Question about Toshiba Computers & Internet
My notebook PC overheats and then in about 10-15 minutes it shuts down
Gets really hot around the processor
  • Randy L. Klingman Dec 12, 2012
    Hi Lee, Funds are scarce right now so I will have a go at fixing myself. The model number is; PSKOGU-OCTO22.
  • jdmason58
    jdmason58 Feb 04, 2013
    I have a Toshiba P25-S508 and I would like to attempt to clean out or possibly change the heatsink or fan to correct. How do I change them?
  • Toshiba Master
  • 4,806 Answers
Hi.
The laptop needs to be cleaned around the fan and vents, this is caused by dust building up on them, it probably sounds very loud when its on. You could get a can of compressed air and try blast the dust out but i would recommend taking it to a professional and have them clean the inside for you. If you are confident enough to have a go yourself then post the model number and I'll tell you how to do it.
Regards.
Posted on Dec 12, 2012
  • Lee Hodgson
    Lee Hodgson Dec 12, 2012
    Hi. It will take me too long to type all the details so i have found a perfect video tutorial for you to watch, if there is anything else you need to know please post a comment.
SOURCE: laptop shutting off
go to control panel and click on to power options. in that you can check whether you have accidentally set the notebook to shutdown after 10 min. thanks for contacting fixya!.
Posted on May 31, 2009
SOURCE: Loud fans and Shutting down
I had same problem with a HP Pavillion ZD-7000.
Turned out to be dust had accumulated on the cpu making it run hot. Get a can of the dust off high pressure air and blow it into the fan intakes and output vents. Cleared my problem right up.
Posted on Oct 06, 2009
  • 156 Answers
SOURCE: how do i access the processor fan for hp pavilion
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
AND
With the ear bud clean the vents of the fan and check whether it is happening again. And if it is happening again do the bios update of the computer from the hp.com website and check.
Posted on Oct 29, 2009
contratek
  • 83 Answers
SOURCE: pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Posted on Jan 21, 2010
    harrihu
    • 7 Answers
    SOURCE: Hi. My notebook (Toshiba Satellite A75-S229) is
    I have family members who have also had similar problems. Your overheating problems may be linked to something more serious but there are a few things I would try first. Step 1 - Use a can of compressed air or an air compressor to blow out the dust from any vents or open areas. Clean out the fans as best you can because that can significantly reduce your noise problem. Step 2 - Do not use the computer on carpet or bed or your lap or anything that will block vents. A hard surface works best. Helpful Tip - You may want a usb powered cooling pad. Your laptop sits on top of it and it prevents raises it up off the desk. It plugs into a usb port on your computer and has fans on it that help keep the computer cool. Some even give you extra usb ports. Step 3 (May not work on all computers - I would install a program that monitors the heat of your computer components. One of the most popular is Speed Fan ( http://www.almico.com/speedfan.php ). Speed Fan can in some cases even adjust your hardware to reduce the temperature.
    If all else fails I would call Toshiba or send it into a computer repair service. If a computer is working properly it should not heat up that much which suggests an internal hardware component failure.
    Hope this helps and good luck to you.
    Posted on Mar 19, 2010
    My hp dv6449us laptop powers up and shuts down immediately how to fix please
    Your laptop is getting HOT because the cooling fan may not be cooling the processor. All it takes is about 15 seconds to overheat the processor. Need to get it serviced.
    Feb 16, 2013 | HP Pavilion DV6449US Notebook
    Overheating
    left side of the laptop will be processor fan... you have to change the ram which suits the laptop.. then it will not be overheated... and your shutdown problem will be solved
    Jun 28, 2012 | MPC Computers TransPort T2300 Notebook
    What would cause my aspire 5630 to shut down sporadically?
    Shut down sporadically, caused by rising temperatures on the processor (processor overheat). Processor overheat, caused by damage to the processor fan. Processor fan function to reduce the processor temperature.
    Possibilities and solutions
    1. The possibility of sluggish processor fan. Processor fan spins, with a low speed, so it can not reduce the processor temperature.
    Solution: clean the processor fan with a vacuum cleaner, or replace the processor fan.
    2. The possibility of fan processor die.
    Solution: replace the processor fan.
    The characteristics of damage to the processor fan
    After the laptop is turned off (more than 1 hour), the laptop can turn on and survive + - 30 minutes. In the period of + - 30 minutes, the laptop died suddenly, because the processor temperature exceeds safe limits (shut down temperature).
    How to check
    Laptop is turned off (more than 1 hour), then turn on. Download and install software to check the processor temperature. Ex. Real Temp 3.60. See the change in temperature. If the temperature continues to rise, it can certainly cause damage to the processor fan.
