Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Frigidaire Washer/Dryer Combo FEX831CS0 won't work
Our unit was working fine until we moved. After getting it all set up the washer would not go into spin cycle, and now will not work at all. Help!
  • Official Brand Answer
  • 4,342 Answers
Hello Laura Clark - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Since it is such a complex unit, I suggest contacting a professional to move forward accurately
Posted on Dec 14, 2012
My kenmore 29822800 won't fill with water, it works on spin and drain
The last time I moved, my washer/dryer combo (Frigidaire) had the same issue for approximately 7 months before finding out all I needed to do was level the washer, and of course, make sure the faucet connected to the washer is turned to on position. Hope this is helpful.
Praysemema.
Mar 13, 2013 | Kenmore Washing Machines
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
I have a frigidaire stackable washer/dryer model number FEX831CS0 an the washer works but the dryer is seem not to be getting any power
Hello cbrhonda125 - Try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch. This is something that a professional would need to properly diagnose.
Dec 19, 2012 | Frigidaire FEX831CS Top Load Stacked...
Dryer hot but not drying quickly.
Sounds like you have a clogged vent. Hopefully you've gotten this repaired.
Feb 25, 2012 | Frigidaire Washing Machines
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
It leaks water after its about half full does it have a hole in the tub?
I doubt if the tub has a hole in it, BUT the increased pressure and weight of the half filled tub could force water past a damaged washer. How did the washer get damaged, probably by the spin bearing starting to fail.
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-dryer-combo-Parts/Model-FEX831CS0/1428/0152000/R0310016/00005?blt=06&prst=&shdMod=
Items 21 and 26 are the parts that I would suspect.
Jul 20, 2011 | Frigidaire FEX831CS Top Load Stacked...
I have a frigidaire stackable washer/dryer model number FEx831cs0. The washer is working just find but the dryer for a few weeks has been making the worst screeching sounding in the world. I am not sure if...
A loose belt often makes a squeak that pulsates with the clothes hitting the paddles in the drum. It's probably the upper drum glide or rear bearing. If it's a constant screech coming from the front, it's probably the glide. If the noise seems to be in the back, suspect the bearing. You might check for a sock or something small that is stuck somewhere between the drum and the dryer.
Glide: http://www.repairclinic.com/PartDetail/Drum-Slide-or-Glide/916658?modelNumber=FEX831CS0
Bearing kit: http://www.repairclinic.com/PartDetail/Drum-Bearing-Kit/1851?modelNumber=FEX831CS0
Neither are very difficult to repair.
Other parts for your machine:
http://www.repairclinic.com/Shop-For-Parts?s=t-%20FEX831CS%20-%3d%3d
Good luck.
Feb 28, 2011 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
187 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
