Question about General Electric PFSS6PKXSS Stainless Steel Bottom Freezer Commercial French Door Refrigerator
Ge pfss6pkwbss shows 88 and 8P
After power outage my refrigerator shows 88 and 8P. What does the 8P mean?
Samsung rt323ted has 33. E flashing on door after power outage and I forgot how to get rid of it. Can you help?
Samsung refrigerator giving error code 33E means the water fill tube heater for the ice maker is loose or faulty.
Pull the ice maker out and check it.
Jan 03, 2017 | Samsung Refrigerators
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
My unit wont get cold, had power outage and think it needs to be reset. How do u reset compressor or unit?
See this video for the "reset" function of some refrigerators:
Easy Refrigerator Fix Reset Defrost Timer Switch if it stops running...
Does My Refrigerator Have Reset Button
How Do Reset My Frigidaire Refrigerator
Said this, I don't mean to "panic" you but if you can't find this "restet" function, your refrigerator suffered a surge effect and might have some electronic cricuir damaged; in best case, some internal security fuse, typical as result of power outage, when power returns.
If you can't find that "reset" call repair service.
By the way, get a surge protector for your refrigerator as soon as possible. See some typica protectors at Amazon, but you can buy one at your local home depot or outlet store.
1800 Watts Refrigerator Surge Protector
Sep 01, 2015 | Refrigerators
The fridge turned off today due to a power outage and now it only shows a green bar on the display and is not cooling!
What kind of refrigerator, and whats the model number? Green bar flashing I'm going to guess a Samsung. If so, then hold down two buttons at the same time on the display, It depends on the model number as to which two, but in most cases its the power freeze and ref buttons. If you can get the brand and model # to me I could describe more for you.
Mar 22, 2011 | Refrigerators
I have a Samsung Refrigerator Model# RF4287HABP/XAA. Had a Power outage and now have an error Code Reading 13-e. Was unable to find what the code meaning was? any suggestions?
On a Samsung Refrigerator model #RF260BEAEBC French Door, press and hold both "Power Freeze" and "Power Cool" buttons simultaneously until chimes sound. This will reset the flashing 13 E code.
Dec 18, 2010 | Samsung Refrigerators
GE PFSS6PKW Displays 8888
Simply press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel.
May 10, 2010 | GE PFSS6PKSS
Refrigerator will not chill after power outage, frost on freezer
Please check other question on this subject, but long story short is that the unit needs to be completly defrosted, your freezer is what cools your fridge and if there is ice build up on the evaporator air cannot flow through to the fridge.
Aug 29, 2009 | LG LSC27931S Side by Side Refrigerator
Refrigerator will not reset after a power outage
just unplug it wait 5 minutes and plug back in. If this doesn;t work, replace the mother board.
David
May 16, 2009 | Samsung RS2534 Side by Side Refrigerator
General Electric PFSS6PKXSS Stainless Steel Bottom Freezer Commercial French Door Refrigerator Logo
112 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a General Refrigerator Expert? Answer questions, earn points and help others
