Question about Dell Latitude D 600/610
Not powering up/power supply led goes out when plugging into into laptop
    Guru:
  • 571 Answers
Step 1:
Try removing the battery of your laptop and try using the ac adapter/power supply alone.
Step 2:
Check your power supply's wiring if it's loose or have some signs of defects on it.
Posted on Dec 12, 2012
Hp nx7400 laptop battery led blinking
probably ur battery is dead or your loading circuit is malfunctioning, due to internal circuitry overload most like to overheating.
Apr 11, 2014 | HP Computers & Internet
Mainboard caused short-circuit
I suggest you take it to a qualified repair agent, or if it is under warranty, return to the dealer or to Dell.
Mar 05, 2014 | Dell LATITUDE Computers & Internet
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
My sony vaio vgn-nw320f was totally dead.i had pulled up the battery cause it could not log off.please help me.....
Most sony laptop power supplies have a power LED that indicates if the device is A) plugged in {ok it happens!}, or B) fried and not providing power to the laptop. Check this first. If the power supply is plugged in and the LED is on (usually green or red) then see if you have ANY lights on the laptop itself. Its possible that your LCD display went bad but that the laptop is otherwise running. You may see a power, hard drive or wireless network light on if the laptop works but the LCD went bad. You can also connect an external monitor to the laptop and power it up to check the LCD.
I've also seen where the battery goes bad and it keeps the laptop from booting. Try removing the battery and power up (with the ac adapter plugged in) again.
If neither of these helps, you may be looking at some kind of internal short on the motherboard which is big money. Hopefully that isn't the case.
Hope this helps!!
Jun 20, 2011 | Sony VAIO VGN-NW320F/B Notebook
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
I goofed. I have a Toshiba Satellite A105-S206, and I will make this as brief as I can. I have had a string of super cheap power supplies that I have been using. The most recent one stopped...
Check for a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 06, 2011 | Toshiba Computers & Internet
Acer aspire 3610 power lead transformer green light is on before plugging into laptop then goes out when plugged in.acer has nothing working, totaly dead any ideas?
If the power LED is lit before connecting to your laptop and then goes out as soon as you connect to your laptop, then you either have a short circuit in the power supply module of your laptop, or you battery is causing the fault.
Remove the battery and try again. If it powers up the battery needs replacing. If the problem is still the same then you need someone to look at the power supply module in the laptop
Mar 09, 2010 | Acer Aspire 3610 Notebook
Benq laptop power unit 'short'?
The fact that the LED light on the power supply tells me that its receiving power, look where the AC adapter goes and check the pin to see if it is loose, this sounds like feedback from the computer causing the power supply light to dim or go out
let me know how you get on
Dec 02, 2008 | Computers & Internet
Acer aspire 3004 WLCi won't power on
Often times when laptop won't power on, it's jack on the back where the power supply plugs in. It needs to be disassembled, soldered back together and that should fix it. Good luck!
Aug 22, 2008 | Computers & Internet
Dell Latitude D 600/610 Logo
mukhtar21 shaikh
mukhtar21 shaikh
