Question about Konica Minolta bizhub C250 All-In-One Laser Printer
C-2801 bizhub 501 - Konica Minolta bizhub C250 All-In-One Laser Printer
3 Suggested Answers
sspsychotic
  • 77 Answers
SOURCE: what is the problem code c-2801 in my konica
Have you check the Printer control board. Also does the toner bottle turn? You can force it in 47 Mode. to turn the bottle motor CW or CCW
Posted on Sep 07, 2009
copyalbania
  • 96 Answers
SOURCE: my konica minolta bizhub 361 has an error code
In my experience you have to change the developer and the machine will be ok.Also there is a chance that you have to clean the two toner sensor that are located in the end of the toner bottle,sometimes there is the problem.please let me know.
Posted on Feb 08, 2012
HOW DO I CLEAR C3806 ERROR CODE ON BIZHUB 501? PLEASE FORWARD ALL DIAGNOSIS CODE
Fusing main temperature low sensing.
clean TH1-Thermistor.
Power ON machine by pressing Utility Button.
and hold for 15 to 20 seconds.
Touch TROUBLERESET once appear.
now restart machine from main Power which is under Toner Door
Dec 21, 2016 | Konica Minolta Bizhub 501 Copier
I have one photocopier bizhub 501 and have error code 2801/03..Can you help me? thnx
Take the toner bottle out. Then you will need to remove several cover to gain access to the sensor way in the back of the where the toner bottle goes and clean that sensor. might even need replacing.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 25, 2015 | Konica Minolta Bizhub 501 Copier
Find release for Bizhub 501 drawer
Sir, draw release is in the back power off the machine and stick a thin screw driver in the hole(Located behind the big draw) to release the large capacity draw!
Nov 03, 2014 | Konica Minolta Bizhub 501 Copier
Konica bizhub 501 take code c2806
actually code c28xx have 7 variant. for example, c2801, c2802, c2803 (error 3,4,5,6) and c2804. if follow the code code c28xx is TCR output abnormality.
ok, first you clean T/S block, do servicing and cleaning all parts.
second, if still same, do toner auto supply.
third, trouble reset. off your machine first, press and hold utility/counter and on machine, until trouble reset appear. press it and off/on again. ^^,
Oct 05, 2013 | Konica Minolta Bizhub 501 Copier
Bizhub 501 error codes c3801
Maybe the power it's not correct.Try to reset hold utility key and power on hold the utility and on screen will be show the ikon trouble reset push it and will show ok power of and on again
Apr 29, 2013 | Konica Minolta Bizhub 501 Copier
How do I replace staples in bizhub 501
Open doors where toner is located.
Deep in the left cavity, you should find a brown unit in which the staple cartridge is located.
Carefully slide the unit towards you and when it reaches the edge, you can gently lift the blue handle and remove the empty cartridge.
Press each side and the spring will lift allowing you to remove the empty white cardboard staple holder. The arrows are to point away from the blue handle.
replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-0.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-1.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-3.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-6.jpg replace-staples-in-bizhub-501-ycf3eytmg1avdtjejiecbwdh-5-10.jpg
Feb 20, 2013 | Konica Minolta Office Equipment & Supplies
My konica minolta bizhub 361 has an error code c-2801.... what does that mean?
Aug 16, 2011 | Konica Minolta bizhub C351 All-In-One...
Bizhub 420 error code c-2801
konica minolta bizhub 420
error code 2801 plesce relese the code prectical met
Feb 08, 2010 | Konica Minolta Office Equipment & Supplies
What is the problem code c-2801 in my konica bizhub 420
Sep 07, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
93 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
