Question about Lionel The Polar Express Train Set
Headlight not working - Lionel The Polar Express Train Set
Lights will not turn on
HEADLIGHTS NOT WORKING
It can be faulty headlight switch or issue with its wiring. Or its faulty head light fuse.
To troubleshoot the issue i suggest you few help links with appropriate solution. So you can follow the test and confirm what exact problem is there in your case of headlights not working:-----
Click the link below: -----
All headlights not working?
http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
Working of Headlight switch?
Both headlight bulbs blow together?
Car headlight bulbs don't last long?
2007 Dodge Caliber: Low Beam Headlight Not working
http://technoanswers.blogspot.in/2012/06/2007-dodge-caliber-low-beam-headlight.html
2003 Toyota Camry: Headlights Work Intermittently?
http://technoanswers.blogspot.in/2012/04/2003-toyota-camry-headlights-work.html
Chevy Tahoe: Low Beam Lamps are not working?
http://technoanswers.blogspot.in/2012/04/chevy-tahoe-low-beam-lamps-are-not.html
2001 Chevrolet Tahoe: Headlights not coming ON?
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-headlights-not.html
2004 Dodge Ram: High Beam Light is DIM?
http://technoanswers.blogspot.in/2012/04/2004-dodge-ram-high-beam-light-is-dim.html
2001 Chevrolet Tahoe: Both Low Beam Lamps Not Working?
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-both-low-beam.html
Low beam headlights Modification?
http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
How to Replace a Headlight
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
How to Replace a Headlight Bulb
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-bulb.html
How to Replace a Headlight Switch
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Headlight Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-assembly.html
How to Replace a Park Light Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
Headlight Assembly Removal On Honda Accord
http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html
Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html
How to Replace a Headlight Door
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
How to replace HID headlight bulbs for lexus 400h?
http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
These will help.
Thanks.
Nov 28, 2012 | 1986 GMC K1500
REPLACE HEADLIGHT 2008 SPRINTER
On some cases there are few hidden clips holding the assembly from under hood,that has to be released to remove headlight .
There are few troubleshooting help links showing how to replace car headlights,i suggest you to refer the links to solve these issue.
Click the link below:------
How to Replace a Headlight http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
How to Replace a Headlight Switch http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Park Light Assembly http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
Low beam headlights Modification? http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
Headlight Assembly Removal On Honda Accord http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html --------------- Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html-----------
How to Replace a Headlight Door http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
All headlights not working? http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
How to replace HID headlight bulbs for lexus 400h? http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
These will help.
Thanks.
Nov 23, 2012 | 2010 Mercedes-Benz Sprinter
How do I get to the front headlight to change it
Re: Replace headlight bulb
  1. INSTALLATION GUIDE:
  2. BMW E38 99-01 HID TYPE 7 Series 1PC Halo Amber Projector Headlights
  3. Parts Identification:
  4. Projector Headlight
  5. Halo & L.E.D.
  6. Bottom of the Headlight:
  7. Ballast Bracket, Halo Wires(red/black)
  8. Turn Signal Adaptor
  9. TOOLS REQUIRE
  10. 10mm - 8mm socket
  11. Philip Screwdriver
  12. Crimper/Pliers
  13. For more information about how to install your vehicle, come visit our youtube page on
  14. http://www.youtube.com/spyderauto
  15. Remove the facotry headlight from the BMW. First remove the front panel cover below the headlight to access the bottom screw of the headlight housing. There is also two screws on the top of the housing.
  16. Once you have remove the headlight, turn the headlight around and remove the bracket that holds the Ballast. Then remove the ballast using a philip screwdriver.
  17. Unplug the wire from the ballast, and then remove the Xenon Plug from the housing. Put the Ballast aside.
  18. Carefully remove the D2S Xenon Bulb from the factory housing. Once you have remove the bulb, transfer the bulb to the Spyder headlights.
  19. Remove the bracket from the Spyder Headlight, and then install the ballast on the housing like the original. Once you have put the ballast on, put the bracket back on.
  20. Remove the Panel Cover bracket from the original headlight to the new Spyder Headlights as shown here.
  21. STEP:
  22. Install the Spyder turn signal socket if the orignal does not fit, unplug the factory plug from the harness and plug the new one on.
  23. Install the Spyder Headlight back on to the vehicle. Plug the Harness back on, the halo/L.E.D. Wires is connect to the Parking lights. These wires are optional to your vehicle, you do not have to wire them together.
  24. Factory Xenon Headlight
  25. Spyder Projector Headlight using Factory Xenon Lights
  26. STEP:
BMW e46 HID Headlight Replace
Nov 22, 2012 | Cars & Trucks
Headlights wont work and dash and parking lights come when ignition switch is turned on. sometimes jiggling wires works. what is the problem?
Check out related help links with solutions to troubleshoot these problem.
