Question about LG RZ-20LA70 20 in. LCD Television
Lg rz32lz55 lcd tv no picture no sound
I have an lg lcd tv it powers up but has no picture or sound. it turns on by remote with a click sound but the backlight fades and it turns back to standby mode.
please can you help
  • Anonymous Mar 15, 2009
    i have an lg 42 inch plasma tv when i turn it on there is no picture or sount it goes from greeen back onto standby.
5 Suggested Answers
SuperTech-11
  • 1591 Answers
SOURCE: Sony KDL40V2000 LCD TV not
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 25, 2011
  • 2311 Answers
SOURCE: LG RZ32LZ55
There could be two possible failures:
1. The backlights are defective (not a common failure for a 14 months old LCD) or the backlights driver/inverter is defective.
2. Power supply failure(very common failure on LCDs) will cause the symptoms you described.
Posted on May 22, 2008
SOURCE: lg plasma 50px4d-eb keeps going into standby mode
no solution, yet... our tv is under warranty, and this is the 2nd time we are going to have to have the SAME problem repaired, and they replaced the whole "INSIDE" the first time!!! so, same problem, 2 different panels, must mean somethings going on, you crappy Sony, you! *shaking fist*
Posted on Jan 20, 2010
budmrtn
  • 11361 Answers
SOURCE: Problem with the LG RZ32LZ55 32 in. HDTV-Ready LCD
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 21, 2010
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
LG LCD 42" sound but no picture
From this web site it says:
http://www.ehow.com/about_5379235_lg-television-problems.html
Powering Off
  • Many LG LCD television owners report having a problem with their televisions where the screen powers on, but then lasts only a few seconds or a few minutes before powering itself off again. The problem usually occurs with brand new televisions, and in this case is inside the television itself. If your television is powering off unexpectedly, contact LG so it can be serviced.
Read more: http://www.ehow.com/about_5379235_lg-television-problems.html#ixzz2qeK8T3SU
Jan 17, 2014 | LG 42LC2RR 42 in. HD-Ready LCD TV
How to change aspect ratio on lg rz-32lz55?
Any chance you are using a box with this set for signal?
Dec 17, 2012 | LG RZ32LZ55 32 in. HD-Ready LCD Television
How do you connect the Virgin VHD box to LG RZ32LZ55 TV for getting HD and also the audio. For the audio the V HD box has a optical audio port and a test port ( i am not sure it works!). The TV has a DVI...
All you need is an hdmi-dvi adapter. You will also need a component audio lead to plug into the mini(3.5) jack socket on the tv as dvi does not carry sound. You will need to initially use the scart to set up your tv for hdmi as the menu can only be seen via the scart until you set it up.
Jul 24, 2010 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Connect tv to cable box with hdmi lead
You will need an HDMI to DVI cable which are available in the shops, even ASDA has one but I don't know how good it is. Or you can buy an adapter that will plug into one of the ends of the HDMI cable and then plug into the DVI socket at the back of the TV. The DVI input is video only so you will need audio leads for sound. These will connect from the output of your source, say, blue ray or sky HD (Left and right audio sockets ) to the audio L/R at the back left of the TV (on the block next to the three component video connections and s-video connections)
Oct 03, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Are all rz-32lz55 hd ready
hi I have the same TV and have been tring for the last year to find someone that know's how to set up the HD. I can get the Picture but no sound for the HD have been told many way to get the sound but does not work. if you find out let us know.
Sep 30, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
No picture but sound is still there
The main display driver board, part of the driver board power supply, and or the lamp supply, or the lamps themselves could have a problem. In some cases the LCD panel itself may have a failure.
The best solution is to take the set to an authorized service rep who has spare working boards and modules to try. This way he will be able to tell you exactly what is involved to service the set.
If the set is out of warranty it will be expensive to service.
Jerry G.
May 27, 2008 | LG RZ32LZ55 32 in. HD-Ready LCD Television
LG RZ32LZ55
May 22, 2008 | LG RZ-20LA70 20 in. LCD Television
LG RZ-20LA70 20 in. LCD Television Logo
2,464 people viewed this question
Computer Repairing
Computer Repairing