    - Normal temperature, when first turned on + - 38oC
    - Normal temperature, after turn on for hours 40oC - 45oC
    - Temperature overheat processor, when first turned on 60oC - 65oC
    Nov 18, 2011 | Acer Computers & Internet
    Unit gets very hot within 5 minutes and slows graphics down to a crawl or crashes the machine.
    I solved a really familiar problem 2 days before here at home.
    The problem is, that your notebook gets really hot within minutes. As it gets to an exact temperature, the CPU first slos down, then shuts down, to prevent damage, and to cool down. If it's an "old" notebook (I mean at least 1,5 - 2 years old), then the thermal paste on the processor got dry, and it doesn't do its job anymore. You have to apply a new amount of thermal paste (BTW you really should do it at least once a year).
    1. Turn the notebook upside down
    2. Take out the screws from the biggest panel (must be next to the heat grille)
    3. Take out the screws from the cooler of the CPU
    4. There will be a lot of white stuff on the CPU, clean it VERY carefully (tissue with alcohol, but NOT brush)
    5. Apply a little thermal paste on the CPU
    6. Take the CPU cooler back, and take the screws back
    7. Take the bottom panel bake, and take the screws back
    Here is a tutorial of it: http://www.youtube.com/watch?v=g3Izxh7J44s
    The other solution is to buy a notebook cooler: http://www.notebookcooler.info/media/ante-notebook-cooler-s.jpg
    Hope I could help.
    Dec 29, 2010 | Dell Latitude D620 Notebook
    My daughter called me this am from school. She said that her laptop seemed to be running hot, especially on the left side, and would shut down after about 15 minutes of use. I told her to run portable...
    Joe- This does sound like thermal shut down. Unfortunately what I would bet has happened, is your daughter uses her computer on the bed often, which picks up lint. This lint ends up plugging the intake port of the computer. I believe the A105 has access to the fans on the bottom pannel which is really helpfull otherwise you have to take the laptop apart. you should get in there with a brush, a vaccume, compressed air and really clean out the fans, and the fins of the heatsink. I would also pull the heatsink from the processor clean both the processor and heatsink with Alcohol and apply artic silver thermal paste to it as per the instructions. Now reassemble. It should be all set.
    As for the coolpad, if the fan is running, which I think it is, it will help. IT will not solve the problem, and the chip will continue to overheat and shut down but take longer to do so.
    Jun 16, 2010 | Toshiba Satellite A105-S171 Notebook
    My aspire 4730z overheats and shuts off even with a fan under it and our best buys geek squad said it wasnt designed to watch dvds even though it had a player. its under 1 year old. what can we do?
    First make sure the laptop is lint free, specially around the fan's area and on the coil.
    You'll notice hot air coming out of your laptop from it.
    Usually gets clogged up with accumulated dust.
    Use a vacuum in both areas.
    If it gets better, but still shuts down, then you need a heatsink cleaning, and a fresh heat release compound for the processor as well.
    Don't forget to rate this answer if it helps
    Dec 04, 2009 | Acer Aspire 5610-4648 Notebook
    Turns itself off & gets hot -don't think fan is kicking on
    Since you do not hear the fan anymore I would start by opening up the case and seeing if power is going to the fan and make sure any connectors for it have not come loose. If the connectors are still hooked up chances are the fan is shot and needs to be replaced.
    If you are not familiar with working around electronics and parts under power I would highly suggest you have some one who is familiar with this do it.
    May 06, 2009 | Computers & Internet
    Shuts down with no reason
    When a processor overheats the system will shut down to avoid physical damage to the processor. An indicator is that you'll have to push the power button twice to get the PC to start again.
    Do as Rtrahan suggests.
    Feb 08, 2009 | Toshiba Satellite P100 Notebook
    Laptop shutting off
    There might be a setting in the BIOS that shuts down the computer when the processor gets too hot. so, getting better cooling or turning off the setting will stop it. but, if you disable the setting, the Processor could overheat and explode.
    Jun 11, 2008 | Gateway 7320GZ Notebook
    System unstable
    This could be a couple of things, the shutdown will probably be because of the overheating, check for blockage around fan extraction area. The other could be that there is a virus or spyware running, taking over the processors work and causing a shut down or overheat error, check for both. The other could be a driver conflict, try doing a system restore to before the problem started.
    Nov 01, 2006 | Compaq EVO 2.0GHz Pentium 4 Notebook with...
    Computers & Internet Logo
    183 people viewed this question
    Top Toshiba Computers & Internet Experts
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
