Question about Dishwashers
U1 problem and beeps constantly after getting half way through cycle
When i insert a video castes it start halfway& beeps on & displaying c:31:23 on LCD screen& not working at all
Posted on Dec 12, 2012
2 Suggested Answers
your_applian
  • 15 Answers
SOURCE: DCS bottom dishwasher drawer u1 code: begins
Hi there Ypowers, U1 fault code relates to the fill system. Is the tap turned on, is the spray arm position correctly and free to rotate, nothing blocking it?. I hope this helps regards Gary.
Posted on Nov 14, 2011
ENGEL STILL GETS COLD BUT RUNS VERY HOT AND USES MORE POWER
FRIDGE COILS SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
Feb 27, 2015 | Engel MT-35F-U1 34 Qt Portable...
Why i hear constant beeping in my 2012 Jetta ?
Beeping with no lights on normally means a dis-connected wire to the oil pressure sender. Check the connection to the oil pressure sender and the wire too for internal damage.
May 04, 2014 | Volkswagen Jetta Cars & Trucks
DCS bottom dishwasher drawer u1 code: begins cycle, runs a couple minutes then stops and beeps
Nov 08, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have fisher&paykel.dishwasher.nautilus, half way through the washing,it beeps non stop and shows me U1 . AND IT DOESNT WORK SO I HAVE TO START ALL OVER AGAIN
U1 fault if caused by several things: water supply not turned on (I doubt that), unit is syphoning causing not water in tub to be detected during cycle (this is possible if the drain system in incorrectly installed), spray arm in the drawer is not in place or get moved somehow, excessive foaming (wrong soap or too much), inlet valve failed, controller failed, or rotor not fitted correctly.
I would inspect this issues and locate the reason the unit will not complete the cycle, you may end up replacing the controller in that drawer to fix the problem (as a last resort).
Good Luck
Oct 11, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Control panel beeps constantly. Have to unplug to get it to stop. Once it's plugged in it will begin beeping again within 30 min.
Hello- The control is not happy. Depending upon the number of 'self-clean' cycles, control may have failed. Find a good tech to check it out. Replacement board w/overlay is about 200$. Let me know if this info helps- have more if needed. -Thanks- ED
Mar 06, 2010 | Frigidaire PLGFMZ98GC Kitchen Range
F & P DD603 starts to wash then beeps & flashes U1 - Fill Fault. I have cleaned both drawers & replaced all parts correctly, still comes up with U1.
Have you checked whether you are getting the water supply to the dishwasher. Check if there is no kink in the water hose.
If no problem with water supply then check the water pressure rating is OK for the dishwasher.
Dec 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
Problems with my MODI XEROX 5216
It can not copy. When I power on after 30 seconds the copier show U4 in the screen and do not work.
Mar 13, 2009 | Xerox Office Equipment & Supplies
Hoshizaki ice machine with constant beeping every 3 seconds
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
Jun 23, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
Owen Barnes
