Question about As Seen On TV Tobi Steamer The Original Clothes Steamer
Tobi steamer replacement parts
Where can i get a replacement strap & cap for the water bottle
Where can I buy tobi steamer parts
Have you tried Tobi? The manufacturers usually can supply parts.
Sep 03, 2014 | Cars & Trucks
My Tobi Steamer will not power on?
Check the fuse in the mains plug and replace it with a like value one. If this doesn't work your iron is at fault.
Jan 08, 2014 | Irons
I need a replacement hose for my tobi steamer
Can't you cut the hose so it is even across, and level? Reaffix the hose to the steamer portion. Just remove the old attached hose from the end of the handle, clean it and reaffix the freshly cut end into the handle once again.
Dec 21, 2013 | As Seen On TV Tobi Steamer The Original...
Instructions for cleaning Bottle steamer
steam it with 1/2 vinegar & 1/2 water. Then steam it two more times with only water.
Aug 12, 2012 | Kidsline Baby Chef Six Bottle Sanitizing...
I left the stemmer on and all the water was gone and the light went out...it wont turn on now. is it finished?
Possibility is that the coil burned up or a thermal fuse opened. If it was a thermostat, it would have reset. Replace it.
Aug 10, 2012 | As Seen On TV Tobi Steamer The Original...
Maxi cosi tobi strap has jammed
It's not possible to loosen the belts of your Tobi?In this case you may need a repair of the quick-adjuster (the part where the buckle is attached to) or it may be appropriate to exchange the quick-adjuster.
Because this part is directly affecting the safety of the seat I would advise you not to try to repair it yourself; please visit a Maxi Cosi dealer to have it serviced.
I hope this helps.
Erwin de Raadwww.babycare.nl
Sep 20, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Need instructions for adjusting straps in maxi cosi tobi car seat also on how to remove covers to wash thanks tracy
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
Jul 13, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Pulled tensioner on maxi cosi tobi now i cant release it back
Just did it. It took two of us, but only a couple of minutes and no tools (except a table knife) once we'd worked out what the problem was. The reason the strap doesn't thread easily through the slot is that there is a sprung two-part mechanism that needs to be held open. One person threads the strap through while the other keeps the mechanism open.
Person 1:
1) Find the slot under the chair that the strap goes into - turn the seat upside down; it's a thin gap you can feel with your fingertip when you run your finger along the narrow back of the metal strip under the front of the seat (not the base).
2) Remove the metal rod that attaches the grey reclining lever. The rod is about 20 cm long and can be pushed out without tools. Removing this rod seems to make it easier to open the buckle mechanism. When replacing the rod later, you just have to line it up carefully with holes (we used a torch to help us see them)
3) Make sure the strap passes under the metal rod at the bottom of the seat back (you can see how here in a small photo here: http://www.englishforum.ch/attachments/sale-wanted/37565d1327058634-sale-maxi-cosi-tobi-car-seat-9mths-3-yrs-zh-maxi_cosi_tobu_small.jpg)
Person 2
4) Push back buckle as far as it will go (it goes back past vertical easily, then needs another firmer push,
5) Hold the buckle in this backwards position.
6) Insert a table knife (rounded and blunt, not sharp) into the space under the buckle and push back the sprung, hinged plastic part that the knife touches at the back.
7) Person 1 then threads the strap back through the slot, pushing until then end comes out.
8) Tie a knot in the end of the strap so you don't accidentally pull it through again!
9) Replace the metal rod in the reclining mechanism.
10) Done!
Mar 21, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Steamer filler cap is sealed
You need a little more leverage--either a strap type tool or a pair of adjustable width pliers that span the width of the cap. Try running hot water over the cap first which may loosen it enough to remove by hand.
Sep 09, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
As Seen On TV Tobi Steamer The Original Clothes Steamer Logo
578 people viewed this question
Top As Seen On TV Televison & Video Experts
Andrew Taylor
Andrew Taylor
Are you an As Seen On TV Televison and Video Expert? Answer questions, earn points and help others
