Question about HP Pavilion dv5170us Notebook
How do you turn spell check on hp pavilion dv5
Is this feature available?
  • HP Master
  • 7,627 Answers
In what software?
Posted on Dec 12, 2012
Geekman
  • 32281 Answers
SOURCE: sata driver for windows xp for Hp pavilion dv5 1102.
Are you trying to install Windows XP on your laptop that has a SATA drive in the laptop?
And during the Windows XP install it cannot find a hard drive?
The reason why Windows install does not work is because Windows XP does not have a SATA driver support and therefore cannot find the hard disk.
THE FIX FOR THIS PROBLEM.
Go into your BIOS and turn off Native SATA support or set it to IDE controller (this setting depends on the type of BIOS). Save the setting and reboot and you will be able to install Windows XP.
Posted on Mar 26, 2009
  • 74 Answers
SOURCE: how to bypass forgotten start up password
If this is a forgotten windows password in xp (not sure if it works for vista), you can download a program called NT Offline Editor which will allow you to blank or remove the password. This program is available from:
http://home.eunet.no/pnordahl/ntpasswd/
Much bigger problem if it is a bios password, that would take calling HP, proving ownership and then they can help you to get in and change or remove the password.
Hope this helps
Posted on May 02, 2009
  • 788 Answers
SOURCE: hp pavilion dv5 wont start. the monitor remains
This unit should still be in warranty. If out of the first year warranty, HP has extended the warranty program for Video issues for a extra year from date of purchase.
Register your unit with HP, if not already and email customer care and log your video issue, ASAP.
I hope this has helped you.
Posted on Oct 07, 2009
joecoolvette
  • 5660 Answers
SOURCE: hp pavilion dv5-1002nr will not power up
Let's run through a basic flow chart.
1.Plug the AC adapter, (Charger), into the laptop.
Is the Power LED light on, and the Battery charging light?
[The Power LED light is on the front edge of your laptop, all the way to the left.
There are three small rectangular LED lights in this area.
1) All the way to the Left - Power LED light.
2) In the middle - Battery Charging LED light.
3) On the right - Harddrive Activity Lamp {Light}
The HDD Activity lamp blinks when harddrive is in use]
Gently wiggle the AC adapter plug, that is plugged into your laptop.
Does the Power LED light and/or Battery Charging light, 'Wink' when you move the plug? (Blink)
Does it stay on when you keep it over to a certain position?
If so, you have either a bad plug on the end of that AC adapter cable, wires that are bad in the cable itself, or a bad DC Power Jack.
(The DC Power Jack, is the port where you plug the AC adapter in. May be labeled as DC IN)
Do you wish to test the AC adapter plug?
See if it has an intermittent connection, due to a break in the wires that meet the plug?
And/or, see if the AC adapter is putting out any voltage, and if so, the correct amount of voltage?
Do you have a multimeter?
A cheap, yet effective multimeter, can be purchased for around $10 to $12 at most auto parts stores. (Radio Shack has them, and a multitude of other stores also. Not an advertisement for Radio Shack)
Set the multimeter to DC Volts, (Turn the knob in the front), and if it has a separate setting, set it to DC Volts - 50 Volt scale.
Read the label on the AC adapter's case. You are looking for the OUTPUT voltage/amperage.
Example:
I'm looking at an Acer Aspire laptop's, AC adapter right now.
INPUT: 100 - 240V ~ 1.8A - 50/60Hz
OUTPUT: 19V === 3.42A
The Output voltage is 19 Volts.
AC adapter plugged into the surge protector.
The Red lead, (Positive), of the multimeter, (Right now it's being used as a Voltmeter), is inserted into the middle of the AC adapter plug.
The center of the plug is the Positive connection.
The Black lead, (Negative), is held against the outside of the AC adapter plug. The round cylinder of the plug on the outside.
This illustrates the AC adapter,
http://www.buy.com/retail/product.asp?sku=213337465&listingid=63465880
The photo shows the AC adapter charger body, attached to the cable with the plug.
To the top left you see the plug, and the shiny metal cylinder. The Black lead touches the outside of the cylinder.
Read whether you are getting voltage, and the proper amount of voltage.
Gently wiggle the plug back, and forth, and see if there is a break.
Voltage, no voltage.
If the AC adapter proves to be good, you have a problem with the DC Power Jack. (DC IN)
The DC Power Jack is on the right side, all the way to the rear.
The setup, and mounting for this DC Power Jack differs from most laptops.
Most laptops have the DC Power Jack soldered directly to the motherboard, or are soldered to a separate small circuit board, that plugs into the motherboard.
This jack has a cable leading from it, and the jack attaches to the bottom case of the laptop, via a small bracket.
To illustrate what I'm referring to here, you may want to download, (Free), the Maintenance and Service Guide from HP Support.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=3753576&lang=en&
(Just click on the X, of the small survey window that comes up)
On this page Left-click on -
HP Pavilion dv5 Entertainment PC - Maintenance and Service Guide
(10th file down. This is a PDF file. The computer you are on now has Adobe Reader on it, which uses PDF files)
Give it a few seconds to download. It may take up to 20 seconds before you see the first page.
