Question about Electrical Supplies
I need a replacement gas tank fuel level "bubble" gauge for a Valsi 5500 watt generator. product # ex2700521306707 ser# 2198652
  • 18 Answers
SOURCE: Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Posted on Sep 19, 2008
  • 62 Answers
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
Posted on Apr 07, 2009
pic498
  • 32 Answers
SOURCE: no electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
Posted on Jun 13, 2009
  • 57 Answers
SOURCE: Valsi Generator 7500W no output voltage
If its a Generac could be the voltage regulator or control board. If you want to go inside then disconnect the avr (voltage regulator) from the field and put 12 volts to the field slip rings with a car battery. Watch Polarity.... Yu should get about 60-80 volts out of the 115 receptacle. Plug in a light bulb and see if it lights. If it does then the field and stator are probably ok and you need to look elseware. Make sure breakers and connections are ok from the stator and receptacle.
Posted on Jul 29, 2009
SOURCE: Need a manual for Electra Gas Generator 5500 8200
I can give you the "OWNERS MANUAL" for the 5500/8200 Model 16172 Electra generator, but I don't think that is what you're looking for, is it? I purchased the generator at the Navy Exchange and got the 3 year warranty on it. When it suddenly wouldn't start going into it's third year, I contacted the warranty center and they told me where to take the generator for repair. That shop worked on it and finally got it to start, but when they attempted a second start - the starter 'dogs' hung up and were destroyed. The shop attempted to locate parts, technical services, etc., for Electra, but couldn't find anything and the warranty center finally returned my purchase money and the shop sent the generator back to the warranty center. Does the manufacturer still even exist? Don't Know.... Tom.... Pensacola, Fl
Posted on Aug 02, 2009
I have a valsi 5500 generator, I would like to rebuild the carb I need to find out what parts I need. and lately it just started putting out 95 watts, need to figure on what it is causing it.
You may only need to give it a good cleaning. Get some "Sea Foam" carbureator cleaner Homepage Sea Foam Sales Company Simply take the carb off and clean it thoroughly with the Sea Foam product and you probably won't need any parts. Also, be sure to add a fuel stabilizer to your fuel supply. "Stabil" is a good product for this.
Oct 16, 2014 | Electrical Supplies
5000s diesel will not start even on ether
mmost engines have a low oil switch. if generator is not level or it is low oon oil by just a little it will not start hope this helps bob
Mar 04, 2013 | Pramac Diesel Generator 5500 Surge Watts,...
Motor was loping i cleaned plug and filter now it runs like 3 min n quits
carburator needs to be cleaned,and put new fuel in the tank as well as a gas stable product
Jun 07, 2011 | Briggs Stratton Portable Generator 305cc...
We have a Valsi 5500 watt generator that isn't putting enough voltage out to run everything in out small travel trailer. It runs the lights but doesnt push out enough voltage to carry the A/C, microwave,...
How long have you had this generator?
Has the generator worked on all of these loads before?
Model 5500 is a 5500 Watt generator which could easily be 5500 watts (Peak) and not continuous.
Your AC is an inductive load.
Your lights are resistive loads
An inductive load can cause issues when starting due to an increased current demand at start up that some generators cringe under. Do the lights flicker or are they stable? I'd say your diodes on your stator are working if you have light stability but you haven't provided nearly enough information for a detailed solution.
I'm sure you have enough voltage but you aren't getting enough current to run specific loads. How many watts is your AC? How many watts for your microwave? Both of these units demand a great deal of energy to run and when you place too much demand on your generator, it will choke it out and eventually, will cause damage to the generator. You may consider getting a beefier generator with a greater amount of wattage output.
Seeing these specs online and noting what you are trying to run, you have an undersized generator and need to get one that can produce a greater amount of running wattage (as well as peak wattage).
Apr 12, 2011 | Watts Onan Portable Generator - 4000 ,...
I have a valsi 7500 watt 13 hp with tecumseh enduro xl/c engine-its extremely loud and wouldn't stay cranked. My ex - an ''idiot'' worked on it without my knowledge - we now have lines that we don't know...
Valsi 7500 watts/13hp tecumsa engine. Was running fine and then started surging like it was going to die and then it ran out of gas. Put fuel in it and now it wont start. Gets fire and has plenty of gas. Problem???
Jun 23, 2010 | Electrical Supplies
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
Have a VALSI 5500 watt generator that works fine but the tank has rusted out and I cant find where to purchase a new one. Can you help me find where to purchase this tank
We had problums with this one also. If you absolutely cant find a tank repair it.
A motorcycle shop in your area has no doubt had plenty failed tanks to repair. and then have it plastic coated on the inside.
The problems stem from the use of fuel with ethanol it attracts watter and dosed not work well in a gen set that spends lots of time setting.
Begin using fuel with a fuel stabiliser and keep it full, Air also has water in it.
r/
David
Jan 05, 2010 | Watts Onan Portable Generator - 4000 ,...
5500 marquie gold startes run for a few nim thin
shut fuel off at tank, pull fuel line off carb ,slowly turn on fuel if fuel flows freely(real good stream)your carb needs replacement(cant buy parts to rebuild EPA) if fuel just barely trickles out . there is a screen in the fuel tank that is probably clogged
Jul 23, 2009 | Watts Onan Portable Generator - 4000 ,...
VALSI 5,500 WATT GENERATOR WILL NOT START
All generators need to be run once a month. All things from the tank to the and including the carb will get gummed up with dried out fuel. I have a whole house generator and a 5500 watt gen set on my motor home. I keep fresh fuel in the stand alone house generator in California in case of a bad earthquake. I drain the gas after every run and keep all vehicles full of fuel just in case. Run gen sets at least once a month or pay pay pay!!
Apr 05, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
156 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
