Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Wather tru the door and ice maker wont work on our year old
We have taken the line apart and there is water going to the frig but doesnt come any further
  • MarkPK Jan 17, 2009
    Icemaker works but water device doesn't
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 310 Answers
The water line hooks up to a device called a solenoid valve. Check to see if the electrical harness is attched firmly to the solenoid. If it is, the solenoid is probably burned out, or the switch that you place the glass against is bad.
Posted on Jan 13, 2009
I have a frigidaire refrigerator with a top freezer , I put a ice maker in and the water is going to the bottom of the frig but not going up the line to the ice maker , but you can't hear the ice make
if the water is turned on you probably have a bad valve take the line off of the valve
at the back of the refrigerator see if you have water if you do its the valve
Oct 10, 2014 | Frigidaire Refrigerators
Why does my ice maker is frezz up, and will not turn to make ice
I'm having a similar problem. Water freezes in the mold, but thermostat does not heat ice to release ice from mold. I replaced the thermostat and still did not work. I just noticed the plastic around the copper line that touches the mold prongs is melted. I guess it shorted out. You may have the same problem. Time to buy a new ice maker even thought the frig is only 1.5 years old.
Aug 16, 2014 | Whirlpool GI6FARXXy French Door...
Ice maker won't make ice
With ice makers it is almost always one of two things. The ice maker itself, or the water valve. Figuring out which one is easy, and I will help explain.
First thing is the frig has to be cold enough for the ice maker to even start working. I'm assuming we have the cold part taken care of. Next, the machine will start a cycle and ask for water. Here is where the valve comes in. The ice maker energizes the valve and it opens allowing water to rush up the back of the frig and into the ice maker. After the ice freezes the ice maker goes into harvest and dumps the ice.
In conclusion, you either have an ice maker that stalled at some point during that cycle (in which case you need a new ice maker). Or the water valve is not opening, thus no water enters the ice maker and you get zero ice.
If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
At this point you will hear the water valve energize or not. If it never energizes, the ice maker is not working right, if it energizes and you get squat, the valve needs to be replaced.
If you have experience with a multimeter you could detach the harness going to the ice maker and simply hook up your leads. When the ice maker asks for water, you should get 110v reading on the meter. If you do, the valve is bad and needs to be replaced.
If I can be of any further assistance please let me know. good luck!
Oh, and the valve probably sells for between $50 and $100 depending on where you buy it. The ice maker should run between $100 and $180.
P.S. There is a remote chance the filter needs to be replaced. An old filter can cause water pressure issues and you may not get enough water into the ice maker.
May 29, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Apr 08, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Jenn air side by side refrigerator ice maker not working
On mine the water inlet feed tube would freeze solid. Removing the ice tray and using a hair dryer to completely thaw the tube would get it working for another month or so. My frig had a solid rubber inlet tube. I noticed at the appliance store that newer models had an inlet tube that was split on top. I got one of these from a local appliance parts store, and it fixed the problem. The tube replacement it easy. Get to the back of the frig. Turn off the water supply. Carefully pry the white plastic piece out ( located on the upper right side when facing the back of the frig. ) of the frig. When you have the new one in hand it will be clear what you are going to do. Pull out the old remove the water line. Attach the line to the new tube and insert it. Turn on water, check for leaks, and you should be ok. This repair is only effective if you have an inlet tube that freezes up. There can be many other malfunctions that stop ice makers from working. This was my problem. Replaced the tube 3 years ago and ice maker has worked fine since the replacement.
Nov 16, 2008 | Jenn-Air JCD2389G Side by Side...
Water dispenser will not work when lever is pressed. we had an intermittent problem with it before it stopped working altogather.I was going to look at it but was afraid to pop off the trim on the outside...
This could be a bad water valve in the frig. This frig has a double water valves. One for the ice maker and one for the water dispenser. It should be in the lower back. Where the water line goes in. You can check this valve easily. Find the double water valve on the frig. Turn off water supply to frig first. Swap the plastic water lines going from the water valve into the frig. Turn water supply on. Then see if the water dispenser works. Sometimes you will have to operate the water dispenser for a little while to get the air out of the line. If it works now then the problem is in the water valve solenoid and needs to be replaced.
Nov 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
Frig.
Make sure you check your water supply and filter if you have one. Check the ice maker. Make sure the motor and gears are turning in the ice maker itself. As the ice maker goes through the cyle it activates the water solenoid for about 5-10 seconds at a certain piont to fill it. If the ice maker isn't running the ice maker will not fill.
Apr 20, 2008 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
63 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