I advise wait, until it has fully downloaded before looking through it, or you may break the download connection.
Under the Bookmarks column to the left, click on the + sign next to - Removal and replacement procedures
Click on the + sign next to - Component replacement procedures
Scroll down, and click right on - Power connector cable
(Or use the blue down arrow above to go to Page 96)
Point of this?
If you are technically inclined, you could disassemble the laptop, and replace the Power connector cable.
The DC Power Jack is part of the Power connector cable.
[BUY and USE an ESD wrist s-trap. Connect the alligator clip to a good ground source. I use an empty desktop computer case, and connect to the metal frame.
Average cost is around $6 for this device. Can be found in a multitude of stores. Again, Radio Shack is one source, but there are many.
Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screws came out of.
You can use a clean egg carton in a pinch.
Make notes, and drawings as you disassemble. Use a digital camera if you have one available.
Check with HP to see if this part is available. I also would check online, and you may want to give thought to Ebay]
2. If the Power light stays on with no intermittent problems with the DC Power Jack, or the AC adapter:
A.There may be a problem with the Power On switch itself. (Under the Power On button)
B.The Ram Memory modules, (Slang is Stick), may have become jarred loose.
AC adapter unplugged, battery removed. Open the Memory Compartment, and remove all ram memory modules. Now reinstall them.
Reinstall the Battery, and then the AC adapter. (Then plug the AC adapter into the surge protector)
Power On the laptop.
C. The Harddrive might not have a good connection.
All power sources removed again, open the Harddrive, (HDD), Compartment.
Make sure the harddrive's plug is tightly connected.
(Page 62)
D.If none of the above cures the problem, then it's time to seek a professional, competent computer repair shop.
The charging circuit of the motherboard may be bad. There is a sensor that determines if power should come from the AC adapter, or the battery.
It also determines if the battery needs charging.
You may have harddrive failure.
[Again, if the shop does determine it to be a bad motherboard, AND you feel technically inclined, you may want to replace the motherboard yourself.
Check online, and also Ebay]
Posted on Dec 23, 2009
  • 1428 Answers
SOURCE: I want to restore my hp pavilion dv5 notebook to
Restart system and hold down the F11 function key till you hear a beep.
This will bring up the system restore dialogue, then follow the system prompt/ instructions.
Remember to backup your documents.
Good luck and rate this.
Posted on Jan 14, 2010
I have a question HP Pavilion DV5 Full
That is you WLAN card (Wireless locale area network card) it is what makes the laptop conect in hotspots.
Oct 23, 2013 | HP New Pavilion DV5-1000 DV5 Series Silver...
Hdmi not detected by HP Pavilion dv5-1235dx Entertainment Notebook PC
You may want to check your dispaly properties to make sure that your display is set to HDMI instead of laptop display in the control panel under display properties. On many laptops, this can be done by pressing the "fn" key and a key with a blue symbol of two screens on it. This toggles between your primary display and external ones.
Nov 23, 2012 | HEWLETT-PACKARD Pavilion dv5-1235dx...
Is the wifi card in an hp pavilion dv5-1235dx removeable
Yes it can be remove and Replace from back side. you can get new card from HP, which can Fit to your laptop and whie faster.ch will mor
Aug 15, 2012 | HEWLETT-PACKARD Pavilion dv5-1235dx...
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
I have a pavilion dv5 the wireless touch button is not working but all other button are working how to turn the wireless from the laptop itself without an external swith or touch button , ps: dv5 have only...
dv5 what , use the full model number.
what OS are you running, windows what?????
Why not get the correct HP drivers for wifi features.
from , drum roll..... HP?
ask here this is HP.
warning they wont help unless you answer the 2 questions above.
https://h30434.www3.hp.com/
Jun 20, 2017 | HP Pavilion dv5000t Notebook
Pavilion dv4000 PC Notebook: My hp pavilion dv5 laptop runs very hot and then t...
The easiest way to clean it is to use a can of compressed air and blow it through the airflow vents.
Check out this link for other solution.
http://bootmylaptop.com/laptop-shuts-off-after-a-few-minutes/
May 18, 2010 | HP Pavilion dv4000 Notebook
Problems with HP HP Pavilion dv5-1159se 15.4
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 29, 2009 | HP Pavilion dv5-1159se Laptop
How can I install Winxp on HP pavilion DV5 laptop ?
You're Hard Drive may be dead. If XP is starting to install and then it goes to the Blue Screen of Death, that's most likely your problem. There's a slight chance that you're power inverter has a fluctuating power level that is causing a disruption, but that's very unlikely. Have you done any tests with any boot CD's to check the hard drive's function?
Jun 09, 2009 | HP Pavilion dv5110us Notebook
HP Pavilion dv5170us Notebook Logo
69 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
