Question about iLive It202b 32" 2.1-channel Soundbar - ileit202b
I have followed directions to sink together tv remote and ilive speaker remote, it didn't work, n o what do i do?
I have a Ilive 10" tv with a Spectrum remote...what is the code
The applicable code will be in your Spectrum remote, if it is compatible with your iLive TV.
Jun 19, 2017 | iLive Televison & Video
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
Dec 29, 2015 | Samsung Televison & Video
Just bought ilive Bluetooth speaker. I paired it and it worked once then all of a sudden no music is coming from the speakers just my htc rezound phone. Bluetooth is still connected. Any solutions/
That happens sometimes with BT. Just reconnect. This is annoying, but the phone and/or ILive don't follow up standards that are not in place (yet)
Oct 02, 2012 | Cell Phones
Tr-606 directions for use and remote
As long as your television and system both have (audio/out jacks from tv, audio/in to system) and cables it should hook up. Not real sure what you mean about directions for the remote, the system I have didn't come with directions just starts working as soon as the system is hooked up. Hope it helps
Feb 08, 2012 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Have iLive ihs3 2.1 speaker system. The speaker was sitting on top of the television, roommate was dusting the tv screen and elbow touched iLive speaker. There was like a static electricity shock, and...
Unfortunately I don't think so. TV"s can develop a huge static charge & dusting would increase it... that Discharge was a huge shot of Static Electricity, most likely fried ya output devices...
Feb 02, 2010 | Audio Players & Recorders
INSIGNIA TV WITH ILIVE BAR. 1 SIDE WORKS
Try swapping your cables from the sound-bar to the TV. If the sound still only plays through one channel but the channel has changed from right to left or vice-versa, then you have a bad cable.
If the performance is the same, connect a different device using the same cables to see if it's the sound bar input or the TV output.
Once you know where the problem is (the sound bar, the TV, or the cables) you'll know what unit needs repair or replacement.
It is entirely possible that a solder joint for the sound-bar has come loose. A soldering pen would easilly fix this if it's a bad joint/connection.
Hope this helps!
Dec 25, 2009 | Insignia 200W Stereo Receiver
My iLIVE mod# IT188b will not turn on.... reset button not working either??? this is the second unit I have had(first one did the same thing)but was able to return without reciept...not the case this time!...
This particular unit has issues with bad solder connections on the main audio board which come loose because the woofer speaker vibrates them loose. I've repaired unit myself with a soldering iron.
Dec 02, 2009 | GPX 2.1 Speaker Bar with ipod Dock ...
iLive It202b 32" 2.1-channel Soundbar - ileit202b Logo
23 people viewed this question
Top iLive Audio Players & Recorders Experts
cwradio73
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
