My philips tv 40PFL7505D/F7volume drops to nothing for no reason
Volume drops to nothing for no reason after 10-20 minutes
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Check it with a DVD connected to the rear inputs, may rule out some things.
Posted on Dec 12, 2012
I own a 40 inches philipps model 40PFL7505D, there is a blackout after about 2 hours of listening. The sound is also out at the same time. That's happening like 3 times a minute and the tv is still working...
If you are sure the set is getting a good sound signal the ask Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en A lot of HD cable systems have breaks in the sound transmission. It drives me nuts.
Feb 11, 2015 | Philips 40pfl7505d/f7 40-inch 1080p 120 Hz...
My philips srp5107wm/17 only changes the volume on my tv no matter what device i have it set on
The Philips remote is set to "push trough" the volume/mute to the TV for devices that typically don't have a volume function. Older versions of Philips remote used to allow you to select the device to push volume to, but for some reason this is no longer available (or at least I haven't found out how to). So here is the solution I used.
Teach (learning function) the remote to use whatever device you like for volume/mute.
1, Press the button for the device you would like to change
2. Hold down "learn" and the button you want to teach ex. "volume up" until the red light comes on
3. Place the original remote of the device you would like to change the volume on 5-10 cm away from your Philips remote and press "volume up" for this example
4. Repeat these steps for the "volume down" and "mute" buttons
5. Repeat these steps for other devices you would like to "push through" volume/mute to a device other than TV
Hope this helps others. I did find that some devices like SAT may not allow you to change the volume/mute, but otherwise this workaround does the trick.
May 05, 2012 | Philips SRP5107WM - Universal remote...
No picture
Good afternoon to you. This is annoying I hope you can put it right,
The advice I have is for you to go into the PICTURE MENU and adjust the brightness and contrast.
good luck
kolbrun
Apr 15, 2012 | Philips 40 40PFL7505D LCD TV
Philips 40pfl7505d5/f7 hd doesn't work
Where are you connected on the set for HD and what is signal source for it you are using?
Mar 15, 2012 | Philips 40 40PFL7505D LCD TV
I have a Tv Philips model 32PW6506/01 few minutes after that is between 10 and 20 minutes go stand by, then if I press p + start and after 10,20 minutes and goes into standby ...If anyone knows about...
Good day!
Usually that problem is cause of the failing capacitors on the power supply section.
You have to do is open the back cover of your TV and look for the actual image of the capacitor with in the power supply section if it is leak/bulged on the top.Please replaced it with the same type,ratings and value.
Thank you and good luck.
May 08, 2011 | Philips 32PW6506 32" TV
Intec G8621 Wireless Remote Control For Xbox 360 - Need Codes
Does any one know the code for the PHILIPS model 40PFL7505D/F7 HD
Mar 08, 2009 | Sony KV-32FS13 TV
Philips 28pw6515/05
Good old cash generator, make one wonder why they are there in the first place doesn't it.
Sep 16, 2017 | Philips 28PW6506 28" TV
Philips magnavox tv volume control
if your are using a remote control,your volume button is shorted,and of you are using your manual control,your tact switch in volume is defective try to replaced  another one.
Oct 18, 2007 | Philips Magnavox PR1906C 19" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
