Precor C954i Commercial Treadmill Logo
rose bronson Posted on Dec 12, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Precore 9.35 Error 5
My Precore 9.35 stops within a few seconds of running after attaching the security clip. Panel states Error 5. I can restart it manually but cannot attach the clip without triggering the error message and stopping the treadmill.
ernesto cuadra
Level 3:
Top Expert:
  • Precor Master 12,223 Answers
  • Posted on Dec 12, 2012
ernesto cuadra
Precor Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4078322
Points
34431
See the next step and fix it. God bless you
5 Related Answers
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on May 24, 2010
SOURCE: Error message reads: Pace error #1
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and EEPROM checksum during the power up test sequence. If a fault is found during the power up test sequence, the appropriate error code will be displayed.
These errors messages almost always indicate an upper console problem when they are consistently displayed. Failures causing these error messages to be displayed are rare.
If the error message is consistently displayed when the unit is powered up, the upper console should be replaced.
Anonymous
  • 15 Answers
  • Posted on May 28, 2010
SOURCE: the treadmill stop when i increase the speed and t...
Error 26 is what's known as a Motor Pulse Width Incorrect. It basically monitors the sensor signal and verifies that it's appropriate for the requested speed. If your machine uses an infrared sensor, check the line of sight between the optical eye and the sensor target, an array of black and silver wedges arranged like a pie. Ensure that it is 3/16" apart and that it's pointed at the larger point of the wedge section. Use an electronic cleaning compressed air cleaner to blow out any particles that could block it. Have a close look at the target, if it's torn or badly scratched, it will need to be replaced.
If the machine uses a hall effect sensor (magnetic) ensure the distance between the flywheel tooth and sensor is 3/16".
You can sometimes get this error if the speed sensor is faulty, but usually it will happen without you even touching the controls at that point because the lower board isn't receiving any signals from the sensor, or you will get a different error code.
Anonymous
  • Posted on Feb 12, 2010
SOURCE: What does code 22 mean?
Error 22 - No Motor Pulses at Start Up
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Anonymous
  • 218 Answers
  • Posted on Aug 12, 2010
SOURCE: Treadmill stopped. Reads "belt error"
clean the speed sensor off the motor
Anonymous
  • 2080 Answers
  • Posted on Mar 01, 2011
SOURCE: While I was running on
First of all, here is a direct link to the ONLINE USER"S MANUAL for a similar model (9.31):
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
If your treadmill is similar enough to the one in the manual, then there are multiple safety features incorporated into the machine. See page 9 and 10 of the ONLINE USER'S MANUAL for detailed instructions on their operation.
Acccording to the manual, TO RESUME RUNNING after the safety switch trips do the following:
Reattach the magnetic safety key to the display console.
Straddle the running belt.
Press QUICKSTART or the SPEED UP ARROW.
If required, enter the SAFETY CODE (which is 1234 unless previously changed by owner).
The belt should begin moving slowly again, so just step back on carefully while holding handles.
See page 50 of the Online User's Manual for more details about the SAFETY CODE to unlock the belt. As stated, the default Safety Code from the factory is 1 2 3 4.
Please comment back here to this page if you have any questions, have difficulty accessing the link, or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page. The ratings are important and I truly appreciate your time and consideration.
Thank you very much and good luck.
Joe.
1helpful
2000 Nissan Sentra 1.8 has hard start acting lot not firing and finally starts and immediately runs great. .
Check fuel pressure after it's been sitting for a while. It should be within 5-psi of spec. If not, you have a bad check valve in the fuel pump.
Start for just 1/3 second then stop with error PF ?
Hey Andy, thank you for your post!
From what you have described your Frigidaire dryer, GLEQ2152ES, is running for a few seconds and then displaying an error code of "PF". The error code of "PF" means there is a power failure and this could be an issue within your control panel or power source. I would suggest performing a reset, this could help clear our any miscommunications within the panel, and you can do this by disconnecting the power cord for at least ten minutes. I hope that this information is helpful towards your repair. -Matt
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
My precore 9.43 starts to run then in 5 seconds turns itself off. Says ERROR- nothing more.
proceed according and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
Precor 9.35 Error 5
please see the details and proceed according. God bless you
Hi, I have a Canon MP620 printer and I bought compatible ink with a chip. I installed it and there is an error u140 which states that it does not recognize the cartidge. Would appreciate it greatly if...
Hello!
Here is your solution.
1. If your replace only one cartridge follow the step. = Press Stop/Reset button for 5 seconds............. after that your printer will start its process. 2. If your replace both cartridge follow the step: = Press Stop/Reset button for 5 seconds ............ after 5 seconds wait for few seconds. Your printer will show the same error, so press for 5 seconds again.... thanks
1helpful
I have almost same problem. This problem start one time when I using my computer. Computer always stop after trying restart, sometimes start normally and stop after few second. And now when I start...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
make sure that your RAM is securely seated
hope this will help
don
What could cause your truck to stall out, instrument panel lights to all come on and then within a few seconds restart without turning off the ignition. The vehicle will always restart once the key is...
No it sounds like you have a igntion switch problem or a control module problem contact your local dealer to have this checked out I think there maybe a service bulletin for this concern.
1helpful
After self clean the door will not unlock. Tried resetting circuit breaker several times. Tried to restart the cleaning and cancel after 15 min. Tried restarting cleaning and cancel after 1 min. Tried...
Hi
Thanks for using FixYa. There is an over-temperature switch built into the electrical panel of the oven. Resetting this switch solved my problem.
To reset it: Turn off the power. Open the door (if door is locked, turn the power back on and gently try pulling the door every few seconds as the locking mechanism cycles until it is unlocked). Remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven). Pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
