Question about Maxell 8GB USB 360 USB 308 - 503202 Hard Drive
I cant get my maxwell 8gb flashdrive to work
I cant get my flash drive to work please help
  • Maxell Master
  • 27,725 Answers
W7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive then you restore it to its default status Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 You might have to alternate doing this repeatedly until the problem is resolved Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system.
If you need more help with this post a reply Hope this helps.
Posted on Dec 12, 2012
How do I put pictures from my home computer onto the SanDisk?
Once you plug the sandisk into your computer, a window should pop up asking you if you want to view the files on the disk, if it does, click on it. If not, just go to Start Menu -> My Computer -> (The Flash Drive). Move this window to the side so you can see the desktop aswell as the flashdrive folder. (You have have to 'demaximize' (Restore Down) the window so that you can see the desktop aswell. Then go to the start menu again and go to "My Pictures" or wherever your pictures are located. then, you can click and drag the pictures from the "My Pictures" folder into the FlashDrive's folder. Once all the images are copied into the flashdrive folder, you can unplug the flash drive and the images will be on it.
Hope this helped, Nathan Taylor
Jul 21, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Kingston 8gb pen has malfuntioned
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
May 30, 2011 | Kingston Digital 8GB DATATRAVELER C10...
I have a new 8gb usb memory and i train to put 4.3gb movie inside then a message say that is too big.the memory is empty.please help
If your having a problem transferring the file on your flashdrive you can reformat the drive so that it you can use all the available space on it. Just Right Click on the flashdrive the select Format Drive.
Thanks for using Fixya.
Jan 31, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Computer says destination is full but the flashdrive is empty. 7.46gb free. transfer of 4-6.5gb files
may be the pen drive is infected with virus Just backup the existing file of flash drive to another drive and format the flash drive and try to copy the files.
Have a nice day and do not forget to rate please...!
Feb 13, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I CAN SAVE ANYTHING IN TO MY FLASHDRIVE TRANSCEND
You killed it
Go to there WEB page, try the repair program.
If it does not work.
Pull down the warrenty paper work. (Life)
Send it in, just got my 8GB pack
cost 2 stamps, can you beat that
Feb 07, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I can not copy enything onto the 8gb flashdrive and if copied it cant be deleted again
Do you have a write protect switch on the pen? If so switch it to the open position.
Sep 10, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
SanDisk Titanium 8GB flash drive with files will not open
Microsoft has a fix for USB and other external peripherals.
http://support.microsoft.com/kb/925196#fixit4me
Hope this solves your issue. Good luck and all the best!
Greg
May 17, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Heating up, light not coming on
cruzer micro 4GB, loaded with data. works perfectly in all systems except my xp. Problem didn't originate until after ghosting system to correct different problem. Now, error message states flashdrive not recognized. must then get behind pc, and gently work with it until i can hear the shift in the duo core processors and the orange light on the flashdrive comes on. Please help.
Mar 10, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How to Unprotect a Write Protect Flash Drive
how to unprotect a write protect my flash drive & i cant copy paste any of my files to my flash drive it gives an error
error drive not found
Oct 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Maxell 8GB USB 360 USB 308 - 503202 Hard Drive Logo
218 people viewed this question
Top Maxell Computers & Internet Experts
yobo007
yobo007
Eric
Are you a Maxell Computer and Internet Expert? Answer questions, earn points and help others
