Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Tuner does not work - Panasonic TH-42PD50U 42 in. Plasma EDTV
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
If the tuner in the set is bad connect to component or even composite inputs on the rear of the set and bypass the tuner built into the set.
What are you using for signal and what makes you think the tuner in the set is bad?
Posted on Dec 12, 2012
  • Guy Tessier Dec 12, 2012
    When I select TV , screen is black w no sound. Set is connected to cable Tv. Tried another set and cable tv works.
Tuner does not work on my Tuner Amplifier
Check to see if the antenna is loose. Most amplifiers will mute the output if they don't detect a strong radio signal.
Jul 26, 2013 | Televison & Video
I have a Toshiba cx35e70 tv. The problem began as a turn on, live screen, no channels, no sound. I found that when I would tap on the tuner on the main board the problem would disappear. Every thing worked...
Is the VCR going through ch 3 or video inputs - if video inputs your TV tuner is likely bad if through ch 3 seeif te picture goes funny on ch 3 without using the VCR the tuner may be bad on higher band channels - smetimes you can remove the tuner and resolder the tuner itself. But if it always works with the VCR just use it that way and don't bother with the fix.
Sep 26, 2009 | Televison & Video
Philips SAA7130 TV Tuner/FM Radio/Video PCI remote stopped working
PLEASE THE SEND THE TV TUNER CARD DRIVERS I AM LOST THE TV TUNER CD
May 04, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Vizio P50HDTV10A 50 in. HDTV Plasma HDTV Tuner out
The HDTV tuner is out. Analog tuner, and video inputs work fine.
TV Model P50HDTV10A
Screen Size 50 in.
TV Manufactured Date Jan 1, 2007
Part Type MAIN UNIT
Alternate Part Type SIGNAL BOARD
Part Number 3850-0042-0150(3A)
Alternate Part Number 0171-2272-2163
Jan 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Sony projection tv with dual tuners; only one tuner appears to be working now.
To verify that the tuner is the problem, move the cable from the second to the first. If you don't get a signal, the tuner is bad. The main tuner is part number 859843000 and is available for $47.38 from tritronicsinc.com
Dan
Oct 07, 2008 | Sony KP-51HW40 51" Rear Projection...
TV Tuner Not Installed
use roll back driver see its work do you knew how to roll back
Aug 15, 2008 | Dell Dimension 2400 PC Desktop
TV Tuner Card is not working on DG31PR Motherboard
You should always install mainboard drivers first.
Remove tuner card, install all other drivers, then add in Tuner card.
Aug 05, 2008 | Intel DG31PR Motherboard
Haier 26; TV Tuner
contact the Haier Service center in NY. www.asnyonline.com
May 25, 2008 | Haier HL32BG 32 in. LCD Television
Can not get picture/sound on my big-screen
Although this is an old post I will try to answer it the best I can.
As long as you have hooked up your cablr/dvd onto the right tuner ( tuner a/tuner b.etc ), it should work if you go to the menu and turn on that tuner. ( ie: if you hook the tuner to tuner A, open up your menu and find where it asks which tuner you are choosing to use and click on tuner A ), then the set should work. If this doesn't straighten up the problem, you may have a bad processor on the main tuner board. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Oct 17, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
