64 (sixty-four) pin ckt. How do u test for that if u are not a techo'
Let someone take a peek at it.
Oct 23, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