Click the link below directly:---
Heater fan and headlights will not turn off with ignition off? http://technoanswers.blogspot.com/2012/01/heater-fan-and-headlights-will-not-turn.html
High beams stopped working but headlights still work?
http://howtobyme.blogspot.com/2011/11/highbeams-stopped-working-but.html
Only one head light works on 2001 Dodge Caravan? http://howtobyme.blogspot.com/2011/11/only-one-head-light-works-on-2001-dodge.html
Headlight Assembly Removal On Honda Accord http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html ------------- Honda Headlight Assembly Removal
Headlight wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/headlight-wiring-diagram-for-1997.html
Dash Lights And Front Marker Lights Flashing On And Off http://schematicsdiagram.blogspot.com/2012/10/dash-lights-and-front-marker-lights.html
---------- 2001 Chevrolet Tracker: Headlights and Dash lights Pulsating? http://whoisbyme.blogspot.in/2012/06/2001-chevrolet-tracker-headlights-and.html
--------- No parking lights and headlights not turning OFF? http://technoanswers.blogspot.com/2012/01/no-parking-lights-and-headlights-not.html
------------- How to replace HID headlight bulbs for lexus 400h? http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
--------- Head Lights Comes ON by Itself? http://whoisbyme.blogspot.in/2012/07/head-lights-comes-on-by-itself.html
--------- Only high beams work but head lights not working on Ford F350?
http://howtobyme.blogspot.com/2011/11/only-high-beams-work-but-head-lights.html
Only high beams working on GMC Savana?---------
How to replace Headlight Bulbs on Lincoln Town Car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-headlight-bulbs-on.html
How to change headlight?
http://repairhelpcenter.blogspot.com/2011/12/how-to-change-headlight.html
Both headlights and turn signals not working? http://schematicsdiagram.blogspot.com/2011/12/both-headlights-and-turnsignals-not.html
Headlights will not turn OFF on Ford expedition and car trailer?
http://technoanswers.blogspot.com/2012/01/headlights-will-not-turn-off-on-ford.html
Headlight Assembly Removal on 2010 buick lacrosse? http://technoanswers.blogspot.in/2012/04/headlight-assembly-removal-on-2010.html
--------- Headlights flickering and car hesitates to start?
http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html
Hummers headlights flashes while start?
http://technoanswers.blogspot.in/2012/02/hummers-headlights-flashes-while-start.html
Using non-AFS headlamp assembly for AFS assembly?
http://schematicsdiagram.blogspot.in/2012/02/using-non-afs-headlamp-assembly-for-afs.html
How to replace Headlight Bulb on 2001 mitsubishi magna
http://www.howtorepairguide.com/2012/10/how-to-replace-headlight-bulb-on-2001.html
These details will help.
Thanks.
Nov 22, 2012 | 1996 Pontiac Grand Am
High beam headlights stuck on replaced switch same problem
It can be issue with headlight switch,but as its already been replaced.Try disconnecting high beam headlight wiring from headlight assembly and reconnect direct external wire from headlight switch to headlight assembly,then by switch see if headlight is getting off and turning on or not.
See below related help links,similar to your issue.Click the link below:----
Only high beams working on GMC Savana?---------- High beams stopped working but headlights still work? http://howtobyme.blogspot.com/2011/11/highbeams-stopped-working-but.html
---------- Working of Headlight switch? ----------
------------ Only one head light works on 2001 Dodge Caravan? http://howtobyme.blogspot.com/2011/11/only-one-head-light-works-on-2001-dodge.html
these will help.
Thanks.
Nov 06, 2012 | 2007 Chevrolet Tahoe
Headlights
For all types of car headlights repair and service issues.Click the link below and follow the troubleshooting:----All headlights not working? http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
--------headlights flashes while start? http://technoanswers.blogspot.in/2012/02/hummers-headlights-flashes-while-start.html
---------Headlights flickering and car hesitates to start? http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html
----------Both headlights and turn signals not working? http://schematicsdiagram.blogspot.com/2011/12/both-headlights-and-turnsignals-not.html
--------Headlight wiring diagram ? http://technoanswers.blogspot.in/2012/02/headlight-wiring-diagram-for-1997.html
---------This will help.Thanks.
Feb 19, 2012 | 1999 Kia Sephia
2002 ford focus headlights inop
All types of car headlight problem troubleshooting.Click the link below :---All headlights not working? http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
Feb 12, 2012 | 2002 Ford Focus
My headlights work on brights but wont work on
might have to replace the headlights/bulbs. I have an 85 rx7 and I didnt have low beams only high and I replaced both headlights and now they work.
Oct 19, 2009 | 1994 Mazda RX-7
Lighting systems
Dear Sir/Madam,
  1. Check your fuses. The plastic panel covering the fuses should have a diagram detailing what each fuse covers. If yours is missing, or unlabeled, check your owner's manual, or a Hanes(tm) or Chilton(tm) repair manual. Often if a headlight is not working, it is the result of a blown fuse. Fuses have a wire running through them that will melt when too much current is run through them. If the fuse is blown, the wire will be broken. If the fuse for the headlight you are working on has an intact wire, it is likely the problem lies elsewhere.
  2. Swap the headlight for its twin. If your left headlight does not work, put the light from your right headlight in its place. If it works with the other headlight in place, your headlight bulb is dead, and needs to be replaced.
  3. If this does not work, try using a voltmeter on the plug for the bad headlight. Turn on the ignition, and turn the headlight switch. If the voltmeter shows no current, then either your switch or the wiring leading to the headlight has gone bad.
  4. If replacing your headlight switch does not solve the problem, then there is a break in the wiring leading to the headlight, and the wiring will need to be replaced.
Thanks
Good Luck
"Don't Forget to rate the solution"
May 28, 2008 | 2005 Jaguar XJ-Series
Lionel The Polar Express Train Set Logo
48 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
